  3. External power supply to radio
14 Posts 4 Posters 10.6k Views 1 Watching
  • RJ_MakeR RJ_Make
    @gigi What kind of problems did you have when connected to the Mega's 3.3v pin?
    gigiG
    gigiG
    gigi
    does not transmit the data. sketch hangs after send data
    @pete1450 said:
    No problem connecting different power supplies, but often finicky components don't like having separate grounds. Connect the ground of everything together and see how it works.
    I try tomorrow
    I will keep you updated.
    I put together a radio rfm12b, a NRF24L01 and a display 128x64
    Thank
    Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
    RJ_MakeR 1 Reply Last reply
    • gigiG gigi
      I try tomorrow
      Thank
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @gigi Is there anything else connected to the 3.3v pin? If not, have you tried installing a cap (I have to use 47uf) on the radio across Vcc and GND?
      RJ_Make
        I had to use a step down from 5V to get stable 3.3v power on the mega.
        gigiG 1 Reply Last reply
          gigiG
          gigiG
          gigi
          unfortunately I did not step down to try!!!!
          With PC USB Arduino Mega does not start the radio.
          the system only works when I put an external power supply to VIN on Arduino Mega.
          after 2 or 3 hours arduino crashes!!!
          • gigiG
            gigiG
            gigi
            This is the sketch arduino
            emon_mysensors.ino
            • gigiG gigi
              emon_mysensors.ino
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @gigi Wow, that's a lot of "stuff" on that 3.3v rail. I think that's your problem... What kind of current are you pulling on that rail when the radio is transmitting.?
              RJ_Make
              • RJ_MakeR RJ_Make
                gigiG
                gigiG
                gigi
                now I try to put the temperature sensor on the 5 volt
                arduino mega limits the current on 3.3v?
                I order AMS1117-3.3V,
                My idea:
                put the step-down input to 5V external power supply and output on 3.3 rail!!! For not use 3.3 v to MEGA
                • gigiG gigi
                  My idea:
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @gigi
                  Here are some specs.
                  Summary:
                  Microcontroller ATmega2560
                  Operating Voltage 5V
                  Input Voltage (recommended) 7-12V
                  Input Voltage (limits) 6-20V
                  Digital I/O Pins 54 (of which 15 provide PWM output)
                  Analog Input Pins 16
                  DC Current per I/O Pin 40 mA
                  DC Current for 3.3V Pin 50 mA
                  Flash Memory 256 KB of which 8 KB used by bootloader
                  SRAM 8 KB
                  EEPROM 4 KB
                  Clock Speed 16 MHz
                  RJ_Make
                  • gigiG
                    gigiG
                    gigi
                    Relay on
                    Only 3.3 volt
                    I do not know if I measured correctly, and my instrument is accurate !!!!!
                    • gigiG gigi
                      Relay on
                      Only 3.3 volt
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      wrote on last edited by RJ_Make
                      @gigi I just can't believe that the display, rfm12b and NRF24 on the same 3.3v rail is under 50ma,... not too mention the other stuff on it.. You could try disconnecting everything except the NRF24 and see what happens?
                      I can't even get my NRF24's to work with the shop's listed boost with the Pro Mini attached without a 'massive' capacitor.
                      RJ_Make
                      • gigiG
                        gigiG
                        gigi
                        I tried to put a separate power supply.
                        General supply 5V 2 Amps.
                        I do not have the controller and I put two arduino nano for 3.3 volts
                        after 2 hours the system crashes.
                        if I put only one of the two radio system is fine.
                        I tried it with a standalone with two radio but without a monitor and the system works perfectly!!!
                        I have to put other capacitors?
                        Thank
