  3. Watchdog on Ethernet Gateway
ethernetgatewayattiny45watchdog
32 Posts 9 Posters 24.2k Views 1 Watching
  • Dan S.D
    Dan S.D
    Dan S.
    Added a 8 sec Watchdog to my ethernet gateway and it's up and running now. Time will tell if it cures the occaisional lockups by automatically resetting. Will report back the results
      FYI: Watchdog reset is automatically called by process() nowadays in the development-branch.
      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.cpp#L509
      Dan S.D 2 Replies Last reply
        Dan S.D
        Dan S.D
        Dan S.
        @hek I assume this is with the intent to allow a watchdog reset on sensor sketches in the future, but does not apply to the Ethernet gateway sketch?
          Dan S.D
          Dan S.D
          Dan S.
          @hek Please disregard my prior message. I looked further and see that the watchdog reset is part of the sensor wait routine and is in the current 1.4 version of MySensors.cpp
          • Dan S.D
            Dan S.D
            Dan S.
            It's been over 6 weeks since I added an 8 sec watchdog to my Ethernet gateway (to Vera) and have not had to reboot the gateway since then. Before adding the watchdog, the most it ever lasted before without rebooting was 4 weeks. So for now I have to assume that the watchdog is doing its job and automatically restoring the gateway. If so, then it is providing the gateway dependability that I wanted. Time will tell.
            • Dan S.D Dan S.
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @Dan-S.
              great news, thanks for the update!
              can you share how you set it up? Are you using the stock gateway code?
                @Dan-S.
                Dan S.D
                Dan S.D
                Dan S.
                @BulldogLowell
                I got my basic info and code for a watchdog timer from a pdf by Nicolas Larson titled "Basic Watchdog Timer" at this site:
                http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB4QFjAA&url=http%3A%2F%2Fforum.arduino.cc%2Findex.php%3Faction%3Ddlattach%3Btopic%3D63651.0%3Battach%3D3585&ei=lc6ZVYiiM8PigwTVx4HYCQ&usg=AFQjCNEBfr1yZ_g44GdxaNVmH4zKyTz3nA&bvm=bv.96952980,d.eXY
                Yes, I am using the stock gateway code with the watchdog code outlined in the pdf added. His code includes a lot of details in the setup that can probably be streamlined but I liked operating at the elementary level to better see what is going on.
                Will post the whole gateway sketch. What's the best way to go about posting it?
                DwaltD 1 Reply Last reply
                • Dan S.D Dan S.
                  @BulldogLowell
                  DwaltD
                  DwaltD
                  Dwalt
                  @Dan-S. To insert code on the forum, use the </> button above the 'compose box'.
                    @Dan-S.
                    Dan S.D
                    Dan S.D
                    Dan S.
                    @BulldogLowell
                    Here's the code. Should be the same as standard except that I didn't use ip address input.
                    In
                     * Copyright (C) 2013 Henrik Ekblad <henrik.ekblad@gmail.com>
                     * Contribution by a-lurker
                     * COMPILING WIZNET (W5100) ETHERNET MODULE
                     * > Edit RF24_config.h in (libraries\MySensors\utility) to enable softspi (remove // before "#define SOFTSPI").
                     * COMPILING ENC28J60 ETHERNET MODULE
                     * > Use Arduino IDE 1.5.7 (or later)
                     * > Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading.
                     * > Remove Ethernet.h include below and include UIPEthernet.h
                     * > Remove DigitalIO include
                     * Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module)
                     * VERA CONFIGURATION:
                     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
                     * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
                     * LED purposes:
                    #include <DigitalIO.h>     // This include can be removed when using UIPEthernet module
                    #include <MyGateway.h>
                    #include <stdarg.h>
                    //watchdog version of gateway
                    #include <avr/wdt.h>
                    // Use this if you have attached a Ethernet ENC28J60 shields
                    //#include <UIPEthernet.h>
                    // Use this fo WizNET W5100 module and Arduino Ethernet Shield
                    #include <Ethernet.h>
                    #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
                    #define INCLUSION_MODE_PIN  3 // Digital pin used for inclusion mode button
                    #define RADIO_CE_PIN        5  // radio chip enable
                    #define RADIO_SPI_SS_PIN    6  // radio SPI serial select
                    #define RADIO_ERROR_LED_PIN 7  // Error led pin
                    #define RADIO_RX_LED_PIN    8  // Receive led pin
                    #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
                    #define IP_PORT 5003        // The port you want to open
                    //IPAddress myIp (192, 168, 1, 14);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
                    // Commented out IPAddress to use DHCP router assigned address, Cannot check program with serial monitor with this
                    //since the DHCP address will not be available till plugged into ethernet.
                    byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
                    // a R/W server on the port
                    EthernetServer server = EthernetServer(IP_PORT);
                    // No blink or button functionality. Use the vanilla constructor.
                    MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME);
                    // Uncomment this constructor if you have leds and include button attached to your gateway
                    //MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                    int inputPos = 0;
                      Ethernet.begin(mac);
                      // give the Ethernet interface a second to initialize
                      delay(1000);
                      // Initialize gateway at maximum PA level, channel 70 and callback for write operations
                      gw.begin(RF24_PA_LEVEL_GW, RF24_CHANNEL, RF24_DATARATE, writeEthernet);
                      // start listening for clients
                      server.begin();
                      //set the watchdog
                      watchdogSetup();
                    // This will be called when data should be written to ethernet
                    void writeEthernet(char *writeBuffer) {
                      server.write(writeBuffer);
                    //WatchDog setup function
                    void watchdogSetup(void)
                    cli();
                    wdt_reset();
                    WDTCSR configuration:
                    WDIE = 1: Interrupt Enable
                    WDE = 1 :Reset Enable
                    WDP3 = 1 :For 8000ms Time-out
                    WDP2 = 0 :For 8000ms Time-out
                    WDP1 = 0 :For 8000ms Time-out
                    WDP0 = 1 :For 8000ms Time-out
                    // Enter Watchdog Configuration mode:
                    WDTCSR |= (1<<WDCE) | (1<<WDE);
                    // Set Watchdog settings:
                    //no interrupt, reset enable
                    WDTCSR = (0<<WDIE) | (1<<WDE) |
                    //8 second timer
                    (1<<WDP3) | (0<<WDP2) | (0<<WDP1) |
                    (1<<WDP0);
                    sei();
                      // if an incoming client connects, there will be
                      // bytes available to read via the client object
                      EthernetClient client = server.available();
                      if (client) {
                          // if got 1 or more bytes
                          if (client.available()) {
                             // read the bytes incoming from the client
                             char inChar = client.read();
                             if (inputPos<MAX_RECEIVE_LENGTH-1) {
                               // if newline then command is complete
                               if (inChar == '\n') {
                                  // a command was issued by the client
                                  // we will now try to send it to the actuator
                                  inputString[inputPos] = 0;
                                  // echo the string to the serial port
                                  Serial.print(inputString);
                                  gw.parseAndSend(inputString);
                                  // clear the string:
                                  inputPos = 0;
                               } else {
                                 // add it to the inputString:
                                 inputString[inputPos] = inChar;
                                 inputPos++;
                            } else {
                               // Incoming message too long. Throw away
                               inputPos = 0;
                       gw.processRadioMessage();
                     //reset watchdog
                     wdt_reset();
                    • Dan S.D
                      Dan S.D
                      Dan S.
                      Would not recommend adding the watchdog until you have a relatively stable gateway, e.g. you have addressed any power/radio issues etc. Otherwise you will have the watchdog constantly tripping in response to issues that are best addressed by other means, i.e., proper troubleshooting.
                      • NeverDieN
                        NeverDieN
                        #31
                        FWIW, I've also experienced rare intermittent lockups on a clone Mega2560 with a clone ethernet shield. By rare I mean an interval between lockups of anywhere from 2 weeks to 6 months, with a median of around 4 months. i.e. It happens, but not very frequently, and so far I haven't seen a pattern to it.
                        Does the arduino's stock brownout protection circuit protect against all possible brownout scenarios, or just some of them? Anyone happen to know? Because I don't know the answer, the next step for me is to put it on a UPS to see if it makes any difference.
                        If your arduino is powered via USB, then my impression is the arduino gives you no additional protection against voltage spikes. Most USB power sources are buck converters. Do buck converters alone typically do well at flattening voltage spikes, or would you need to add a voltage regulator to ensure all voltage spikes get flattened out? Anyone happen to know? Depending on the answer, it may be reason to power through the barrel jack, which goes through the onboard voltage regulator, rather than through the USB.
                        Regarding use of the built-in watchdog protection, is there a possible brownout/spike scenario that could defeat the watchdog protection in addition to wedge the regular program loop? Or is the watchdog bulletproof in that regard?
                        Dan S.D 1 Reply Last reply
                        • NeverDieN NeverDie
                          Dan S.D
                          Dan S.D
                          Dan S.
                          @NeverDie All I can say is that after adding the watchdog I have not had a lockup in 2+ months. Before that, like you, I had random lockups. Based on this positive experience I also added a watchdog to the one repeater I have in my system. Had a brief power outage the other day and everything came back online by itself with no problems.
