  2. Bug Reports
  3. Node personalizer sketch seems broken in MySensors 2.3.1
3 Posts 3 Posters 1.6k Views 2 Watching
  • joaoabsJ
    joaoabsJ
    joaoabs
    My node personalizer is running fine as always if I use the 2.3.0 version of the library.
    However, when upgrading the library to the latest 2.3.1, it doesn't compile anymore.
    home/xxx/node-personaliser-signing/node-personaliser-signing.ino: In function 'void write_eeprom_checksum()':
    node-personaliser-signing:524: error: 'signerSha256Init' was not declared in this scope
         signerSha256Init();
    node-personaliser-signing:526: error: 'signerSha256Update' was not declared in this scope
         signerSha256Update(buffer, 32);
    node-personaliser-signing:531: error: 'signerSha256Final' was not declared in this scope
         hash = signerSha256Final();
    exit status 1
    Going back to version 2.3.0 overcomes the issue, but I guess it should be solved in 2.3.1, right?
    AnticimexA 1 Reply Last reply
    • joaoabsJ joaoabs
           signerSha256Init();
      exit status 1
      AnticimexA
      AnticimexA
      Anticimex
      @joaoabs thanks for reporting.
      @tekka something related to your crypto hal refactoring?
      • tekkaT
        tekkaT
        tekka
        Bingo! This is a backwards incompatibility :triumph: - thanks for reporting!
        @joaoabs You should be able to fix this by using the SecurityPersonalizer example from the 2.3.1 lib and copy/paste the settings section from your current sketch to the example sketch.
        @Anticimex issue originates from replacing all signerSHA256xyz() functions in the cryptoHAL
