  3. Relay node hangs sometimes when toggling a fan
10 Posts 4 Posters 6.1k Views 3 Watching
  • C Offline
    C Offline
    chris021
    I have a sensor node driving a fan and sometimes when toggling the relay the node locks up. I am using a nano board and when it locks up the TX led stays solid.
    The relay board is opto isolated. I have done some research about the interference that can be caused by a relay switching a motor, but I don't understand the solutions and given its 240v I don't want to make changes to the 240 side unless I fully understand them.
    I have tried swapping out the radio, the nano and the relay.
    I have not been able to reproduce the fault when the fan is disconnected.
    My skills are quite basic so any simple advice would be very much appreciated!
    Chris021
    • H Offline
      H Offline
      Do you feed the relay from your arduino?
      • C Offline
        C Offline
        chris021
        I have D3 signal low to trigger the relay. The same 5V source powers the relay, but this works fine if no load is connected.
        B 1 Reply Last reply
        • C chris021
          B Offline
          B Offline
          BulldogLowell
          what kind of power source are you using?
          C 1 Reply Last reply
          • T Offline
            T Offline
            TimO
            I've the same problem with a 4 relay board. After a few times switching on and off, the Atmega hangs.
            Especially if more than one relay on the board is switched.
            I'm currently swithing the power source.
            • B BulldogLowell
              C Offline
              C Offline
              chris021
              @BulldogLowell im using one of these onto the 5v pin of the board:
              http://www.aliexpress.com/item/5-pcs-AC-DC-85V-265V-700mA-Isolated-Switching-Power-Board-Module-Industrial-Power-Supply-Built/1260239970.html
              I have also tried feeding it via USB of a 2.1 amp supply with the same results.
              • B Offline
                B Offline
                BulldogLowell
                So you are powering both the relays and the arduino in parallel from the transformer?
                have you tried isolating the arduino's power from the transformer with a capacitor?
                the power surge of the relays (even though you have an opto-isolator from arduino to relays) may cause issues for the arduino.
                perhaps start with a regular 4.7µF across the Vin and ground of the arduino
                • C Offline
                  C Offline
                  chris021
                  its worth a try, however this works 100% fine when there is not a fan connected :) I might try a different AC device to see if that is just as reliable as no AC device connected.
                  • C chris021
                    B Offline
                    B Offline
                    BulldogLowell
                    motors draw a tremendous amount of current when they start... Try isolating the arduino's power from the transformer, or using the capacitor.
                    • B BulldogLowell
                      C Offline
                      C Offline
                      chris021
                      @BulldogLowell I have powered it off an external battery pack. Same story!
                      12.2k
