  3. Dectect wake up source
12 Posts 5 Posters 2.2k Views 3 Watching
  • GeforceGamerG
    GeforceGamerG
    GeforceGamer
    is it possible to dectect how my node wakes up? If the wake up cames form the button or by timer?
    this is my sleep code:
    sleep(digitalPinToInterrupt(reedswitch), CHANGE, SLEEP_TIME);
    I want to check something like this:
    If (wakeUpByTime == 1)
        Serial.println("Node wakes up by timer");
    else
       Serial.println("Node wakes up by Button");
    • nagelcN
      nagelcN
      nagelc
      Yes. sleep() gives a return code you can use. See the discussion in the API page here:
      https://www.mysensors.org/download/sensor_api_20#sleeping
      • GeforceGamerG GeforceGamer
        else
        @geforcegamer
        if (interruptReturn == true) {    // Woke up by changing pin
           if woken by interrupt code
        if (interruptReturn == false) { // Woke up by timer  (or it's the first run)
        'if not by interrupt
         interruptReturn = sleep(digitalPinToInterrupt(PIR_PIN), RISING, SLEEP_TIME);
        From my doorbell sensor: https://github.com/sundberg84/HomeAutomation/blob/master/Sketches MySensors Nrf24l01 radio/DoorBellDec1mhz/DoorBellDec1mhz.ino
        Waiting for en external interrupt, or a timer.
        Im sure there are better/prettier code since thats not my stronge side. But its an example...
        • GeforceGamerG
          GeforceGamerG
          GeforceGamer
          @nagelc Thank you.
          @sundberg84 Thanks for the great example. It really helped me a lot. I will try it out the days.
          • GeforceGamerG
            GeforceGamerG
            GeforceGamer
            unfortunately it does not work with me so. I don't know whats wrong. At the first start of the node it works. But the wakeup by time shows wake up by interrupt and the wake by interrupt shows "wake up by interrupt" too.
            if (interruptReturn == true)     // Woke up by changing pin
                wakeup= 1;
                Serial.println("wake up interrupt");
              if (interruptReturn == false)     // Woke up by Timer
                wakeup= 0;
                Serial.println("wake up timer");
            interruptReturn = sleep(digitalPinToInterrupt(reedswitch), CHANGE, SLEEP_TIME);
            YveauxY 1 Reply Last reply
                  wakeup= 1;
                  wakeup= 0;
              YveauxY
              YveauxY
              @geforcegamer what do you use as interrupt source?
              If you use e.g. a hardware button then bouncing of the switch contacts can cause the node to wake up unexpectedly.
              Also, you wake on CHANGE, meaning both a low high and high low transition will wake up your node (e.g. Button press and button release).
              Can you describe your hardware setup?
              • GeforceGamerG
                GeforceGamerG
                GeforceGamer
                @Yveaux
                I use an reedswitch as interrupt source. It is use in a bin to measure the level. I use the CHANGE command to always wake up the node. No matter if the lid is opened or closed.
                  @Yveaux
                  @geforcegamer how is the interruptreturn variable declared? Is it scoped to survive (we can only see part of your code - maybe the value is lost at the end of loop()?
                  • GeforceGamerG
                    GeforceGamerG
                    GeforceGamer
                    wrote on last edited by GeforceGamer
                    bool interruptReturn;
                        offen = 1;
                        Serial.println("aufwachen durch Deckel");
                        offen = 0;
                        Serial.println("aufwachen durch Timer");
                          offen = 1;
                          offen = 0;
                      @geforcegamer I think I found the problem. Sleep returns an int, not a bool. Change
                      to
                      int interruptReturn;
                      and change
                        offen = 1;
                        offen = 0;
                      to
                      if (interruptReturn == MY_WAKE_UP_BY_TIMER)
                        offen = 0;
                      } else  {     // Woke up by interrupt (or MY_SLEEP_NOT_POSSIBLE)
                        offen = 1;
                      Documentation: https://www.mysensors.org/download/sensor_api_20#sleeping
                      • GeforceGamerG
                        GeforceGamerG
                        GeforceGamer
                        @mfalkvidd
                        Thanks alot. Now the wake-up detection works perfectly
                          @mfalkvidd
                          @geforcegamer great, thanks for reporting the result.
                          @sundberg84 next time you update your doorbell, maybe you should add the same changes.
