  3. Mozilla WebThings Gateway
  4. Mozilla Webthings MySensors add-on / adapter
Scheduled Pinned Locked Moved Mozilla WebThings Gateway
55 Posts 5 Posters 12.5k Views 8 Watching
  • Nca78N
    Nca78N
    wrote on last edited by Nca78
    #21
    I removed the add-on, I restarted, reinstalled the add on.
    It's recreating the sensor from Persistance, but that sensor was removed from the thing detail page before, so it should not have any persistance left ? Also the recreated thing/sensor is not visible anywhere: not in add things, not in things view.
    2019-05-30 08:23:31.508 INFO   : mysensors: RECREATING DEVICES FROM PERSISTENCE
    2019-05-30 08:23:31.510 INFO   : mysensors: -Recreating: BlackCircleSensor
    2019-05-30 08:23:31.512 INFO   : mysensors: AddonManagerProxy: Failed to send message: Nanomsg library was terminated
    2019-05-30 08:23:31.518 INFO   : mysensors: AddonManagerProxy: handle_device_added: MySensors_33
    2019-05-30 08:23:31.521 INFO   : mysensors: AddonManagerProxy: Failed to send message: Nanomsg library was terminated
    2019-05-30 08:23:31.522 INFO   : mysensors: + DEVICE.ADD_CHILD with child_id: 1
    2019-05-30 08:23:31.525 INFO   : mysensors: new_description = Temperature
    2019-05-30 08:23:31.527 INFO   : mysensors: AddonManagerProxy: Failed to send message: Nanomsg library was terminated
    2019-05-30 08:23:31.528 INFO   : mysensors: AddonManagerProxy: Failed to send message: Nanomsg library was terminated
    2019-05-30 08:23:31.530 INFO   : mysensors: AddonManagerProxy: handle_device_added: MySensors_33
    2019-05-30 08:23:31.532 INFO   : mysensors: AddonManagerProxy: Failed to send message: Nanomsg library was terminated
    2019-05-30 08:23:31.534 INFO   : mysensors: + DEVICE.ADD_CHILD with child_id: 2
    2019-05-30 08:23:31.536 INFO   : mysensors: new_description = Humidity
    2019-05-30 08:23:31.538 INFO   : mysensors: AddonManagerProxy: Failed to send message: Nanomsg library was terminated
    2019-05-30 08:23:31.539 INFO   : mysensors: AddonManagerProxy: Failed to send message: Nanomsg library was terminated
    2019-05-30 08:23:31.541 INFO   : mysensors: AddonManagerProxy: handle_device_added: MySensors_33
    2019-05-30 08:23:31.543 INFO   : mysensors: AddonManagerProxy: Failed to send message: Nanomsg library was terminated
    Also it seems all files remain when the add-on is removed, I'm not sure if it's a problem with the add-on or with the gateway ? When re-adding the add-on I have a bunch of messages similar to those :
    2019-05-30 08:23:20.911 INFO   : mysensors: Target directory /home/pi/.mozilla-iot/addons/mysensors-adapter/lib/crcmod already exists. Specify --upgrade to force replacement.
    2019-05-30 08:23:20.915 INFO   : mysensors: Target directory /home/pi/.mozilla-iot/addons/mysensors-adapter/lib/serial already exists. Specify --upgrade to force replacement.
    2019-05-30 08:23:20.919 INFO   : mysensors: Target directory /home/pi/.mozilla-iot/addons/mysensors-adapter/lib/voluptuous-0.11.5.egg-info already exists. Specify --upgrade to force replacement.
    2019-05-30 08:23:20.929 INFO   : mysensors: Target directory /home/pi/.mozilla-iot/addons/mysensors-adapter/lib/pymysensors-0.18.0.egg-info already exists. Specify --upgrade to force replacement.
    alowhumA 1 Reply Last reply
    • Nca78N Nca78
      alowhumA
      alowhumA
      alowhum
      #22
      @nca78 So the first issue is gone, right?
      The short version:
      Your log shows this error: Nanomsg library was terminated, which indicates that the Gateway component that the add-on communicates with has crashed. Your best bet is to restart the WebThings Gateway/Raspberry Pi.
      The long version:
      If you disable persistence, it does not remove the persistence file. That file is always used to remember all the node ID's that have been handed out.
      If you disable persistence, all that happens is that it no longer re-generates all the things after a restart of the gateway/add-on. If persistence is disabled, nodes will only show up once they present themselves. To speed this up, the add-on goes over the list of stored node ID's and asks all of them, one per second, to re-present themselves. Another way to get them to re-present themselves is to simply restart the node.
      If you remove a thing in the Gateway, the latest version (0.0.5) also removes its data from the persistence file. In other words: if you remove a thing, you will most likely have to restart the node if you want it to show up on the 'add things' page again.
      "It's recreating the sensor from Persistance, but that sensor was removed from the thing detail page before, so it should not have any persistance left ?"
      Correct, it should theoretically no longer be in the persistence file.
      "Also the recreated thing/sensor is not visible anywhere: not in add things, not in things view."
      Then how do you know it's been recreated? From the log?
      Strange that the add-on files are still there after removing the add-on. I'm not even sure those files should have ever been there. Did you do a git clone at some point? Perhaps the crashed part of the Gateway also resulted in the add-on not really being removed.
      Nca78N 1 Reply Last reply
      • alowhumA alowhum
        The short version:
        The long version:
        Nca78N
        Nca78N
        @alowhum said in Mozilla Webthings MySensors add-on / adapter:
        No, not at all. I still can't add any node in MySensors.
        I did, it didn't work
        Well from the log I believe it's still here ?
        Yes, from the log as it's not visible anywhere else. And neither are new nodes. Very frustrating :(
        No I never fiddled directly with the files. I think I will do it now, my guess is the problem is related to those messages I see in log when I remove the add-on:
        2019-05-30 09:45:07.158 INFO   : Unloading MySensorsAdapter
        2019-05-30 09:45:07.166 INFO   : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadAdapter","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
        2019-05-30 09:45:07.179 INFO   : mysensors: Shutting down MySensors adapter
        2019-05-30 09:45:07.181 INFO   : mysensors: MySensors adapter was unable to cleanly close PyMySensors
        2019-05-30 09:45:07.183 INFO   : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadPlugin","data":{"pluginId":"mysensors-adapter"}}'
        2019-05-30 09:45:10.188 INFO   : Killing mysensors-adapter plugin.
        • Nca78N
          Nca78N
          So connected with SSH and the directory is gone now.
          I reinstalled the add-on and I didn't have those messages about files already existing, only success messages.
          But I don't get why it still has my configuration for MySensors gateway URL etc. I install the add-on and after install it connects directly to the MySensors gateway.
          I don't know what happened also but it seems I had a problem with the gateway too as I didn't have sensor info in it's log. Now I reprogrammed it and I see log when sensor sends and I have the sensor in the add sensor view.
          No idea of what happened, but it seems problem was with my own sensors/gateway and not the add-on :)
          • alowhumA
            alowhumA
            alowhum
            @Nca78 Glad to hear it.
            I suspect that because part of the gateway had crashed, all the things you thought you did never actually happened. You never really deleted the thing, and hence the persistence data was still there. You never really deleted the add-on, and hence the files were still there.
            • alowhumA
              alowhumA
              alowhum
              #26
              Version 0.0.7 has been created, and should hopefully be accepted soon.
              It fixes the issue that the user's preference for which capability should be shown centrally was reset every time the add-on restarted.
              Internally, the add-on always uses persistence. Whether devices are shown as 'connected' is now an option. You can either immediately show all MySensors nodes as 'connected' upon a restart, or wait until nodes have sent a signal.
              // It has been accepted
              • alowhumA
                alowhumA
                alowhum
                Version 0.1.0 has been accepted. Persistence is a bit faster and hopefully more robust. Hopefully it fixes an issue @rmalbers was experiencing.
                • alowhumA
                  alowhumA
                  alowhum
                  Version 0.1.2 has been uploaded. It has a lot of new features:
                  • Automatic serial port searching. User doesn't need to add a serial port ID manually anymore (but can if they want)
                  • Support for metric/imperial units. You can set your preference in the add-on settings.
                  • Support for multipleOf. This should help show a sane amount of decimals on numeric variables.
                  • Experimental MQTT support based on user feedback.
                  • Anticipates switch to version 0.9 of the WebThings gateway by implementing title support.
                  • alowhumA
                    alowhumA
                    alowhum
                    The new version has been accepted.
                    • alowhumA
                      alowhumA
                      alowhum
                      #30
                      I have uploaded a new version (0.1.4) that should hopefully be accepted in the coming days.
                      It allows MySensors devices to better work with voice control.
                      Its main new ability is that it can split up a single MySensors device into several. The reason this is important is that in the webthings gateway you currently cannot change property names, only thing names. By essentially creating many things with only one property, this problem is circumvented.
                      It also has some small improvements in MySensors V-types support.
                      • alowhumA alowhum
                        Nca78N
                        Nca78N
                        Thanks you @alowhum, is the splitting systematic or done in settings/configured ?
                        • Nca78N Nca78
                          alowhumA
                          alowhumA
                          alowhum
                          @nca78 It's a setting, it's optional.
                          • alowhumA
                            alowhumA
                            alowhum
                            Version 0.1.4 has now been accepted.
                            • alowhumA
                              alowhumA
                              alowhum
                              Version 1.0.0 has been submitted to Mozilla.
                              • Support for time-outs. After a user-defined period of not receiving any sign of life (data/heartbeat), a node will be set to disconnected.
                              • Support for the new WebThings thermostat capability.
                              • alowhumA
                                alowhumA
                                alowhum
                                It has been accepted.
                                • Nca78N
                                  Nca78N
                                  Thank you !
                                  R 1 Reply Last reply
                                  • Nca78N Nca78
                                    Thank you !
                                    R
                                    R
                                    rmalbers
                                    Thanks, I have the timeout set (to 30 minutes) and it seems to be working, GREAT! In other news, it looks like they added metric to the gateway with the new release last night and all my temp readings reverted to 'Cent', the new default, until I switched it off 'metric', scared me for a second!
                                    • R rmalbers
                                      alowhumA
                                      alowhumA
                                      alowhum
                                      #38
                                      @rmalbers Thanks for suggesting the idea.
                                      @rmalbers said in Mozilla Webthings MySensors add-on / adapter:
                                      Yeah I have to figure out how the add-on can get this value from the gateway instead.
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        A bit of a side-note, but I've created a theme (the very first one!). It also adds thermostat setpoint buttons.
                                        • badmannenB
                                          badmannenB
                                          badmannen
                                          I been searching around in the forum but I cannot find a way how to send the Battery % so the WEBTHINGS will recognize it , can anyone give me a hint?
                                          at the moment I report it in from my battery node with:
                                          but I assume this does not get forwarded to the controller?
                                          so should I send it as a separate "child node ID , message?
                                          and which one would be most clever?
                                          thank you
                                          rPi 3 - UNO R3 - Mini - Nano - custom
