  3. Mozilla WebThings Gateway
  4. Mozilla Webthings MySensors add-on / adapter
Scheduled Pinned Locked Moved Mozilla WebThings Gateway
55 Posts 5 Posters 12.5k Views 8 Watching
  • Nca78N
    So connected with SSH and the directory is gone now.
    I reinstalled the add-on and I didn't have those messages about files already existing, only success messages.
    But I don't get why it still has my configuration for MySensors gateway URL etc. I install the add-on and after install it connects directly to the MySensors gateway.
    I don't know what happened also but it seems I had a problem with the gateway too as I didn't have sensor info in it's log. Now I reprogrammed it and I see log when sensor sends and I have the sensor in the add sensor view.
    No idea of what happened, but it seems problem was with my own sensors/gateway and not the add-on :)
    • alowhumA
      alowhumA
      alowhum
      @Nca78 Glad to hear it.
      I suspect that because part of the gateway had crashed, all the things you thought you did never actually happened. You never really deleted the thing, and hence the persistence data was still there. You never really deleted the add-on, and hence the files were still there.
      • alowhumA
        alowhumA
        alowhum
        #26
        Version 0.0.7 has been created, and should hopefully be accepted soon.
        It fixes the issue that the user's preference for which capability should be shown centrally was reset every time the add-on restarted.
        Internally, the add-on always uses persistence. Whether devices are shown as 'connected' is now an option. You can either immediately show all MySensors nodes as 'connected' upon a restart, or wait until nodes have sent a signal.
        // It has been accepted
        • alowhumA
          alowhumA
          alowhum
          Version 0.1.0 has been accepted. Persistence is a bit faster and hopefully more robust. Hopefully it fixes an issue @rmalbers was experiencing.
          • alowhumA
            alowhumA
            alowhum
            Version 0.1.2 has been uploaded. It has a lot of new features:
            • Automatic serial port searching. User doesn't need to add a serial port ID manually anymore (but can if they want)
            • Support for metric/imperial units. You can set your preference in the add-on settings.
            • Support for multipleOf. This should help show a sane amount of decimals on numeric variables.
            • Experimental MQTT support based on user feedback.
            • Anticipates switch to version 0.9 of the WebThings gateway by implementing title support.
            • alowhumA
              alowhumA
              alowhum
              The new version has been accepted.
              • alowhumA
                alowhumA
                alowhum
                #30
                I have uploaded a new version (0.1.4) that should hopefully be accepted in the coming days.
                It allows MySensors devices to better work with voice control.
                Its main new ability is that it can split up a single MySensors device into several. The reason this is important is that in the webthings gateway you currently cannot change property names, only thing names. By essentially creating many things with only one property, this problem is circumvented.
                It also has some small improvements in MySensors V-types support.
                Nca78N 1 Reply Last reply
                • alowhumA alowhum
                  Thanks you @alowhum, is the splitting systematic or done in settings/configured ?
                  alowhumA 1 Reply Last reply
                  • Nca78N Nca78
                    alowhumA
                    alowhumA
                    alowhum
                    @nca78 It's a setting, it's optional.
                    • alowhumA
                      alowhumA
                      alowhum
                      Version 0.1.4 has now been accepted.
                      • alowhumA
                        alowhumA
                        alowhum
                        Version 1.0.0 has been submitted to Mozilla.
                        • Support for time-outs. After a user-defined period of not receiving any sign of life (data/heartbeat), a node will be set to disconnected.
                        • Support for the new WebThings thermostat capability.
                        • alowhumA
                          alowhumA
                          alowhum
                          It has been accepted.
                          • Nca78N
                            Thank you !
                            R 1 Reply Last reply
                            • Nca78N Nca78
                              Thank you !
                              R
                              R
                              rmalbers
                              Thanks, I have the timeout set (to 30 minutes) and it seems to be working, GREAT! In other news, it looks like they added metric to the gateway with the new release last night and all my temp readings reverted to 'Cent', the new default, until I switched it off 'metric', scared me for a second!
                              • R rmalbers
                                alowhumA
                                alowhumA
                                alowhum
                                #38
                                @rmalbers Thanks for suggesting the idea.
                                @rmalbers said in Mozilla Webthings MySensors add-on / adapter:
                                Yeah I have to figure out how the add-on can get this value from the gateway instead.
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  A bit of a side-note, but I've created a theme (the very first one!). It also adds thermostat setpoint buttons.
                                  • badmannenB
                                    badmannenB
                                    badmannen
                                    I been searching around in the forum but I cannot find a way how to send the Battery % so the WEBTHINGS will recognize it , can anyone give me a hint?
                                    at the moment I report it in from my battery node with:
                                    but I assume this does not get forwarded to the controller?
                                    so should I send it as a separate "child node ID , message?
                                    and which one would be most clever?
                                    thank you
                                    rPi 3 - UNO R3 - Mini - Nano - custom
                                    • badmannenB badmannen
                                      thank you
                                      @badmannen said in Mozilla Webthings MySensors add-on / adapter:
                                      This is what I do at the moment
                                      badmannenB 1 Reply Last reply
                                      • Nca78N Nca78
                                        badmannenB
                                        badmannenB
                                        badmannen
                                        @nca78 Do you send it as a "DIMMER" to send the percentage?
                                          @badmannen not even, was working with the humidity percentage so I kept the same for the battery :)
                                          MyMessage batPercentMsg(CHILD_ID_BATTERY, V_HUM);
