  3. Mozilla WebThings Gateway
  4. Mozilla Webthings MySensors add-on / adapter
Scheduled Pinned Locked Moved Mozilla WebThings Gateway
55 Posts 5 Posters 13.2k Views 8 Watching
  • alowhumA
    alowhumA
    alowhum
    Version 0.1.2 has been uploaded. It has a lot of new features:
    • Automatic serial port searching. User doesn't need to add a serial port ID manually anymore (but can if they want)
    • Support for metric/imperial units. You can set your preference in the add-on settings.
    • Support for multipleOf. This should help show a sane amount of decimals on numeric variables.
    • Experimental MQTT support based on user feedback.
    • Anticipates switch to version 0.9 of the WebThings gateway by implementing title support.
    • alowhumA
      alowhumA
      alowhum
      The new version has been accepted.
      • alowhumA
        alowhumA
        alowhum
        #30
        I have uploaded a new version (0.1.4) that should hopefully be accepted in the coming days.
        It allows MySensors devices to better work with voice control.
        Its main new ability is that it can split up a single MySensors device into several. The reason this is important is that in the webthings gateway you currently cannot change property names, only thing names. By essentially creating many things with only one property, this problem is circumvented.
        It also has some small improvements in MySensors V-types support.
        Nca78N 1 Reply Last reply
        • alowhumA alowhum
          Thanks you @alowhum, is the splitting systematic or done in settings/configured ?
          alowhumA 1 Reply Last reply
          • Nca78N Nca78
            alowhumA
            alowhumA
            alowhum
            @nca78 It's a setting, it's optional.
            • alowhumA
              alowhumA
              alowhum
              Version 0.1.4 has now been accepted.
              • alowhumA
                alowhumA
                alowhum
                Version 1.0.0 has been submitted to Mozilla.
                • Support for time-outs. After a user-defined period of not receiving any sign of life (data/heartbeat), a node will be set to disconnected.
                • Support for the new WebThings thermostat capability.
                • alowhumA
                  alowhumA
                  alowhum
                  It has been accepted.
                  • Nca78N
                    Thank you !
                    R 1 Reply Last reply
                    • Nca78N Nca78
                      Thank you !
                      R
                      R
                      rmalbers
                      Thanks, I have the timeout set (to 30 minutes) and it seems to be working, GREAT! In other news, it looks like they added metric to the gateway with the new release last night and all my temp readings reverted to 'Cent', the new default, until I switched it off 'metric', scared me for a second!
                      • R rmalbers
                        alowhumA
                        alowhumA
                        alowhum
                        #38
                        @rmalbers Thanks for suggesting the idea.
                        @rmalbers said in Mozilla Webthings MySensors add-on / adapter:
                        Yeah I have to figure out how the add-on can get this value from the gateway instead.
                        • alowhumA
                          alowhumA
                          alowhum
                          A bit of a side-note, but I've created a theme (the very first one!). It also adds thermostat setpoint buttons.
                          • badmannenB
                            badmannenB
                            badmannen
                            I been searching around in the forum but I cannot find a way how to send the Battery % so the WEBTHINGS will recognize it , can anyone give me a hint?
                            at the moment I report it in from my battery node with:
                            but I assume this does not get forwarded to the controller?
                            so should I send it as a separate "child node ID , message?
                            and which one would be most clever?
                            thank you
                            rPi 3 - UNO R3 - Mini - Nano - custom
                            • badmannenB badmannen
                              thank you
                              @badmannen said in Mozilla Webthings MySensors add-on / adapter:
                              This is what I do at the moment
                              badmannenB 1 Reply Last reply
                              • Nca78N Nca78
                                badmannenB
                                badmannenB
                                badmannen
                                @nca78 Do you send it as a "DIMMER" to send the percentage?
                                  @badmannen not even, was working with the humidity percentage so I kept the same for the battery :)
                                  MyMessage batPercentMsg(CHILD_ID_BATTERY, V_HUM);
                                  • Nca78N Nca78
                                    badmannenB
                                    badmannenB
                                    badmannen
                                    @nca78 aaa ok . perfect . Now I try with dimmer and I will see if it appears like I want otherwise I´ll try your way . thanks !
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      #45
                                      Interesting. I'll see if there's an 'official' way to implement battery level.
                                      // Asked a question on how to implement it.
                                      • alowhumA alowhum
                                        badmannenB
                                        badmannenB
                                        badmannen
                                        @alowhum did it your way and it works like a charm. 🤘👍🏻
                                        • badmannenB
                                          badmannenB
                                          badmannen
                                          I just wish Mozilla could introduce some more settings in their web interface. Just to edit nodes and bring back nodes that you deleted etc, in an easy way. The easy interface is pretty and all but it would be useful with some more settings options etc
