  3. ds18b20 on 2xAAA battery
34 Posts 10 Posters 6.5k Views 8 Watching
  • pihomeP pihome
    i must admit you are lucky or your sensors dont care about voltage but at this stage after reading your comments i have tried 3 different sensors and all the same result
    may be something is in my sketch ?
    //  _____    _   _    _
    // |  __ \  (_) | |  | |
    // | |__) |  _  | |__| |   ___    _ __ ___     ___
    // |  ___/  | | |  __  |  / _ \  | |_  \_ \   / _ \
    // | |      | | | |  | | | (_) | | | | | | | |  __/
    // |_|      |_| |_|  |_|  \___/  |_| |_| |_|  \___|
    //    S M A R T   H E A T I N G   C O N T R O L
    // *       Battery Powered OneWire DS18B20 Temperature Sensor      *
    // *           Version 0.31 Build Date 06/11/2017                  *
    // *            Last Modification Date 09/05/2019                  *
    // *                                          Have Fun - PiHome.eu *
    //#define MY_DEBUG
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // #define MY_RF24_PA_LEVEL RF24_PA_LOW
    // RF24_PA_MIN RF24_PA_LOW RF24_PA_HIGH RF24_PA_MAX RF24_PA_ERROR
    #define MY_RF24_PA_LEVEL RF24_PA_MIN
    //#define MY_DEBUG_VERBOSE_RF24
    // RF channel for the sensor net, 0-127 Default is 76
    #define MY_RF24_CHANNEL	76
    //PiHome - Make Sure you change Node ID, for each temperature sensor. 21 for Ground Floor, 20 for First Floor, 30 for Domastic Hot Water.
    #define MY_NODE_ID 33
    //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
    #define RF24_DATARATE 	   RF24_250KBPS
    // Set baud rate to same as optibot
    //#define MY_BAUD_RATE 9600
    //set how long to wait for transport ready in milliseconds
    //#define MY_TRANSPORT_WAIT_READY_MS 3000
    //#include <SPI.h>
    #include <OneWire.h>
    #define ledpin 4 // LED for one Blink Power On, Solid LED for No sensors, 5 Blinks for no Radio (this settings is in MySensors.cpp) and three blinks for low battery
    // Define sensor node childs
    #define CHILD_ID_BATT 1
    #define CHILD_ID_TEMP 0
    #define COMPARE_BVOLT 1 // Send battery voltage only if changed? 1 = Yes 0 = No
    #define MAX_ATTACHED_DS18B20 2
    unsigned long SLEEP_TIME = 56000; // Sleep time between reads (in milliseconds)
    // Battery related init
    float oldBatteryV = 0;
    MyMessage msgBatt(CHILD_ID_BATT, V_VOLTAGE);
    // Dallas Temperature related init
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(CHILD_ID_TEMP, V_TEMP);
    void before(){
      sensors.begin();
    void setup(){
    	//This is LED pin set to output and turn it on for short while
    	pinMode(ledpin, OUTPUT);
    	digitalWrite(ledpin, HIGH);
    	delay(60);
    	digitalWrite(ledpin, LOW);
      // needed for battery soc
          analogReference(INTERNAL1V1);
      #else
          analogReference(INTERNAL);
        // disable ADC
      //ADCSRA = 0;
      //power_usart0_disable();// Serial (USART)
      //power_adc_disable(); // ADC converter
      //power_twi_enable(); // TWI (I2C)
    void presentation() {
    	sendSketchInfo("Temperature Sensor", "0.31");
    	//Blink LED as number of sensors attached
    	blink_led(numSensors, ledpin);
    	//check if attached sensors number is grater then 0 if no then put led on solid
    	#if numSensors > 0
    	#else
         present(i, S_TEMP);
    void loop(){
    	// get the battery Voltage
    	//ref http://www.ohmslawcalculator.com/voltage-divider-calculator
    	// 1M, 100K divider across battery and using internal ADC ref of 1.1V
    	// ((1e6+100e3)/100e3)*1.1 = Vmax = 12.1 Volts
    	// 12.1/1023 = Volts per bit = 0.011828
    	//R1 820k, R2 220k
    	//((820e3+220e3)/220e3)*1.1 = Vmax = 5.2 Volts
    	//5.2/1023 = Volts per bit = 0.005083089
    	int battSensorValue = analogRead(BATTERY_SENSE_PIN);
    	//float batteryV  = battSensorValue * 0.005083089; //R1 820k, R2 220k divider across battery and using internal ADC ref of 1.1v
    	float batteryV  = battSensorValue * 0.011828;    //R1 1M, R2 100K divider across battery and using internal ADC ref of 1.1v
    	//int batteryPcnt = ( ( batteryV - 2.9 ) / ( ( 4.2 - 2.9 ) / 100 ) ); // for 18650 Battery Powred
    	int batteryPcnt = ( ( batteryV - 2.1 ) / ( ( 3.0 - 2.1 ) / 100 ) ); // for AAA Battery Powered
    	#ifdef MY_DEBUG
    		Serial.print("Pin Reading: ");
    		Serial.println(battSensorValue);
    		Serial.print(batteryV);
    		Serial.println(" v");
    		//Print Battery Percentage
    		Serial.print(batteryPcnt);
    		Serial.println(" %");
    	#if COMPARE_BVOLT == 1
    		if (oldBatteryV != batteryV) {
    			send(msgBatt.set(batteryV, 2));
    			oldBatteryV = batteryV;
    	#else
    	//sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater)
    	sleep(conversionTime);
    		float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
    		#if COMPARE_TEMP == 1
    		#else
    			send(msg.setSensor(i).set(temperature,1));
    		//Condition to check battery levell is lower then minimum then blink led 3 times
    		//if (batteryV < 2.9) { //for 18650 Battery Powered Sensor
    		if (batteryV < 2.0) { //for AAA Battery Powered Sensor
    			blink_led(3, ledpin);
    			//Serial.print("Low Voltage");
    	//go to sleep for while
    	//smartSleep(SLEEP_TIME);
    	sleep(SLEEP_TIME);
    //Blink LED function, pass ping number and number of blinks usage: blink_led(variable or number of time blink, ledpin);
    void blink_led(int count, int pin){
    	for(int i=0;i<count;i++){
    		digitalWrite(pin, HIGH);
    		delay(700);
    		digitalWrite(pin, LOW);
    		delay(700);
    zboblamontZ Offline
    zboblamontZ Offline
    zboblamont
    wrote on last edited by zboblamont
    #21
    @pihome Not sure why you are looking for a sketch problem if the issues don't arise >=3v?
    That some folks have ds18b20 working below the specified minimum of 3v is pure luck, but even were you to source devices which could work down to say 2.8v, it still does not address their certain disfunction below it, particularly down to the 1.9v drop off voltage of your radio, which was your objective?
    Your options are limited to swapping to a sensor (?) which works down to 1.9v, switch on/off a separate supply for the ds18b20, or run a full-time booster for the entire assembly to suck all life from your batteries. It is this latter scenario here, but designed and built by folks clever than I.
    Very tempted after this to look at switching on/off the ds18b20 array's power and see how long it lasts on batteries aloe, perhaps a rainy day or winter project.
    • pihomeP Offline
      pihomeP Offline
      pihome
      @zboblamont,
      yes you are right it is pure luck, i just wanted to check i m not doing anything stupid and said pair of eyes are always good. i have ordered the parts and i m going to work on two version: one with boost convert for sensor and second 3xAAA with voltage regulator and probably 3rd version (may be in future when i get some free time) with boost converter with shutdown, may be some one already have done this and my search string isnt very good to dig that out.
      PiHome - Smart Heating Control
      • pihomeP Offline
        pihomeP Offline
        pihome
        further update:
        while playing with 1mhz bootloader and feeding arduino to raw pin from 18650 battery, sensors is successfully sending battery voltage and battery percentage but no temperature sensor reading. to prove that something isnt right with 1mhz bootloader i burned 8mhz default bootloader i get battery voltage, battery percentage and temperature reading. can not think of something obvious :(
        Link to 1mhz bootloader
        • pihomeP pihome
          further update:
          zboblamontZ Offline
          zboblamontZ Offline
          zboblamont
          @pihome No expert, but recall these one-wire devices have a digital communications protocol. As such they rely on accurate timing, hence your clock speed disrupts it?
          • zboblamontZ zboblamont
            #25
            @zboblamont might be on the right track. See https://github.com/arduino/Arduino/issues/7181 for a discussion on timing problems, especially at 1MHz
            • pihomeP Offline
              pihomeP Offline
              pihome
              Life is never easy and definitely not straight, there is always something wrong :( perhaps back to educating myself...
              • B Offline
                B Offline
                bjacobse
                It appears that you during runtime can change prescale, so you should be able to change clock frequency to 8MHz when reading DS18B20 and after reading change clock back to 1MHz
                https://forum.arduino.cc/index.php?topic=223771.0
                • pihomeP Offline
                  pihomeP Offline
                  pihome
                  @bjacobse
                  reason behind 1mhz mcu is to run it on lower voltage but switching between speed still need higher voltage. if i m not wrong!!!
                  mfalkviddM B 2 Replies Last reply
                  • pihomeP pihome
                    @bjacobse
                    @pihome yes that’s correct
                    • pihomeP pihome
                      @bjacobse
                      B Offline
                      B Offline
                      bjacobse
                      wrote on last edited by bjacobse
                      #30
                      @pihome yes nothing is free;-)
                      • B Offline
                        B Offline
                        bjacobse
                        #31
                        Well then another approach is not to use DS18B20 :-)
                        Have you checked TMP117 price seems to be 2USD in higher qty, and supply range: 1.8 V to 5.5 V
                        http://www.ti.com/product/TMP117
                        https://www.digikey.com/products/en/sensors-transducers/temperature-sensors-analog-and-digital-output/518?FV=ffe00206&quantity=0&ColumnSort=1000011&page=1&k=TMP117&pageSize=25
                        And someone have made a lib to Arduino: https://github.com/NilsMinor/TMP117-Arduino
                        • A Offline
                          A Offline
                          avelo
                          Hi, I'm on a somehow "comparable" (but very different scenario) project in terms of using same DS18B20 and arduino 3.3V, a mkr SAMD21 in my case, and trying to get the longer autonomy I can.
                          The best option I've seen so far seems to be to use the (best option) TPS61291 or (alternate option) TPS61221, as the first seems to be designed for this use cases, and the second has enable option to switch it off. All those seemed to me (newbie here) better than the TPS you indicate.
                          For my use case, the "low tech" option indicated by @mfalkvidd could fit very nicely, so I'll dig into that option.
                          • pihomeP Offline
                            pihomeP Offline
                            pihome
                            @avelo
                            thank you for suggestion, i have made prototype based on MIC5219-3.3
                            but sure TPS61291 / TPS61221 are good options. once i get pcb delivered i'll you know here.
                            • T Offline
                              T Offline
                              tbowmo
                              #34
                              just for reference, 4 out of 5 sensebender micros is still running strong, after 4 years on the same set of AA batteries, that they where deployed with.
                              The 5th sensebender is my outdoor sensor, that one eats a set of batteries within 48 hours.. But i suspect that it's the air humidity that has destroyed it.
                              I opted to use a Si7021 instead (there might be others that are better suited now), as it was better suited for low power operation, and runs down to 1.2V supply (if I remember right).
