  3. MY_RF24_IRQ_PIN on ESP8266 GW
9 Posts 4 Posters 1.7k Views 2 Watching
  • Sergio RiusS
    Sergio RiusS
    Sergio Rius
    Hi guys, I just updated a gateway to the latest version and I also activated IRQ for the radio.
    I wired the irq to the pin marked D4 on the NodeMcu v1 and set: #define MY_RF24_IRQ_PIN (2)
    Due to the weird mapping on this board I don't know if its correctly wired. The gw seems to work.
    Do you guys knows how to know if the feature is correctly working? Thanks.
    • Sergio RiusS Sergio Rius
      @sergio-rius if the gateway can send and receive messages, the irq is working.
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @mfalkvidd said in MY_RF24_IRQ_PIN on ESP8266 GW:
        MY_RF24_IRQ_PIN is currently only used for the RX_QUEUE_BUFFER feature, and unfortunately, ESP8266 does not support interrupt usage for SPI. See comments here: https://github.com/mysensors/MySensors/blob/development/hal/transport/RF24/driver/RF24.cpp#L525
        • Sergio RiusS
          Sergio RiusS
          Sergio Rius
          So there's so limited functionality on esp. I think you can guess where I was going.
          So I thought it could be some trouble because I saw some strange behavior, sometimes the start stuck, and keep flashing the led. I saw that d4 controls the inboard led, but as the gw worked after a reset and was so late I left for the day.
          I may swap that pin, but I don't know what is available and it's internal number.
          YveauxY 1 Reply Last reply
            YveauxY
            YveauxY
            @sergio-rius I'm surprised it even compiles for esp8266, see my posts in https://github.com/mysensors/MySensors/issues/1128
            Could be that the arduino port for esp8266 had evolved, but that requires a deeper look.
            • YveauxY Yveaux
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              @yveaux Defining MY_RF24_IRQ_PIN does not enable the RX queue feature per se. Therefore it compiles ;)
              Sergio RiusS YveauxY 2 Replies Last reply
              • tekkaT tekka
                Sergio RiusS
                Sergio RiusS
                Sergio Rius
                @mfalkvidd yes, I saw those posts. And there are changes in both the esp firmware and the Arduino core. I had to re-implement the ArduinoOta, for example. And it still doesn't work. But compiles.
                @tekka said in MY_RF24_IRQ_PIN on ESP8266 GW:
                That's the impression I had, that hadn't any effect. That was the reason I asked. Does actually have any functionality on esp?
                • tekkaT tekka
                  YveauxY
                  YveauxY
                  True, and next it doesn't use it? ;-)
                  Sergio RiusS 1 Reply Last reply
                  • YveauxY Yveaux
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    @yveaux said in MY_RF24_IRQ_PIN on ESP8266 GW:
                    This could be reformulated as an affirmative sentence.
                    I cut the bridge wiring and continued working as nothing happened.
