  3. ESP8266 Gateway with AP mode instead of hardcoded ssid etc
7 Posts 5 Posters 1.2k Views 6 Watching
  • UweKU
    UweKU
    UweK
    Hi
    I want to change the ESP8266 gateway exampel in a way that i can use AP mode to configure the gateway on the fly instead of hardcoding SSID and PW in teh code.
    But: How can i stop the gateway starting when no WIFI SSID is set to start AP mode?
    I haven't understood the start phase completely.
    Uwe
    UweKU 1 Reply Last reply
    • UweKU UweK
      Hi
      Uwe
      UweKU
      UweKU
      UweK
      @uwek
      It seems as the library only supports the defined DEFINE Variable
      (void)WiFi.begin(**MY_WIFI_SSID**, MY_WIFI_PASSWORD, 0, MY_WIFI_BSSID);
      Has anlyone an idea how to add some flexibility?
      Uwe
      • camadortC
        camadortC
        camadort
        This is how I did it
         * Version 1.0 - Henrik EKblad
         * Contribution by Ivo Pullens (ESP8266 support)
         * The EthernetGateway sends data received from sensors to the WiFi link.
         * VERA CONFIGURATION:
         * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
         * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
         * LED purposes:
         * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
          * Inclusion mode button:
        #define MY_BAUD_RATE 9600
        #define MY_RADIO_RF24
        //#define MY_RF24_CHANNEL 100
        #define MY_RF24_PA_LEVEL  RF24_PA_LOW    //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
        #define MY_GATEWAY_ESP8266
        // Enable UDP communication
        //#define MY_USE_UDP
        //#define MY_ESP8266_HOSTNAME "mysensors-gateway"
        //#define MY_IP_ADDRESS 192,168,1,69
        #define MY_IP_GATEWAY_ADDRESS 192,168,1,254
        #define MY_PORT 5003
        // Enable inclusion mode
        // #define MY_INCLUSION_BUTTON_FEATURE
        //#define MY_INCLUSION_MODE_BUTTON_PIN  16
        // Set blinking period
        // Flash leds on rx/tx/err
        // Led pins used if blinking feature is enabled above
        #define MY_DEFAULT_ERR_LED_PIN 5  // Error led pin
        #define MY_DEFAULT_TX_LED_PIN  2  // the PCB, on board LED
        #if defined(MY_USE_UDP)
        #include <WiFiUdp.h>
        #include <ESP8266WiFi.h>
        #include <DNSServer.h>
        #include <ESP8266WebServer.h>
        #include <WiFiManager.h>         //https://github.com/tzapu/WiFiManager
             //WiFiManager
            //Reset WiFi with push button on GPIO16.
            WiFiManager wifiManager;
            bool oldValue = digitalRead(16);
            if (oldValue == 0) {
              wifiManager.resetSettings();
            //fetches ssid and pass from eeprom and tries to connect
            //if it does not connect it starts an access point with the specified name
            //here  "MySensorsAP"
            //and goes into a blocking loop awaiting configuration
            wifiManager.autoConnect("MySensorsAP");
            //if you get here you have connected to the WiFi
            Serial.println("connected... :)");
        • UweKU
          UweKU
          UweK
          ough!!
          Cool, Soo easy, tststs...
          Thanks a lot...
          • S
            shajek
            but that is solution for non-MQTT GW, if you have ESP8266 with MQTT you still get
            Documents/Arduino/libraries/MySensors/core/MyGatewayTransportMQTTClient.cpp:257:33: error: 'MY_WIFI_PASSWORD' was not declared in this scope
              (void)WiFi.begin(MY_WIFI_SSID, MY_WIFI_PASSWORD, 0, MY_WIFI_BSSID);
            any solution for this ?
            thank you
            • K
              K
              kimot
              But if you move ( or sold ) your gateway to different network, what seems as reason for selecting SSID and password,
              you still need recompile your code due to different IP of your controller.
              • Z
                Z
                zarat
                Banned
                wrote on last edited by zarat
                This post is deleted!
