  3. My experiences with MySensors
32 Posts 13 Posters 6.4k Views 9 Watching
  • Felix HaverkampF
    Felix HaverkampF
    Felix Haverkamp
    Hello Community,
    currently i removed all MySensors devices. I am very sad about this. But i couldn't establish a reliable connection to the gateway and the sensors.
    I was very frustrated about the preferred radio "NRF24L01+". I read every article about this sensor and how to improve range and connection.
    Didn't get any good results with this radio. I also read that this kind of radios have a very bad range and only work within 2-3 meters.
    So i can't understand why these radios are the preferred radios for mysensors, this makes this project really unrealiable.
    Currently, i switched to Zigbee devices from Aqara with a Conbee USB Stick from dresden electronics.
    The Aqara Sensors and button devices fulfill all my requirements and have a very good connection and the battery usage of the devices is awesome.
    Bought some of the sensors 16 month ago, and have a battery level of 80/90 % !!!
    All other Zigbee devices like bulbs and LED-Stripes works to with conbee. As the central gateway i use pimatic (pimatic.org)
    But if you need custom sensors and actors for a Maker Project MySensors is a good thing, but if you new to this project, i advise you to use any other communication method than NRF24L01+. This radios are total crap.
    sincerely,
    Felix
    TheoLT 1 Reply Last reply
    • Felix HaverkampF Felix Haverkamp
      Hello Community,
      sincerely,
      Felix
      TheoLT
      TheoLT
      TheoL
      @felix-haverkamp I'm sorry to hear that Felix. In my own experience MySensors works fine with the NRF24L01+ sensors. I have full range throughout my entire house. For my it wasn't a frustrating experience. I followed the instructions and it worked in most cases directly. Good to hear that you have found something that suits your needs.
        mickecarlsson
        Be aware that most of the cheap NRF boards from China are counterfeit. If you have those in an environment with a lot of WiFi you won’t get any range at all. And all “modifications” to improve range posted on YouTube are not any improvement.
        You need to buy real NRF modules with external antenna.
        Just my two cents.
        • R
          R
          rodaman
          You are right. Mysensors based on NRF is dead. I started my adventure with home automation based on mysensors but gradually I replaced all my sensor with Wemos. Now everything work fine. Sorry mysensors...
          M B 2 Replies Last reply
          • R rodaman
            mickecarlsson
            @rodaman if you have bought real NRF modules you have been satisfied.
            Or if you have bought RFM 433, 833 or 915 MHz radios you had been more that pleased.
            Not MySensors fault.
            • tbowmoT
              tbowmoT
              tbowmo
              As others say, cheap clones of the nrf24 is probably the issue here..
              I'm using mysensors with nrf24 throughout the house. Some sensors have been in operation for more than 4 years now, with the same set of 2xAA batteries! And they are still happily reporting temperature / humidity. I admit, that I do not have many sensors around, as I only have 15 or so units deployed (mix of both sensor-only and actuators)
              • R rodaman
                B
                B
                boozz
                @rodaman
                Although fully agree with @mickecarlsson and @tbowmo (I have been lucky with really cheap nrf24L01+ modules I think) and have a similar experience as @TheoL (MySensors works fine with nr24L01+ modules) I can state that mySensors is very much alive.
                However, I'm interested in your Wemos setup.
                I've got some questions from which I'm sure you can give me the right quidance:
                I guess it used some bandwith in your Wifi network? can I use it similar as mySensors topology or even with mySensors libraries?
                Can it be used with batteries (sleep modes and so on) for a long time?
                thank you in advance for your values answers,
                BR, Boozz
                B 1 Reply Last reply
                • Sergio RiusS
                  Sergio RiusS
                  Sergio Rius
                  wrote on last edited by Sergio Rius
                  Well, unfortunately I cannot agree with the stories of success.
                  It's ok that a tool works for someone, but it can't be so weak that things like radio clones, track shapes or cap variations renders something unusable. And still did not mention interference or houses construction materials. All things that should be tested. WiFi/mobile interference should not be a problem, everyone has em.
                  Just only think that if Chinese manufacturers are making these clones in that volumes, and they are sold, it's because they took a look at the original and made a product profile with what specs are acceptable for the expected application and clones are the result. I mean that perhaps mysensors expected to much from them.
                  I guess everyone already knows that I only had problems trying to use mysensors, and now I have a defeating gw problem while using original radios all around. I have nrf52s in the box for testing but I'm so defeated, that I have no strength to try them.
                  I've ordered parts for making a good ole rj45 gw, but I'm already working in a custom base sketch for moving to esp+mqtt.
                  My influx data is full of "holes"
                  Now I'm thinking in the fact that my gw started to make this more or less after the installation of a Google home and a echo Dot, for testing. It already seems paranoia.
                  scalzS P 2 Replies Last reply
                  • Sergio RiusS Sergio Rius
                    scalzS
                    scalzS
                    wrote on last edited by scalz
                    Just my "little" two cents on this because I don't think it's MySensors fault only..afaik MySensors started with rf24, but got compatible with better radios years ago!
                    when you learn RF and electronics you'll discover what's the purpose of decoupling and buffering power. Same about the shape of the board, gnd plane size, enclosure, parts close to antenna et, will affect antenna frequency like shifting it, and decrease sensitivity (noise).
                    Manufacturers of end device passes certification to prove their device are RF "green" and calibrated. Even when you change the external antenna on a device, and don't buy the same original one, you may lose CE/FCC, because there are chance it detuned a bit RF, more or less.
                    These are things that a beginner would not imagine when picking a rf module, arduino, some dupont cables and playing.. So there can be variations in users nodes which can weaken link quality (Pity when the radio is only 0dB max). Far from reference design concept. Not easily coverable by MySensors team.
                    Don't trust me?? Just read, manufacturers datasheet, application notes, check with good RF tools or even watch some youtube videos.
                    those who clones and sell volumes, why do you think they care if people continue to buy because it's cheap. they just simply sell. And when you get a problem, they show you the github from someone else who could help..
                    No sense, not scientific. Coexistence of multiple protocols in one RF band isn't magic. What happens when people in same room all talk at same time, and some louder?? You can catch louder people and rest is just a mess. Sort of jamming, you could even pick esp8266/32 for short range jamming 2.4gz, never tried..but in this, the stronger wins.
                    See this pic, especially for those who would like to use different products on same band..
                    (source: https://www.researchgate.net/figure/Spectra-of-multiple-wireless-technologies-in-the-24-GHz-ISM-band-The-colors-indicate_fig4_326598630)
                    why not adding MySensors protocol in this 2.4ghz recipe?? Just pray that the freq of your node is not shifted/detuned too much.. I hope too you choosed the right freq for your network.
                    • Which protocols is either fixed freq, or freq hoping based??
                    • What if there more or less powerful repeaters for these ?
                    The only way would be to run protocols concurrently (with time slots). Not possible when there are separate gw for each protocols, it just get messy in air, lost packets, etc.
                    Was it like this 10-15 years ago in homes, I don't think so.
                    I hope I don't look old at repeating but finally, I think this problem is mostly about user choices..and I understand it maybe doesn't solve all problems.
                    Sergio RiusS 1 Reply Last reply
                    • scalzS scalz
                      Sergio RiusS
                      Sergio RiusS
                      Sergio Rius
                      @scalz Regarding WiFi I'm not saying that mysensors should overcome the problems of crowded or noisy environments. I'm just saying that if that's the war field, it should have slided to another one.
                      I spent more than 4 years on those problems. I'm physician and software architect/analyst, and my father was ham radio fanatic. Not boasting, only saying that I have a minimum knowledge. I created a nice environment with only one WiFi device, good ubiquity equipment, with nodes without boards or ground planning issues, studying the band and choosing channels and still had nightmares.
                      Yesterday I learned how to easily hang a node by sending a message to it. That shouldn't be possible.
                      I'm not saying that this is crap or that this doesn't worth playing with it. Only think that it needs some love on the low level even if it has to move to slightly powerful devices. Or adding capabilities on powerful architectures while still supporting the good old ino.
                      Perhaps combined with a custom nrf52 development board or something to make easier burn and solder them. Make an nrf52 mysensors starter kit, and convert sensebender to it.
                      Sorry, as you said I don't have the knowledge to make long run boards to contribute with them.
                      • NeverDieN
                        NeverDieN
                        I think the problem is less about the radio and more about the transmit power. Even for official Nordic nRF24l01+ chips, without an external power amplifier, the maximum transmit power is just 0db. For a lot of people, that just won't be enough, which will inevitably lead to disappointment. Compare that to other radios which offer 20dbm tx power, and it's night and day difference in range, coverage, and satisfaction.
                        For beginners who want to use the nRF24L01 design, I humbly suggest that mysensors change its website to guide them to using modules with an external power amplifier and LNA, such as:
                        https://www.aliexpress.com/item/32757594224.html?spm=a2g0o.productlist.0.0.250b696etKb9Ty&algo_pvid=0848ed36-ecf2-4f48-b3f4-37147cbad5dc&algo_expid=0848ed36-ecf2-4f48-b3f4-37147cbad5dc-3&btsid=f941d6b5-6827-4810-b113-797cf378bdfb&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_53
                        or similar. There are also much smaller modules with trace antennas and pa + LNA on them, and even so the cost remains low. If someone doesn't need the full Tx power, they can always scale back.
                        I think a big reason why people like the hoperf rfm69hw modules is simply that they provide 20dbm Tx power. So, you can switch to that or another radio, or you can simply amplify the type you've got. For comparison, an ESP8266 has a maximum 20.5dbm Tx power, which is set as it's default tx power. So, for the guy who moved everything over to wemos, maybe that's why you like it better.
                        Of course, there are differences in receive sensitivity, and that's obviously equally important, and even preferable. And datarate and coding schemes can be other large factors too. Still, if the max Tx power is capped at 0dbm, you're pretty limited in most cases as to your range and coverage and, in my view, a bit crippled for most things other than very short range.
                        • zboblamontZ
                          zboblamontZ
                          zboblamont
                          @neverdie said in My experiences with MySensors:
                          Too simplistic. It is not just about power but also the behaviour of different frequencies and how noisy the RF band is. 2.4GHz is not noisy for some but is for others, add in fakes and you have a nightmare. Your suggestion reminds me of a texan ham who used to claim he was turning his LF beam when he was slowly screwing up his linear.. ;)
                          I deliberately went with 433MHz rfm69s because of range and structural penetration, I'm in the sticks so the Wifi band is relatively quiet, no regrets, no fakes (yet), just MySensors doing it's stuff... :)
                          • NeverDieN
                            NeverDieN
                            @zboblamont said in My experiences with MySensors:
                            I think you're missing the point. How many people using, for example, primarily rfm69 are capping the Tx power on all their modules to 0dbm or less? I'd wager the answer is very, very few, if any.
                            • NeverDieN
                              NeverDieN
                              Of course, if it were just for me to decide, I'd recommend all beginners start with LoRa, because if you can't find a way to be happy with the LoRa radio module (which, incidently, can also do everything an rfm69 module can do), you probably can't be happy with anything.
                              Is LoRa even supported by mysensors as yet? It's been a long while since I last checked.
                              tekkaT 1 Reply Last reply
                              • zboblamontZ
                                zboblamontZ
                                zboblamont
                                @neverdie You're not related to my erstwhile Ham contact are you? :joy:
                                I believe you missed the point that it is not purely a power issue, TX/RX is a combo of frequency, noise, and pre-amp/antenna gain, environment, etc, etc..
                                I've no idea what the default setting is for my 433MHz RFM69s, perhaps when I update the system and the nodes I might be able to advise. They are standard devices not the high power version, all using 2dB whips, none have failed to communicate to date. I do have an HW version, it's still in it's antistatic bag...
                                I can track my wifi signal outside the house to about 5m, my Nodes are well beyond that. I could add gain to the wireless router to try matching the performance but the question remains why?
                                NeverDieN 1 Reply Last reply
                                • zboblamontZ zboblamont
                                  NeverDieN
                                  NeverDieN
                                  @zboblamont
                                  The problem is that, assuming FCC compliance, the allowed uses for the 433Mhz band in the USA are pretty limiting for narrowband communications.
                                  • NeverDieN NeverDie
                                    tekkaT
                                    tekkaT
                                    tekka
                                    Yes, we support RFM95 radios and various LoRa settings: https://www.mysensors.org/apidocs-beta/group__RFM95SettingGrpPub.html
                                      @zboblamont
                                      zboblamontZ
                                      zboblamontZ
                                      zboblamont
                                      @neverdie No knowledge of FCC 433MHz restrictions, in the EU it is limited also, from vague memory on %age TX and probably ERP as it is a shared band. But you would need to be pumping a shedload of data for these constraints to take effect, and crucially it suffers none of the frequency crowding issues or penetration constraints of 2.4GHz.
                                        mickecarlsson
                                        wrote on last edited by mickecarlsson
                                        I started out with NRF 2.4 MHz radios for my 8 nodes MySensors and Domoticz. As I also install WiFi networks for customers and have access to our equipment at work I did a measurement at home because I could not get a reliable network.
                                        First measurement revealed that my DECT wireless phone occupied the same channel that was the default for the NRF radios. And that my neighbors run their WiFi occupying all other channels. Equipment used was Ekahau.
                                        I tried to tweak the channels but no avail.
                                        So, I bought new radios, RFM833, and that was the end of my troubles. For two year now my eight nodes have not skipped a beat. I measure temperature, humidity, light (lux), UV and radioactivity.
                                        And all my WiFi at home is at 5GHz as the 2.4 was exhausted.
                                        I have about 40 NRF radios in a box with no use for them.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          Perhaps I should make a 433Mhz transmitter, with a 1kW (60dBm) pa on it (which is the limit of my ham license) ;)
                                          The problem with higher power output on the radio side, also consumes more power from the (battery) supply.. In case of battery operated sensors I'm always aiming for the lowest possible current draw, which is with non-lna devices.
                                          Luckily I live in the country side, so the 2g4 band is not that crowded, and so my nrf24 is good enough. I tried to use rfm69 as well, but never got the range above 50cm, so I ditched those radios again. And yes, I added decoupling capacitors etc. all over the thing..
