  3. rfm69hw on a raspberry pi 4, power issues
2 Posts 1 Posters 322 Views 1 Watching
  • K
    K
    kiesel
    wrote on last edited by kiesel
    I am trying to build a raspberry pi gateway with a rfm69hw chip.
    I built a hat for the pi and the connections seem to be fine, my problem is range.
    I am using the signal scanner sketch and it shows me that the sending node has to max out TXPowerLevel when it talks to the gateway.
    I repurposed one of my other nodes as a gateway and there sending was fine at TXPowerLevel 0, so it must be the gateway.
    I soldered a 470uF capacitor to the radio on the pi and that helps for the first lets say 50 messages, but then the same pattern reappears: The node maxes out its power level.
    Any ideas on how to fix this? I know I could just use a serial gateway, but to be honest I got it into my thick skull that the gateway has to be hat for the pi (mostly because otherwise all that time would have been wasted ;)).
    I have some step up boosters to 3.3v (the ones I use for the nodes), should I try to power the rfm69-chip from one of the boosters?
    K 1 Reply Last reply
    • K kiesel
      K
      K
      kiesel
      So from what I can read here this might not be a power issue after all?
      This is the sketch I am using for the signal scanner:
       * Version 1.0 - tekka
       * ATC mode settings and signal report functions, on RFM69 and RFM95 nodes
      // Enable debug prints
      #define MY_SIGNAL_REPORT_ENABLED
      #define MY_NODE_ID 3
      // RFM69
      #define MY_RADIO_RFM69
      #define MY_RFM69_NEW_DRIVER   // ATC on RFM69 works only with the new driver (not compatible with old=default driver)
      #define MY_IS_RFM69HW
      //#define MY_RFM69_ATC_TARGET_RSSI_DBM (-70)  // target RSSI -70dBm
      //#define MY_RFM69_MAX_POWER_LEVEL_DBM (10)   // max. TX power 10dBm = 10mW
      // RFM95
      //#define MY_RADIO_RFM95
      //#define MY_RFM95_ATC_TARGET_RSSI_DBM (-70)  // target RSSI -70dBm
      //#define MY_RFM95_MAX_POWER_LEVEL_DBM (10)   // max. TX power 10dBm = 10mW
      // ID of the sensor child
      #define CHILD_ID_UPLINK_QUALITY (0)
      #define CHILD_ID_TX_LEVEL       (1)
      #define CHILD_ID_TX_PERCENT     (2)
      #define CHILD_ID_TX_RSSI        (3)
      #define CHILD_ID_RX_RSSI        (4)
      #define CHILD_ID_TX_SNR         (5)
      #define CHILD_ID_RX_SNR         (6)
      // Initialize general message
      MyMessage msgTxRSSI(CHILD_ID_TX_RSSI, V_CUSTOM);
      MyMessage msgRxRSSI(CHILD_ID_RX_RSSI, V_CUSTOM);
      MyMessage msgTxSNR(CHILD_ID_TX_SNR, V_CUSTOM);
      MyMessage msgRxSNR(CHILD_ID_RX_SNR, V_CUSTOM);
      MyMessage msgTxLevel(CHILD_ID_TX_LEVEL, V_CUSTOM);
      MyMessage msgTxPercent(CHILD_ID_TX_PERCENT, V_CUSTOM);
      MyMessage msgUplinkQuality(CHILD_ID_UPLINK_QUALITY, V_CUSTOM);
        // Send the sketch version information to the gateway and controller
        sendSketchInfo("ATC", "1.0");
        present(CHILD_ID_UPLINK_QUALITY, S_CUSTOM, "UPLINK QUALITY RSSI");
        present(CHILD_ID_TX_LEVEL, S_CUSTOM, "TX LEVEL DBM");
        present(CHILD_ID_TX_PERCENT, S_CUSTOM, "TX LEVEL PERCENT");
        present(CHILD_ID_TX_RSSI, S_CUSTOM, "TX RSSI");
        present(CHILD_ID_RX_RSSI, S_CUSTOM, "RX RSSI");
        present(CHILD_ID_TX_SNR, S_CUSTOM, "TX SNR");
        present(CHILD_ID_RX_SNR, S_CUSTOM, "RX SNR");
        // send messages to GW
        send(msgUplinkQuality.set(transportInternalToRSSI(_transportSM.uplinkQualityRSSI)));
        send(msgTxLevel.set(transportGetTxPowerLevel()));
        send(msgTxPercent.set(transportGetTxPowerPercent()));
        // retrieve RSSI / SNR reports from incoming ACK
        send(msgTxRSSI.set(transportGetSendingRSSI()));
        send(msgRxRSSI.set(transportGetReceivingRSSI()));
        send(msgTxSNR.set(transportGetSendingSNR()));
        send(msgRxSNR.set(transportGetReceivingSNR()));
       //to serial
       Serial.print("transportInternalToRSSI(_transportSM.uplinkQualityRSSI): "); Serial.println(transportInternalToRSSI(_transportSM.uplinkQualityRSSI));
       Serial.print("transportGetTxPowerLevel(): "); Serial.println(transportGetTxPowerLevel());
       Serial.print("transportGetTxPowerPercent(): "); Serial.println(transportGetTxPowerPercent());
       Serial.print("transportGetSendingRSSI(): "); Serial.println(transportGetSendingRSSI());
       Serial.print("transportGetReceivingRSSI(): "); Serial.println(transportGetReceivingRSSI());
       Serial.print("transportGetSendingSNR(): "); Serial.println(transportGetSendingSNR());
       Serial.print("transportGetReceivingSNR(): "); Serial.println(transportGetReceivingSNR());
       Serial.println("Waiting");
        // wait a bit
        wait(10000);
      And this is how I compiled the gateway:
      ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-gateway=mqtt --my-is-rfm69hw --extra-cxxflags="-DMY_RFM69_RST_PIN=29" --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mysensorsgateway1 --my-mqtt-user=mysensors --my-mqtt-password=redacted --my-port=1883
      Any ideas how I can test mysensors 2.2 with the raspberry pi 4? From what I understand that version of the pi isn't supported until version 2.4 alpha?
