  3. Drawbacks to using a pro mini as a serial gateway?
6 Posts 2 Posters 841 Views 2 Watching
  • K
    K
    kiesel
    I am planing on using a pro mini as a serial gateway (to connect to my raspberry pi)
    I saw in the serial gateway sketch, that it runs on a lower baud rate when run on a pro mini. Does that mean that messages will appear later on raspberry? Are there other drawbacks?
    And is it correct that I simply connect rx/TX from the pro mini to tx/rx on the pi and that's it? Plus power and gnd, of course.
    electrikE 1 Reply Last reply
    • K kiesel
      electrikE
      electrikE
      electrik
      @kiesel the pro Mini is the same chip as an Arduino nano, so the speed will be the same for both
      K 1 Reply Last reply
      • electrikE electrik
        K
        K
        kiesel
        @electrik
        Thanks. So why the reduced baud rate than? Sorry, this is probably a noob question.
        • electrikE
          electrikE
          electrik
          Maybe the clock frequency is different. So 8mhz instead of 16mhz for the nano.
          But I remember you can still run at the same baud rate.
          I don't think it will make a big difference anyway unless your sending lots of data.
          If the baudrate is 9600, 10 characters will take 10ms to transfer.
            K
            K
            kiesel
            @electrik
            Ah, I see there are Nanos with 8mhz and 16mhz, that's why I thought the baud rate of 34800 was specifically for the pro mini.
            Do you know whether I just have to hook up TX and rx, power and gnd to the pi or whether I need something else? I am having trouble finding a description of how to do it without USB.
            • electrikE
              electrikE
              electrik
              No just the Rx, TX and power should be enough.
