  3. get a string out of a payload
getcustomstringstringgetstring
17 Posts 4 Posters 6.7k Views 1 Watching
    Mickey
    Hi
    I creating a message that holds a string in the payload.
    I also want to get a message like that and using the mymessage.getcustomstring() but cant pass compilation.
    Can I have example for using this method or rather I need to use some other method?
    • BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Mickey
      let's see what you are trying to compile....
        Mickey
        char strMsg[25];
        char *strMsgPtr = strMsg;
        if (message.type==V_VAR1)
        // spit to serial
        Serial.print(message.sensor);
        Serial.print(", New payload: ");
        Serial.println(message.getCustomString(strMsgPtr));
        hekH 1 Reply Last reply
        • M Mickey
          char strMsg[25];
          // spit to serial
          @Mickey
          Are you getting compile error using:
          Serial.println(message.getString(strMsg));
            Mickey
            No
            with this method it compile ...
            thanks
              Mickey
              wrote on last edited by Mickey
              OK
              Now I having problems with the other way around(x,y,z are one byte numbers) I want to convert 3 values of x,y,z to one string that contain 3 hex numbers
              char *strTag[] = {String(x, HEX)+String(y, HEX)+String(z, HEX)};
              gw.send(msg.set(strTag));
              but I cant work it out...
              *EDIT:
              This workout for me:
              String temp="I";
              temp+=String(x, HEX);
              temp+=String(y, HEX);
              temp+=String(z, HEX);
              temp.toCharArray(strMsg,10);
              gw.send(msg.set(strMsgPtr));
              • M Mickey
                OK
                *EDIT:
                String temp="I";
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                wrote on last edited by BulldogLowell
                @Mickey
                how do you parse this string back out?
                you will not get leading zeroes, so how will you know if where the first second and third digit start and end in your string?
                byte a = 255;
                byte b = 0;
                byte c = 15;
                unsigned long myHex = 0;
                  Serial.begin(9600);
                  String yourString;
                  yourString += String(a, HEX);
                  yourString += String(b, HEX);
                  yourString += String(c, HEX);
                  Serial.println("your string looks like this:");
                  Serial.println(yourString);
                  // try this?
                  myHex |= a;
                  myHex <<= 8;
                  myHex |= b;
                  myHex <<= 8;
                  myHex |= c;
                  String myString = String(myHex, HEX);
                  Serial.println("my string looks like this:");
                  Serial.println(myString);
                  char buffer[6];
                  sprintf(buffer,"%02x%02x%02x",a,b,c);
                  Serial.println("or even better...");
                  Serial.println(buffer);
                output:
                ff0f
                ff000f
                or even better...
                ff000f
                updated
                  Mickey
                  ok I saw what you did and its way better.
                  this is my current code:
                  char strMsg[]="";
                  myHex |= x;
                  myHex <<= 8;
                  myHex |= y;
                  myHex <<= 8;
                  myHex |= z;
                  myString .toCharArray(strMsg,7;
                  right now its doing the job.
                  also how do I embed code in the forum?
                  ChaoticC BulldogLowellB 2 Replies Last reply
                  • M Mickey
                    char strMsg[]="";
                    myHex |= x;
                    myHex <<= 8;
                    myHex |= y;
                    myHex <<= 8;
                    myHex |= z;
                    ChaoticC
                    ChaoticC
                    Chaotic
                    @Mickey
                    If your talking about codebender code just paste the link
                    Example modified cleareeprom sketch that reports when done.
                    https://codebender.cc/sketch:89547
                      Mickey
                      no I meant like above with the black background(didn't know how but I just paste code from arduino IDE and it turn out like this...)
                      ChaoticC 1 Reply Last reply
                      • M Mickey
                        ChaoticC
                        ChaoticC
                        Chaotic
                        @Mickey oh thats easy start the line with 4 spaces and a blank line before it
                        like this
                        I had assumed you knew about that since you did it in your post before this.
                        If you click on the ? when replying it should bring you to a page on markup which tells you how to do that and other things.
                          Mickey
                          like this
                          I must say its turn out to be a great community this site...
                          • ChaoticC Chaotic
                            like this
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            or put the whole block of code between 3 backticks like this:
                            (backticks are the apostrophe looking thingy to the left of your 1 on the keyboard!)
                            code posts automagically:
                            	Serial.begin(115200);
                              for (int i=0;i<512;i++) {
                                EEPROM.write(i, 0xff);
                              Serial.println("Finished");
                            • M Mickey
                              char strMsg[]="";
                              myHex |= x;
                              myHex <<= 8;
                              myHex |= y;
                              myHex <<= 8;
                              myHex |= z;
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              isn't it still dropping a leading zero on the first byte?
                              how about:
                              byte a = 13;
                              byte b = 255;
                              byte c = 16;
                                Serial.begin(9600);
                                char *buffer = "";
                               // gw.send(msg.set(buffer))//<<<<<<<<<<<<<<
                              that should work, and get you the leading zero and is a little simpler code...
                                Mickey
                                @BulldogLowell said:
                                char *buffer = "";
                                this is what I get with this suggested code:
                                acff53ffd2
                                I expected and needed a six char figure here like RGB color code:
                                ffffff
                                000000
                                and this is what I got with my previous code
                                but I getting 10 chars now...(or am I missing some fundamental understanding on hex numbers...?)
                                • M Mickey
                                  char *buffer = "";
                                  acff53ffd2
                                  ffffff
                                  000000
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @Mickey
                                  are you using an Arduino to break up the message on the other end? In other words, to what are you sending this message? It may be easier to send it as an Unsigned Long, and use the bitshift method you used, as long as you can decode it on the receiving side.
                                  Can you decode an UL where the message is going?
                                    Mickey
                                    I'm writing a sketch that use a MEMS sensor (ADXL345 in this case but it will be a start point for more sensors like this like MPU6050).
                                    this chip can raise an interrupt when: inactivity sensed,activity sensed,tap,double tap,free fall.
                                    so the reading of the XYZ values with a leading char that represent the event sensed (I for inactivity and etc ) are going to a serial MySensor GW and from there to the controller (right now I'm using MYSController).
                                    *EDIT
                                    I found out that values can be negative so I just sending the decimal numbers as is...
