  3. Coronavirus (way, way, off topic)
115 Posts 18 Posters 27.7k Views 16 Watching
  • zboblamontZ zboblamont
    @NeverDie Worth a read as a lot of info not explained by the political crew or the media... The infectivity and when it peaks is the most illuminating, it explains why it spread so dramatically, and why isolation, distancing, sitting tight and testing were so effective...
    As an aside to the lunacy, Chinese sent a planeload of gear and advisers to help in Italy with their experience in dealing with COVID.
    No use to Trumpland of course, the CHINESE VIRUS is unknown outside the US ;)
    https://www.sciencenews.org/article/coronavirus-most-contagious-before-during-first-week-symptoms
    mntlvrM
    mntlvrM
    mntlvr
    @zboblamont You know the test will only tell you if you have at time of test not if you will not get it in the future so not sure why all of the belief that testing is going to stop you from getting it if you are in contact with people who have it
    • mntlvrM mntlvr
      zboblamontZ
      zboblamontZ
      zboblamont
      wrote on last edited by zboblamont
      #22
      @mntlvr Sorry, obviously I didn't explain that clearly enough.
      There were two strands to testing the Chinese, South Korean etc authorities successfully deployed, and bear in mind these are in communities where voluntary precautions limited the spread, control on movement, distancing, isolation, sterilisation, etc..
      The first strand was a rolling programme of mass checking to identify those with potential symptoms, typically temperature, but there were reports of the Chinese deploying portable scanners to check for lung damage (a much earlier flag) but found no further info on that.
      Only those identified as suspicious went on to specific virus testing, while they traced and checked contacts. Where positive the contacts were advised to be aware and were more rigorously checked.
      Edit - A further complication is that some who recovered fully were infected a second time. This raises questions over immunity, but pretty sure the specialists are trying to figure that out.
      The Vo project/experiment in Italy was an interesting project on global virus testing... As a non-infected city, it's only danger now is inward carriers, but lockdown prevents it...
      NeverDieN 1 Reply Last reply
      • NeverDieN NeverDie
        zboblamontZ
        zboblamontZ
        zboblamont
        @NeverDie Thought you might find this informative https://www.livescience.com/how-long-coronavirus-last-surfaces.html
          NeverDieN
          NeverDieN
          #24
          @zboblamont said in Coronavirus (way, way, off topic):
          Here's a list of the different theories put forth to explain the double positive test. In classic news style, they're presented with almost equal weight. As a result, the TL;DR is: who knows? :shrug:
          https://www.snopes.com/fact-check/covid-19-reinfection/
          My guess: since the stakes are high, you probably want a test that's biased toward false positives over false negatives, and so you would actually expect some double positives from that alone. Whether statistics alone accounts for all of it or not... well, that's what bio statisticians are good for, to tease apart the raw data and figure that out. They should have interviewed one!
            zboblamontZ
            zboblamontZ
            zboblamont
            @NeverDie said in Coronavirus (way, way, off topic):
            Not sure what US media is like, but in the UK it is expert and eminent virologists such as Pierce Morgan, Nigel Farage and Boris Johnson's father they select to interview.... :eyes:
            Considering the speed at which this has unfolded the knowledge gleaned has been remarkable, much more to come I suspect.
            UK now has finally gone into lockdown and I believe the US, but there is still considerable disinformation circulating which is not helping, such as Dan Patrick's idiocy on Fox News, reported in the UK along the lines of "WTF... and we thought Boris Hohnson was mad".
            Will leave you with this reality check from Ireland, where numbers are still mercifully low... https://www.independent.ie/irish-news/stay-indoors-im-young-sporty-and-fit-i-never-would-have-thought-id-catch-coronavirus-39070693.html
            Good luck to all, stay safe...
            Nca78N NeverDieN 2 Replies Last reply
              Nca78N
              Nca78N
              I believe this is some kind of worldwide trend :face_palm:
                NeverDieN
                NeverDieN
                @zboblamont According to an op-ed piece in the New York Times, as of yesterday "the United States has tested approximately 313,000 people for the coronavirus, and more than 270,000 have tested negative." i.e. only 13.7% of those who were tested actually tested positive. Given how pre-screened most of those 313,000 had to be in order to even get the test, that 13.7% figure seems a lot lower than I would have expected a priori. Unless the test itself is pretty much garbage, that suggests there must be some other flu with remarkably similar symptoms that's attacking in parallel at the same time. A one-two punch perhaps?
                Nca78N zboblamontZ 2 Replies Last reply
                  Nca78N
                  Nca78N
                  wrote on last edited by Nca78
                  #28
                  A lot of tests return negative while people are still in incubation period, but also after symptoms, they seems to be far from 100% reliable. Yesterday they stated that a case currently treated at hospital was tested negative 3 times already, but she is still not considered "cured" in the official statistics.
                  My building is still in quarantine, we were supposed to be released from quarantine if all direct contacts tested negative. They tested them all, twice, all negative, but they still maintain the quarantine until the end of the 14 days, and tested all the building yesterday.
                  I think it shows how much they trust the tests...
                  If you look at the study from Pr Raoult in France who claims chloroquine is an incredible cure, you can see the same patient can be positive one day, negative the next, and positive again on third day. And that's probably the best hospital in France, with the best equipment and very experienced doctors.
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    #29
                    @NeverDie There do appear to be conflicting reports of test results, but what is not clear in some cases is what the test actually was.
                    What IS however very clear is that different strategies of identification, distancing, isolating, quarantine are having various profoundly differing impacts on the spread of the virus, but doing nothing is catastrophic.
                    A collaborative article drawing together various aspects of this I'll attach here, a long but illuminating read, and we all have plenty of time of late... The projections for the US were eye-popping, even if the orange faced idiot thinks you'll all be at Easter church services..
                    https://medium.com/@tomaspueyo/coronavirus-the-hammer-and-the-dance-be9337092b56
                      NeverDieN
                      NeverDieN
                      #30
                      @zboblamont Surely by now everyone realizes that mitigation will help save lives. So, what's holding it back? In the US forward thinkers are starting to question whether a proper prolonged mitigation is even possible without the economic wheels exploding and an altogether different, possibly worse disaster happening, leading to who knows what. It's hard to know what the shape of that might be, but look at how quickly Iraq went barbaric after the US invaded as one possible model of the fallout, and, well, it's not unimaginable. We're all built from the same DNA as those Iraqi's. Mass looting? Definitely, and in poorer cities pretty fast once the groceries run out. And the chaos just gets worse from there. Take existing crime and multiply by 100x. We're just not staffed to control for that. I think we're looking at government rationing and martial law, at a minimum, just to try to keep a lid on things and prevent a boilover.
                      So, on the one hand, we think we know the huge cost in lives of not mitigating, but on the other hand, we have little idea of what a prolonged mitigation could lead to, because there's just too many unknowns. Save lives or save society as we know it? And then you look at just whose lives are being saved, and it's mostly a lot of very old people, so you're saving years at end of life rather than saving entire lives. Thus, I can see an argument in favor of letting the chips fall where they may on the virus front but otherwise keeping the world as we know it more or less in tact. Ultimately, I think that's the sort of trade-off that's being debated behind closed doors. If not already, then pretty soon.
                      • scalzS
                        scalzS
                        wrote on last edited by scalz
                        #31
                        @NeverDie depends on who's old. Here in FR, yesterday, 38% of people in reanimation are <60years old. Being in reanimation, means people may also have future health consequences=money cost too.
                        Sadly, there are also doctors who died, infected nurses and firemen.. each day seems worse. with confinement, peak is coming very soon here I think.
                        Citing a french doctor: "when there is fire, you shouldn't look at the water bill"
                        • scalzS scalz
                          NeverDieN
                          NeverDieN
                          #32
                          @scalz said in Coronavirus (way, way, off topic):
                          They may be in re-animation, but are they dying? So far, US death rate seems governed by age:
                            zboblamontZ
                            zboblamontZ
                            zboblamont
                            @NeverDie As @scalz aptly quoted, "when there is fire, you shouldn't look at the water bill", unfortunately many of our politicians obsess over little else.
                            Frequently ignored on stats relating to age range of fatalities is the realities faced where COVID overwhelms, such as Italy. Those >60 are more likely to have medical complications which increase chances of pneumonia. When numbers attending hospital exceed resources, prioritising WHO gets ventilation kicks in. Over 60s are not priority but are given "assistance" to suffer less, hence inflating fatalities in that age range. A dreadful but necessary choice for doctors typical of a war zone.
                            China went on a war footing rapidly, field hospitals, roving screening, contact tracing, they wrote the book. Korea and Singapore refined the techniques successfully, look at their numbers and condition now...
                            It is too early to assess the long term damage to health for survivors, but lung damage is fully expected, hence the desperate search for drugs which can have beneficial effect BEFORE infection becomes destructive.
                            Finally, the front line as @scalz highlighted. It is crucial medics etc are given all the PPE and kit they need, without it their numbers will deplete, and fatalities will increase... No healthcare system can handle this, again highlighting the importance of strategy deployed by Singapore/Korea etc, screen, test, trace, isolate.
                            Watch London in the next 10 days for a textbook example of bean-counter mentality on the health of a populace, it will eclipse Lombardy...
                              NeverDieN
                              NeverDieN
                              #34
                              @zboblamont Yes, in an ideal world, I'm all for that. But realistically, for how long can it be maintained? At the moment, we're teetering on recession/depression. As you may have heard, in the US the politicians just recently authorized $2 Trillion direct cash injection to individuals and businesses, and supposedly that means most people will get a roughly $2,000 check. Wonderful. Just how long will that $2,000 last you before it runs out? A week? Two weeks? And then what? Another $2 Trillion? For argument's sake, let's say $4 Trillion/month. Times what? 12 months? 24 months? That would be a range of $48 Trillion to $96 Trillion dollars. Who's going to lend the US that kind of money, especially in an environment where other countries will be needing to borrow similar amounts? Even if everyone got behind that, is it even possible? I just don't see how. In the near term the treasury could print money, but there are limits to even that before dollars lose much of their value to inflation, and if that's the only plan then dollars will become devalued even sooner. US GDP is roughly $20 Trillion. Total existing national debt is $22 Trillion. If there's some way it's possible, I'm just wondering how.
                              And I don't mean this to be about the US. The same thing in will probably happen in many if not most other countries.
                              My earlier point was simply this: in the US the average life expectancy is 78.6 years. For simplicity, let's set aside the nuances of what that means and take that number at face value. Suppose that by whatever means and at whatever cost you could save a large chunk of the 85+ year olds. Just how much longer do you suppose they would live, even before coronavirus? Maybe a couple more years, on average? And yet, because I doubt the US will triage like the Italians are doing, they'll probably be occupying most of the hospital beds and respirators, because they'll become the sickest in the biggest numbers.
                              • giangiredG
                                giangiredG
                                giangired
                                Hi guys from Italy. I live in one of the most interested areas by the Virus and I can say that the situation is very bad. I read some of you refer to older people as the main group touched by the virus. That's obviously true but our doctors start to say that the last days people around 50 years old are now increasing in the intensive care units. So, since you all have more time than us, please stay at home and avoid any possible contact with others because this virus is very aggressive. Take care!
                                Nca78N 1 Reply Last reply
                                • giangiredG giangired
                                  Nca78N
                                  Nca78N
                                  #36
                                  @giangired said in Coronavirus (way, way, off topic):
                                  And yesterday a 16 y.o. girl died in France...
                                  Edit: no pre-existing condition known and no saturation of hospital/missing equipment involved...
                                  http://www.leparisien.fr/essonne-91/morsang-sur-orge-91390/julie-16-ans-decedee-du-coronavirus-personne-n-est-invincible-se-desole-sa-soeur-27-03-2020-8288850.php
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @NeverDie We have been teetering on global recession/depression since 2008 because the underlying problem was never addressed, we just stuck a band-aid on it and carried on with the same "religion". The MMT model is now peeking out amid the UK crisis, and the finance circus are up in arms seeing their QE milk-cow taken away. For the US there are multiple times that resistance and greater lobbying power but that's a whole other issue..
                                    The problem with your earlier point is what value is placed on a human life, and as both preceding posts made clear the statistical prevalence of older sicker people masks the fact that this virus takes out the young and fit also.
                                    Without mitigation and ultimately intervention those numbers will escalate dramatically, and you're going to need multiple field hospitals built by the army in record time to cope. It is THAT serious.
                                    As of this morning the US exceeded China's infections (who tested rigorously and universally v the US scenario) the wider the spread of the virus the greater the number of young and middle-aged who will die, it really is THAT simple.
                                    As an aside, a 4,000 bed field ICU is almost completed in London just as ALL hospitals are at breaking point, but with it's high population it will still be too little for the tsunami which hits over the next 10 days.
                                    Time was up 6 weeks ago....
                                      NeverDieN
                                      NeverDieN
                                      #38
                                      @zboblamont Sounds apocalyptic. Here we've barely left the house since January. Take care, and even more so if you have one or more of the known co-morbidities that puts you at higher risk of death. Plan ahead and identify your source of nearest available supplemental oxygen in case it comes to that.
                                      The Italians have started to say that hospitals are a major source of caronavirus infection, so I intend to stay away unless it's truly unavoidable.
                                      In the US there's a push toward hospitals not attempting to resuscitate anyone (aka as "universal DNR") with caronavirus, because healthcare workers don't want to expose themselves to greater risks than they're already taking (which is the stated reason), but probably also legally absolve themselves from taking action when, for example, there simply aren't enough ventilators or other resources to meet demand. Otherwise, they'd be in a constant thrash mode trying to revive someone who has no ventilator access only to be in the same position a moment later, because there's still no spare ventilator to put them on. The only prior precedent for it would be people who officially ask in advance for DNR, with notarized paperwork and instructions to that effect, but this would encompass everyone, even if you've made it clear that's not what you want. I'm guessing it will be approved, but even if it isn't, I can imagine they may adopt that policy unofficially anyway out of either self survival or absurdity avoidance, in which case the public at large may not find out until after the dust has settled, if ever. At least if it were official, people would know what they may be in for if they're unable to breathe on their own, or worse, which is probably the only reason you'd want to be in a hospital in the first place. A brand new catch-22.
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        @NeverDie It's only apocalyptic because politicians made it so or played it down, the nuts claiming it's no worse than flu, or a scam by money manipulators, or Chinese conspiracy, or would damage the economy, only helped obscure the danger to human life by confused messaging.
                                        Odds of dying in ICU is averaging 17% from the figures I've seen, 27,000 dead so far, no plans to join that number but acutely aware I'm high risk, hence isolated...
                                        DNR is normal once ICUs are overloaded, a shot of morphine is all they can do to ease the passing.
                                        For now hunker down and take reasonable precautions, even from our own family members if symptoms show. Until governments are forced to take this seriously and adopt the WHO measures, there is very little upside until you survive it...
                                        Best of luck over there. ;)
                                        • NeverDieN
                                          NeverDieN
                                          If you don't already own one, you may want to buy an oximeter, just to have some objective measure of your condition or a family member's. They're cheap and even now probably pretty widely available. And if you do end up in a hospital, it sounds like you may want to take it there with you. Otherwise, you may be turning blue before anyone notices.
