  3. Coronavirus (way, way, off topic)
115 Posts 18 Posters 27.1k Views 16 Watching
    There's some debate about whether a mask is helpful protection or not. I'm not sure what the science indicates. Hackaday has an article on how to DIY one, and it seems to indicate that the coronavirus particle size is actually larger than some bacteria, whereas I had always thought viruses were generally smaller than bacteria. Clearly healthcare workers are wearing them, so that's maybe one sign that they do work. I guess I'm lucky in that I have a P100 dust mask for when I use my circular saw or 3D printing. I'm not sure what might be better than P100. Plainly Home Depot isn't normally stocked for a virus attack. Is there anything commonly off-the-shelf that's better than P100?
    One theory is that even if the virus size is smaller than what a P100 can completely remove, the virus is likely to be lodged inside a globule of spittle or mucus from when someone coughed, rather than floating about in the air in isolation, and so the filter can filter those globules, which are comparatively large, and so thereby block the virus, albeit indirectly.
    I see no downside to it, so if you have one, you might as well wear it when going about in crowded public places. It's still quite easy to breathe with it on. Perhaps it will become the new fashion. :muscle:
    skywatchS 1 Reply Last reply
      skywatchS
      skywatchS
      skywatch
      @NeverDie It is also said to enter via the eyes, so airtight eye protection is also needed or the mask may well be useless.....at least that is what I have heard....
      NeverDieN zboblamontZ Nca78N 3 Replies Last reply
      • skywatchS skywatch
        @skywatch Thanks! It will be hard to find something airtight that fits over my glasses, but I'll look.
          zboblamontZ
          zboblamontZ
          zboblamont
          @skywatch True, but the greatest danger is the airways because you are inhaling.
            Just a follow-up: Hackaday's reported size for the virus (https://hackaday.com/2020/03/18/homemade-masks-in-a-time-of-shortage/) is the right order of magnitude but nonetheless a bit off. Hackaday reported 0.1 to 0.2 micron in size, whereas analysis under an electron microscope reports it is 70 to 90nm in size (https://www.ncbi.nlm.nih.gov/pmc/articles/PMC7045880/). The hellish thing is definitely smaller than even the smallest known bacteria.
            From what I've read so far, there are (obviously) respirator filters that can filter out virus's of even that small particle size, but they are cause for labored breathing and so unpleasant to wear. I guess that's why the ultimate is a powered air purifying respirator (PAPR), which the CDC says offers good protection (https://www.cdc.gov/niosh/npptl/topics/respirators/factsheets/respsars.html) Interestingly, hackaday has a design for one of those too (https://hackaday.com/2007/05/25/diy-powered-respirator/), but who can say how well they work. I may have the parts for one, though, as I was a year or so ago trying to create an air purifier for a 3D printing enclosure. There was a design on thingiverse that I used to house the HEPA filter. It turned out the computer fan I was hoping to use was just nowhere near strong enough to push air through the HEPA filter. Besides, since it wouldn't be formally rated for this use, it would be a total crapshoot as to how well it would actually work.
            Fortunately, the above CDC article says that airborn transmission of small particles is thought to be a relatively rare way to contract COVID-19. It seems that the protective eyewhere is therefore meant to be a guard against being directly sneezed/coughed upon at close proximity.
            So, unless anyone has a better idea for something better than P100, I guess that's about it. I will, though, add over-glasses shop goggles, for whatever good they might do, if anything, since I have them anyway for when working with power tools. Perhaps overspray goggles would be even better? That way it might guard against someone "painting" my eyeballs with their cough. LOL.
              Which sources of information about coronavirus have you all found to be the best? I've read CDC, WHO, and FDA, but the best source I've found so far has been Harvard: https://www.health.harvard.edu/diseases-and-conditions/coronavirus-resource-center
              Useful info reported there:
              1. advised to take acetaminophen instead of ibuprofen if you have a fever.
              2. an experiment where a nebulizer was used to send coronavirus into the air shows that infectuous virus laden droplets can remain airborn for up to 3 hours. So, this idea that you see everywhere in the press that the particles can travel only up to 6 feet before they simply drop to the floor just isn't so, and plainly droplets can travel quite some distance in three hours.
              3. Coronavirus tests are prone to false negatives, and it's not even known yet at what stage of the disease a test might indicate positive.
              4. Cancel your kid's play dates.
              5. The incubation period is thought to be anywhere from 3 days to 13 days. The 5 days you commonly read about is just the average (presumably, the median).
              What I like about Harvard is that it's fairly frank about what still isn't known, as compared to, say, the FDA, which makes pronouncements like "there's no evidence that coronavirus can be transmitted by food", which may be literally true, but which probably misleads some people into thinking that such a grand pronouncement is being broadcast because it means food poses zero threat from coronavirus, which isn't what a more careful, literal reading actually implies. It would have been more honest to say that there "isn't yet any evidence." As my high school English teacher was fond of saying, "Absence of evidence isn't evidence of absence." Not surprisingly, fresh produce companies are quick to quote the FDA and reference the FDA as the source. Harvard is more clear that the matter isn't settled, and that the risk may depend a lot on the health of who may have touched the food (and their personal hygiene) before it gets to you. We know that the virus dies in 3 days on plastic or stainless steel, but what about on butter lettuce? That doesn't lend itself well to pealing off of layers, and sanitizing it with common sanitizers... yuck. So, here we won't be buying certain kinds of produce until more is definitely known about this.
              Nca78N 1 Reply Last reply
                @skywatch you're missing the point of the mask. Here it's not worn to protect you, but to protect others if you are infected. So you don't need to have an efficient/medical one, a cloth mask is enough to block saliva spray if you cough or just when you speak. I everyone is wearing a mask, you don't need glasses because no one can project the virus in your face.
                @NeverDie most people starting to put food aside in February here, because with China next door people were afraid it would spread. It's the case for us we had plenty of food in stock and my wife was outside when the quarantine was enabled so she boughts fruits and other fresh food.
                But we can also get deliveries at the entrance of the building and guards will give us so we are not in direct contact with delivery people.
                  @NeverDie for point 2) it's not comparable to someone coughing, nebulizer makes really tiny droplet that can stay in suspension, when you cough/spit the droplets are much bigger and don't stay airborne for long. But still, I think wearing tissue or even paper masks can limit the spread by blocking the saliva droplets.
                  For 3) it happened in Vietnam, a flight attendant was tested negative 4 times before testing positive. Some people have a long incubation period and it seems during part of this incubation period the test fails to detect the virus :(
                  For the FDA unfortunately at some point they have to give recommendations to people, as raw scientific data "It might, it might not" is not enough for people&companies to take a decision. So they have to opt for the most probable situation, and take into account the price and feasibility of things too I guess. If transmission rate is possible but likely extremely low with food, it's not worth spending huge amounts of money to avoid the few cases that it will cause.
                  • O
                    O
                    Omemanti
                    Here in the Netherlands, schools and daycares are closed for a week now, and stays so at least until the 6th of April. Only people with vital occupations can drop their kids off (hospital personal, and people who work for food companies etc. )
                    For the rest, they advise to stay at home and if you need to go out, stay at least 1,5m away from one another. No lockdown yet, they hope these measures will help flatten the curve.
                    But people are so very stupid atm. "hey its sunny, let's all go to the park/beach/(fill in crowded place)". I fear that for this reason, they will have a lockdown anytime soon.
                      zboblamontZ P 2 Replies Last reply
                      • zboblamontZ zboblamont
                        @NeverDie Worth a read as a lot of info not explained by the political crew or the media... The infectivity and when it peaks is the most illuminating, it explains why it spread so dramatically, and why isolation, distancing, sitting tight and testing were so effective...
                        As an aside to the lunacy, Chinese sent a planeload of gear and advisers to help in Italy with their experience in dealing with COVID.
                        No use to Trumpland of course, the CHINESE VIRUS is unknown outside the US ;)
                        https://www.sciencenews.org/article/coronavirus-most-contagious-before-during-first-week-symptoms
                        mntlvrM
                        mntlvrM
                        mntlvr
                        @zboblamont You know the test will only tell you if you have at time of test not if you will not get it in the future so not sure why all of the belief that testing is going to stop you from getting it if you are in contact with people who have it
                        • mntlvrM mntlvr
                          zboblamontZ
                          zboblamontZ
                          zboblamont
                          #22
                          @mntlvr Sorry, obviously I didn't explain that clearly enough.
                          There were two strands to testing the Chinese, South Korean etc authorities successfully deployed, and bear in mind these are in communities where voluntary precautions limited the spread, control on movement, distancing, isolation, sterilisation, etc..
                          The first strand was a rolling programme of mass checking to identify those with potential symptoms, typically temperature, but there were reports of the Chinese deploying portable scanners to check for lung damage (a much earlier flag) but found no further info on that.
                          Only those identified as suspicious went on to specific virus testing, while they traced and checked contacts. Where positive the contacts were advised to be aware and were more rigorously checked.
                          Edit - A further complication is that some who recovered fully were infected a second time. This raises questions over immunity, but pretty sure the specialists are trying to figure that out.
                          The Vo project/experiment in Italy was an interesting project on global virus testing... As a non-infected city, it's only danger now is inward carriers, but lockdown prevents it...
                            zboblamontZ
                            zboblamontZ
                            zboblamont
                            @NeverDie Thought you might find this informative https://www.livescience.com/how-long-coronavirus-last-surfaces.html
                              #24
                              @zboblamont said in Coronavirus (way, way, off topic):
                              Here's a list of the different theories put forth to explain the double positive test. In classic news style, they're presented with almost equal weight. As a result, the TL;DR is: who knows? :shrug:
                              https://www.snopes.com/fact-check/covid-19-reinfection/
                              My guess: since the stakes are high, you probably want a test that's biased toward false positives over false negatives, and so you would actually expect some double positives from that alone. Whether statistics alone accounts for all of it or not... well, that's what bio statisticians are good for, to tease apart the raw data and figure that out. They should have interviewed one!
                                zboblamontZ
                                zboblamontZ
                                zboblamont
                                @NeverDie said in Coronavirus (way, way, off topic):
                                Not sure what US media is like, but in the UK it is expert and eminent virologists such as Pierce Morgan, Nigel Farage and Boris Johnson's father they select to interview.... :eyes:
                                Considering the speed at which this has unfolded the knowledge gleaned has been remarkable, much more to come I suspect.
                                UK now has finally gone into lockdown and I believe the US, but there is still considerable disinformation circulating which is not helping, such as Dan Patrick's idiocy on Fox News, reported in the UK along the lines of "WTF... and we thought Boris Hohnson was mad".
                                Will leave you with this reality check from Ireland, where numbers are still mercifully low... https://www.independent.ie/irish-news/stay-indoors-im-young-sporty-and-fit-i-never-would-have-thought-id-catch-coronavirus-39070693.html
                                Good luck to all, stay safe...
                                Nca78N NeverDieN 2 Replies Last reply
                                  I believe this is some kind of worldwide trend :face_palm:
                                    @zboblamont According to an op-ed piece in the New York Times, as of yesterday "the United States has tested approximately 313,000 people for the coronavirus, and more than 270,000 have tested negative." i.e. only 13.7% of those who were tested actually tested positive. Given how pre-screened most of those 313,000 had to be in order to even get the test, that 13.7% figure seems a lot lower than I would have expected a priori. Unless the test itself is pretty much garbage, that suggests there must be some other flu with remarkably similar symptoms that's attacking in parallel at the same time. A one-two punch perhaps?
                                    Nca78N zboblamontZ 2 Replies Last reply
                                      wrote on last edited by Nca78
                                      #28
                                      A lot of tests return negative while people are still in incubation period, but also after symptoms, they seems to be far from 100% reliable. Yesterday they stated that a case currently treated at hospital was tested negative 3 times already, but she is still not considered "cured" in the official statistics.
                                      My building is still in quarantine, we were supposed to be released from quarantine if all direct contacts tested negative. They tested them all, twice, all negative, but they still maintain the quarantine until the end of the 14 days, and tested all the building yesterday.
                                      I think it shows how much they trust the tests...
                                      If you look at the study from Pr Raoult in France who claims chloroquine is an incredible cure, you can see the same patient can be positive one day, negative the next, and positive again on third day. And that's probably the best hospital in France, with the best equipment and very experienced doctors.
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        #29
                                        @NeverDie There do appear to be conflicting reports of test results, but what is not clear in some cases is what the test actually was.
                                        What IS however very clear is that different strategies of identification, distancing, isolating, quarantine are having various profoundly differing impacts on the spread of the virus, but doing nothing is catastrophic.
                                        A collaborative article drawing together various aspects of this I'll attach here, a long but illuminating read, and we all have plenty of time of late... The projections for the US were eye-popping, even if the orange faced idiot thinks you'll all be at Easter church services..
                                        https://medium.com/@tomaspueyo/coronavirus-the-hammer-and-the-dance-be9337092b56
                                          #30
                                          @zboblamont Surely by now everyone realizes that mitigation will help save lives. So, what's holding it back? In the US forward thinkers are starting to question whether a proper prolonged mitigation is even possible without the economic wheels exploding and an altogether different, possibly worse disaster happening, leading to who knows what. It's hard to know what the shape of that might be, but look at how quickly Iraq went barbaric after the US invaded as one possible model of the fallout, and, well, it's not unimaginable. We're all built from the same DNA as those Iraqi's. Mass looting? Definitely, and in poorer cities pretty fast once the groceries run out. And the chaos just gets worse from there. Take existing crime and multiply by 100x. We're just not staffed to control for that. I think we're looking at government rationing and martial law, at a minimum, just to try to keep a lid on things and prevent a boilover.
                                          So, on the one hand, we think we know the huge cost in lives of not mitigating, but on the other hand, we have little idea of what a prolonged mitigation could lead to, because there's just too many unknowns. Save lives or save society as we know it? And then you look at just whose lives are being saved, and it's mostly a lot of very old people, so you're saving years at end of life rather than saving entire lives. Thus, I can see an argument in favor of letting the chips fall where they may on the virus front but otherwise keeping the world as we know it more or less in tact. Ultimately, I think that's the sort of trade-off that's being debated behind closed doors. If not already, then pretty soon.
