  3. Home Assistant
  4. Mysensors Node not being recognized (added)
3 Posts 3 Posters 497 Views 3 Watching
  • pw44P
    pw44P
    pw44
    Hi All,
    i have HA Core and mysensors gateway + one mysensors door sensor node.
    I simply not finding out how to add the node to be monitored.
    Log debug shows:
    root@wolke:/var/homeassistant/homeassistant# cat home-assistant.log
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up http
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.2 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up system_log
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.1 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'cloud', 'alexa', 'auth', 'frontend', 'websocket_api', 'config', 'system_log', 'person', 'lovelace', 'device_automation', 'search', 'webhook', 'onboarding', 'api', 'http'}
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up person
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up lovelace
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up device_automation
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up alexa
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up auth
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up config
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.1 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up webhook
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up api
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain alexa took 0.0 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.1 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.0 seconds.
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up search
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds.
    2020-07-06 08:47:01 INFO (SyncWorker_2) [homeassistant.loader] Loaded camera from homeassistant.components.camera
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.1 seconds.
    2020-07-06 08:47:01 INFO (SyncWorker_4) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
    2020-07-06 08:47:01 INFO (SyncWorker_2) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
    2020-07-06 08:47:01 INFO (MainThread) [homeassistant.setup] Setting up onboarding
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up cloud
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.7 seconds.
    2020-07-06 08:47:02 INFO (SyncWorker_8) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up frontend
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'default_config', 'input_number', 'input_select', 'zeroconf', 'mysensors', 'updater', 'group', 'scene', 'tts', 'ipp', 'logbook', 'automation', 'zone', 'geo_location', 'sun', 'history', 'system_health', 'nextcloud', 'script', 'mobile_app', 'ssdp', 'input_text', 'mqtt', 'input_datetime', 'map', 'input_boolean', 'upnp', 'met'}
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up input_number
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up input_select
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up updater
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up group
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up scene
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up automation
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up zone
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up sun
    2020-07-06 08:47:02 INFO (SyncWorker_11) [homeassistant.loader] Loaded geo_json_events from homeassistant.components.geo_json_events
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up nextcloud
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up script
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up input_text
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up met
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up geo_location
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.1 seconds.
    2020-07-06 08:47:02 INFO (SyncWorker_7) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up logbook
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up history
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up system_health
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up map
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.geo_location] Setting up geo_location.geo_json_events
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain geo_location took 0.1 seconds.
    2020-07-06 08:47:02 INFO (SyncWorker_13) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up ipp
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up mqtt
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.2 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 0.2 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 0.2 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 0.2 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 0.2 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.2 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.1 seconds.
    2020-07-06 08:47:02 INFO (SyncWorker_8) [homeassistant.loader] Loaded weather from homeassistant.components.weather
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up tts
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up upnp
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain ipp took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.2 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up weather
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.2 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.updater
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 0.0 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.1 seconds.
    2020-07-06 08:47:02 INFO (SyncWorker_3) [homeassistant.loader] Loaded notify from homeassistant.components.notify
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.weather] Setting up weather.met
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain upnp took 0.0 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up notify
    2020-07-06 08:47:02 WARNING (zeroconf-ServiceBrowser__elg._tcp.local.-_ipps._tcp.local.-_miio._udp.local.-_googlecast._tcp.local.-_api._udp.local.-_daap._tcp.local.-_esphomelib._tcp.local.-_printer._tcp.local.-_nut._tcp.local.-_spotify-connect._tcp.local.-_dkapi._tcp.local.-_ipp._tcp.local.-_axis-video._tcp.local.-_hap._tcp.local.-_wled._tcp.local.-_viziocast._tcp.local._140061348976384) [zeroconf] Error sending through socket 12
    Traceback (most recent call last):
      File "/var/homeassistant/lib/python3.7/site-packages/zeroconf/__init__.py", line 2792, in send
        bytes_sent = s.sendto(packet, 0, (real_addr, port))
    OSError: [Errno 126] Required key not available
    2020-07-06 08:47:02 INFO (Thread-5) [homeassistant.components.mqtt] Connected to MQTT server wolke.wollny.com.br:1883 (0)
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.mobile_app
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.2 seconds.
    2020-07-06 08:47:02 INFO (SyncWorker_18) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up sensor
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up ssdp
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds.
    2020-07-06 08:47:02 INFO (SyncWorker_5) [homeassistant.loader] Loaded brother from homeassistant.components.brother
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setting up mysensors
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 0.1 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mobile_app
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.ipp
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.mobile_app
    2020-07-06 08:47:02 INFO (MainThread) [homeassistant.components.sensor] Not adding entity HP LaserJet 1010 - CUPS+Gutenprint v5.2.13 Uptime because it's disabled
    2020-07-06 08:47:03 WARNING (SyncWorker_9) [mysensors.persistence] File does not exist or is not readable: /var/homeassistant/.homeassistant/mysensors.json
    2020-07-06 08:47:03 INFO (MainThread) [homeassistant.setup] Setting up default_config
    2020-07-06 08:47:03 WARNING (SyncWorker_9) [mysensors.persistence] Trying backup file: /var/homeassistant/.homeassistant/mysensors.json.bak
    2020-07-06 08:47:03 WARNING (SyncWorker_9) [mysensors.persistence] File does not exist or is not readable: /var/homeassistant/.homeassistant/mysensors.json.bak
    2020-07-06 08:47:03 WARNING (SyncWorker_9) [mysensors.persistence] Failed to load sensors from file: /var/homeassistant/.homeassistant/mysensors.json
    2020-07-06 08:47:03 DEBUG (SyncWorker_7) [mysensors.persistence] Saving sensors to persistence file /var/homeassistant/.homeassistant/mysensors.json
    2020-07-06 08:47:03 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.0 seconds.
    2020-07-06 08:47:03 INFO (MainThread) [homeassistant.setup] Setup of domain mysensors took 0.5 seconds.
    2020-07-06 08:47:03 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.80.9', 5003)
    2020-07-06 08:47:03 INFO (MainThread) [mysensors] Connected to <_SelectorSocketTransport fd=23 read=polling write=<idle, bufsize=0>>
    2020-07-06 08:47:03 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;14;Gateway startup complete.
    2020-07-06 08:47:03 INFO (MainThread) [mysensors.handler] n:0 c:255 t:3 s:14 p:Gateway startup complete.
    2020-07-06 08:47:03 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 0 child 255
    2020-07-06 08:47:03 DEBUG (MainThread) [mysensors] Receiving 0;255;0;0;18;2.3.2
    2020-07-06 08:47:03 INFO (MainThread) [homeassistant.components.updater] Submitted analytics to Home Assistant servers. Information submitted includes {}
    2020-07-06 08:47:04 INFO (MainThread) [homeassistant.setup] Setup of domain nextcloud took 1.7 seconds.
    2020-07-06 08:47:04 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.nextcloud
    2020-07-06 08:47:04 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.nextcloud
    2020-07-06 08:47:12 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.upnp
    2020-07-06 08:47:12 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 11.66s
    2020-07-06 08:47:12 INFO (MainThread) [homeassistant.core] Starting Home Assistant
    2020-07-06 08:47:12 INFO (SyncWorker_6) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
    2020-07-06 08:47:13 DEBUG (SyncWorker_17) [mysensors.persistence] Saving sensors to persistence file /var/homeassistant/.homeassistant/mysensors.json
    2020-07-06 08:47:13 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2020-07-06 08:47:13 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.2
    2020-07-06 08:47:14 INFO (MainThread) [homeassistant.core] Timer:starting
    2020-07-06 08:47:23 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2020-07-06 08:47:23 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.2
    2020-07-06 08:47:33 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2020-07-06 08:47:33 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.2
    2020-07-06 08:47:43 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2020-07-06 08:47:43 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.2
    2020-07-06 08:47:53 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2020-07-06 08:47:53 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.2
    2020-07-06 08:48:03 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2020-07-06 08:48:04 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.2
    mysensors.json shows:
    root@wolke:/var/homeassistant/homeassistant# cat mysensors.json
        "0": {
            "sensor_id": 0,
            "children": {},
            "type": 18,
            "sketch_name": null,
            "sketch_version": null,
            "battery_level": 0,
            "protocol_version": "2.3.2",
            "heartbeat": 0
    What am i missing in order to have UI showing the node?
    Thx in advance
    • S
      Sasquatch
      you add entry for your door sensor node to mysensors.json
      AFAIK HA can't detect and automatically add your nodes
      • monteM
        monteM
        monte
        Please read carefully the HA documentation: https://www.home-assistant.io/integrations/mysensors/
        There it says that you need to present your node to HA by sending initial value of the node. Then HA adds it to its device list.
        if (!initialValueSent) {
            send(msg.set(state?RELAY_ON:RELAY_OFF));
            Serial.println("Requesting initial value from controller");
            request(CHILD_ID, V_STATUS);
            wait(2000, C_SET, V_STATUS);
