  3. [Tutorial] Raspberry Pi NRF24l01 direct connection
raspberry pinrf24l01
56 Posts 32 Posters 93.6k Views 24 Watching
  • H Offline
    H Offline
    hawk_2050
    I think the problem with the PiGatewaySerial showing as consuming 100% is not a real problem. I also see the CPU consuming 100% using the top utility, however as soon as you run another process, for example a user python script, on the Pi, you will notice that top will suddenly report that PiGatewaySerial is using only a few percent of the CPU.
    Cheers
    Richard
    • M Offline
      M Offline
      markusand
      Hi! I want to use RPi as a controller, with direct radio connection and pimatic. I've followed both posts but not sure how to make it work together. I know @Vladut-Grecu is using the same configuration, could you please point me to the right direction?
      • Roberto BrunialtiR Offline
        Roberto Brunialti
        wrote on last edited by Roberto Brunialti
        #23
        Ok. It seems the gateway is working as i get the same final screen when I run it. But... does it has a verbose mode? How can I know If it is working? I tried with a test node, unfortunately it seems not working ... or simply it does'nt give any feedback...
        • M Offline
          M Offline
          minscof
          wrote on last edited by minscof
          #24
          I used this gateway on a wheezy debian (RPI2) for several months and everything was ok. I upgraded my raspbian to jessie, and then the CPU load was always 100%. So I try to revert to wheezy, but i have now the same problem : CPU stays at 100 % .
          So there must be a system configuration somewhere to improve this gateway and prevent it to use all the CPU.
          Do you have an idea ?
          **Solved **: see this post
          • D Offline
            davy39
            I'm trying to setup a direct connection between domoticz and /dev/ttyMySensorsGateway
            Waiting for my hardware (no NRF24l01 attached yet), I'm actually playing around with the software part.
            I did install Domoticz and MySensorsGateway on the Pi and I'm getting a /dev/ttyMySensorsGateway symlink at boot time.
            The problem is that I can't see it on domoticz interface when trying to choose a serial port on "Mysensors gateway USB" device : only /dev/ttyAMA0 ....
            Is that because no NRF24 is connected or there is a specific configuration to make /dev/ttyMySensorsGateway appearing as a serial port (chown, udev ....)
            Thanks for your help
            • F Offline
              F Offline
              fets
              Hi everybody,
              I'm new in mysensors world and I would like to use my pi2 with direct connection to nrf24l01.
              There is a new release of the arduino library but I can't find the raspberry one.
              Somebody knows if it exists and where to find it ?
              I also tried to find an example of using raspberry as mqtt gateway without success, any ideabut was not able to find an example
              • hekH Offline
                hekH Offline
                You could probably run the old one.
                Ideally I would like to have the same code-base for RPi but someone needs to help implement the HW-implementation-class.
                • F Offline
                  F Offline
                  fets
                  Thanks hek, i'll try to use old code but I didn't find anything about raspberry as mqtt client gateway.
                  If I succeed, and if not too late, i'll try to implement the new library
                  • hekH Offline
                    hekH Offline
                    If you do want to help out, have a look at the gateway-refactoring-branch. Opening up for different protocols over there (where MQTT should be one of them).
                    https://github.com/mysensors/Arduino/tree/gateway-refactoring
                    • Fernando ArconadaF Offline
                      Fernando Arconada
                      hi everybody
                      @hek are you going to support Rpi + rf24 direct connection? I were playing with https://github.com/mysensors/Raspberry a bit and works (I opened a pair of tickets) but needs to be updated.
                      I also think that PiGateway should support MQTT I have created PiGatewayMQTT (It's just a prototype).
                      What will be the future of https://github.com/mysensors/Raspberry repo? abandoned in favor of any kind of gateway-refactoring-branch ?
                      thanks
                      • J Offline
                        J Offline
                        jelluz
                        wrote on last edited by jelluz
                        #31
                        (solved)
                        Hi. Thanks a lot for this implentation and the helpful posts here!
                        I've got the gateway working with a tmp75 temperature sensor on an arduino. The nrf24 is sitting on the raspberry directly (CE pin 22), as a controller i'm using PiMatic. It works very nicely!
                        There is one small problem however. The PiGatewaySerial will only work if i have called PiGateway before (and closed it again). With working I mean picking up radio transmissions from my sensor node. Everything else seems normal (/dev/ttyPiGatewaySerial and radio details printout).
                        The details of both configurations might give a clue:
                        pi@raspberrypi ~/mysensors_rpi $ sudo ./PiGateway
                        Starting Gateway...
                        ================ SPI Configuration ================
                        CSN Pin          = CE0 (PI Hardware Driven)
                        CE Pin           = Custom GPIO25
                        Clock Speed      = 8 Mhz
                        ================ NRF Configuration ================
                        STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                        RX_ADDR_P0-1     = 0xa8a8e1fc00 0xa8a8e1fc00
                        RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                        TX_ADDR          = 0xe7e7e7e7e7
                        RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
                        EN_AA            = 0x3b
                        EN_RXADDR        = 0x06
                        RF_CH            = 0x4c
                        RF_SETUP         = 0x23
                        CONFIG           = 0x0e
                        DYNPD/FEATURE    = 0x3f 0x06
                        Data Rate        = 250KBPS
                        Model            = nRF24L01+
                        CRC Length       = 16 bits
                        PA Power         = PA_LOW
                        [CALLBACK]0;0;3;0;14;Gateway startup complete.
                        read: 4-4-0 s=0,c=1,t=0,pt=7,l=5:22.9
                        [CALLBACK]4;0;1;0;0;22.9
                        after closing PiGateway and opening PiGatewaySerial i get this:
                        pi@raspberrypi ~/mysensors_rpi $ sudo ./PiGatewaySerial
                        Starting PiGatewaySerial...
                        Protocol version - 1.4
                        Created PTY '/dev/pts/3'
                        Gateway tty: /dev/ttyMySensorsGateway
                        CE Pin           = Custom GPIO22
                        Clock Speed      = 8 Mhz
                        EN_AA            = 0x3b
                        EN_RXADDR        = 0x06
                        RF_CH            = 0x4c
                        RF_SETUP         = 0x23
                        CONFIG           = 0x0e
                        Data Rate        = 250KBPS
                        Model            = nRF24L01+
                        PA Power         = PA_LOW
                        read: 4-4-0 s=0,c=1,t=0,pt=7,l=5:22.8
                        Notice how the CE pins of both SPI configurations are different!
                        I'm at the point that i want to daemonize the gateway. Which in fact i did, but the same problem persists. Before i hack the startup script to first run and close PiGateway before PiGatewaySerial, i was hoping that someone has an idea what i'm doing wrong.
                        Thanks in advance!
                        solved!
                        I have two RPIs (a Pi 2 B and a Pi B+), which both worked with the pyRF24 lib of TMRh20, so when i had a look in the source of the radio initialization of PiGatewaySerial and found this:
                        #ifdef __PI_BPLUS
                        	gw = new MyGateway(RPI_BPLUS_GPIO_J8_15, RPI_BPLUS_GPIO_J8_24, BCM2835_SPI_SPEED_8MHZ, 1);
                        #else
                        	gw = new MyGateway(RPI_V2_GPIO_P1_22, BCM2835_SPI_CS0, BCM2835_SPI_SPEED_8MHZ, 1);
                        When i changed it to:
                        #ifdef __PI_BPLUS
                        #else
                        and recompiled the gateways,it all started to work. After powerup everything runs :).
                        The Rpi that is connected now is the Pi 2 B. So i guess either i have my nrf25 wired differently then defined in this lib, or the precompiler was thinking i have a B+ connected. Or both.
                        I will find out when i get this also working on my B+.
                        J 1 Reply Last reply
                        • E Offline
                          E Offline
                          ericvdb
                          Hi all,
                          I just followed the guide in the 1ste post, but i'm not able to compile this correctly.
                          Here's the output:
                          g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=arm        v6zk -D BCM2835_PERI_BASE=0x -c RF24.cpp
                          gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=arm        v6zk -D BCM2835_PERI_BASE=0x -c bcm2835.c
                          bcm2835.c: In function ‘bcm2835_init’:
                          bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
                          bcm2835.c:1208:28: error: invalid suffix "x" on integer constant
                          bcm2835.c:1209:28: error: invalid suffix "x" on integer constant
                          bcm2835.c:1210:28: error: invalid suffix "x" on integer constant
                          bcm2835.c:1211:28: error: invalid suffix "x" on integer constant
                          bcm2835.c:1212:28: error: invalid suffix "x" on integer constant
                          bcm2835.c:1213:28: error: invalid suffix "x" on integer constant
                          bcm2835.c:1214:28: error: invalid suffix "x" on integer constant
                          bcm2835.c:1228:83: error: invalid suffix "x" on integer constant
                          bcm2835.c:1232:81: error: invalid suffix "x" on integer constant
                          bcm2835.c:1236:81: error: invalid suffix "x" on integer constant
                          bcm2835.c:1239:83: error: invalid suffix "x" on integer constant
                          bcm2835.c:1242:83: error: invalid suffix "x" on integer constant
                          bcm2835.c:1246:83: error: invalid suffix "x" on integer constant
                          bcm2835.c:1249:83: error: invalid suffix "x" on integer constant
                          bcm2835.c:1253:79: error: invalid suffix "x" on integer constant
                          Makefile:52: recept voor doel 'bcm2835.o' is mislukt
                          make: *** [bcm2835.o] Fout 1
                          g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                          g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                          g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                          g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                          g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=armv6zk -I. -Ilibrf24-bcm/
                          g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -mfpu=vfp -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -mtune=arm1176jzf-s -D_TTY_NAME=\"/dev/ttyMySensorsGateway\" -D_TTY_GROUPNAME=\"tty\" -march=ar        mv6zk -I. -Ilibrf24-bcm/ -lrf24-bcm
                          /usr/bin/ld: cannot find -lrf24-bcm
                          collect2: ld returned 1 exit status
                          Makefile:60: recept voor doel 'PiGateway' is mislukt
                          make: *** [PiGateway] Fout 1
                          Done!
                          I'm using the 2015-05-05-raspbian-wheezy version complete with:
                          rpi-update
                          apt-get update
                          apt-get upgrade
                          Can anyone tell me what is going wrong.
                          Thx in advance.
                          • E Offline
                            E Offline
                            ericvdb
                            I got it working, and by adding ser2net in the mix, you have a MySensors raspberry pi ethernet gateway.
                            The trick is not to update the RPi, just use the latest image.
                            Does anyone know if it is possible to connect the status LEDs to the RPi?
                            • AndurilA Offline
                              AndurilA Offline
                              Anduril
                              Hi @ericvdb ,
                              could you please post your config for ser2net? I also tried to use my NRF24L01 connected to my RPi as ethernet gateway for MYSController, but all I got was an 'unable to bind port'.
                              • E Offline
                                E Offline
                                ericvdb
                                in /etc/ser2net.conf i used:
                                9003:raw:600:/dev/ttyMySensorsGateway
                                where 9003 is the tcp port your controller needs to connect to.
                                Remember, this allows only 1 connection, so if you want to play with multiple controllers, you can, however 1 at a time.
                                • AndurilA Offline
                                  AndurilA Offline
                                  Anduril
                                  Don't see any difference to my old entry... but pasted yours and now it works. Thank you very much @ericvdb
                                  • E Offline
                                    E Offline
                                    ericvdb
                                    you're welcome ;)
                                    • V Vladut Grecu
                                      [EDIT] - I uploaded a script in the next post that does everything I explained below
                                      I have installed MINImal raspBIAN which is a raspBIAN without a gui. So this should work for you guys.
                                      First of all you have to
                                      1. Undo your Overclock. If you have any. (SPI does not like Overclocked pi's)
                                      2. Enable SPI
                                      Details:
                                      On a normal raspbian image this can be done either on a fresh install (when you config your pi) or you can type in terminal sudo raspi-config
                                      From there you go into ADVANCED OPTIONS -> SPI
                                      On a minimal image you don't have the luxury of raspi-config. You have to manually activate it.
                                      (I already had it enabled but you can check)
                                      (If you don't have sudo installed on your image just run apt-get install sudo)
                                      sudo nano /etc/modprobe.d/raspi-blacklist.conf
                                      Make sure there IS a # before blacklist spi-bcm2708, so it looks like this…
                                      #blacklist spi-bcm2708
                                      If there is no line like that, you can add it. It won't do any harm.
                                      CTRL+O - Save
                                      ENTER - Confirm
                                      CTRL+X - Exit
                                      or
                                      CTRL+X - Exit
                                      y - I want to save the file
                                      ENTER - Confirm
                                      We have to edit now the config.txt.
                                      sudo nano /boot/config.txt
                                      add this to the end of the line
                                      dtparam=spi=on
                                      Save and exit.
                                      Reboot your pi.
                                      sudo reboot
                                      Enjoy using SPI. (Source)
                                      3.Downloading the files
                                      Details:
                                      You have 2 options. wget and git-clone. I'll start with:
                                      a. git-clone
                                      If you don't have git-clone you need to install the git tools. (Yes, git is related to github)
                                      sudo apt-get install git
                                      After you installed git you simply navigate to the folder that you wish to install the program and type:
                                      sudo git-clone https://github.com/mysensors/Raspberry.git
                                      This will download a zip, unarchive it and.. It does all the jobs for you.
                                      b. wget
                                      Some ppl are old-school and go the hard way or they just enjoy it done this way.
                                      Navigate to the folder that you wish to install the program and type:
                                      wget https://github.com/mysensors/Raspberry/archive/master.zip (this will download you the zip)
                                      Unzip the file
                                      If you don't have unzip installed just type
                                      sudo apt-get install unzip
                                      unzip master.zip -d /home/pi/Raspberry (you can specify any directory that you want instead of the /home/pi/Raspberry)
                                      4.Edit and compile what you downloaded
                                      In the Raspberry folder you have some files and some folders.
                                      The majority of ppl (including me) forget to complile the libs for the NRF24l01.
                                      This is the library provided by [TMRH20]{http://tmrh20.github.io} (He has some interesting stuff there including an audio library for NRF24l01.)
                                      Back to our stuff.
                                      Go to the Raspberry folder then into librf24-bcm.
                                      cd Raspberry/librf24-bcm/
                                      Type
                                      make
                                      Go back to the Raspberry folder
                                      cd ..
                                      Type
                                      make
                                      5.Connecting the NRF
                                      Mister TMRH20 tells us that we need to connect the NRF24l01 this way
                                      PIN		NRF24L01	RPI				RPi -P1 Connector
                                      1		GND			rpi-gnd			(25)
                                      2		VCC			rpi-3v3			(17)
                                      3		CE			rpi-gpio22		(15)
                                      4		CSN			rpi-gpio8		(24)
                                      5		SCK			rpi-sckl		(23)
                                      6		MOSI		rpi-mosi		(19)
                                      7		MISO		rpi-miso		(21)
                                      8		IRQ			Not Connected
                                      Connect everything like that except for the CE pin
                                      Run the PiGatewaySerial
                                      ./PiGatewaySerial
                                      It shoud prin something like this:
                                      Created PTY '/dev/pts/1'
                                      Clock Speed      = 8 Mhz
                                      RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
                                      RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
                                      EN_AA            = 0x3b
                                      EN_RXADDR        = 0x07
                                      RF_CH            = 0x10
                                      RF_SETUP         = 0x23
                                      CONFIG           = 0x0e
                                      Data Rate        = 250KBPS
                                      Model            = nRF24L01+
                                      PA Power         = PA_LOW
                                      Look at line 7 CE Pin = Custom GPIO25
                                      Connect the CE pin where it says you should.
                                      Here are some pictures with the GPIO connector on the rPi.
                                      https://www.google.ro/search?q=raspberry+pi+gpio&tbm=isch
                                      G Offline
                                      G Offline
                                      GrantsPi
                                      @Vladut-Grecu - Thanks very much for the tutorial!! After a bit of trial and error I was able to get the Pi reading my two nodes with very good reliability.
                                      I'm now trying to merge this RPi Direct Connection with the openHab With Serial Gateway that TimO was kind enough to post (http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway). I had openHab working well on the RPi using an Arduino nano serial gateway using that tutorial.
                                      Running PiGatewaySerial in a terminal window yields the proper readings from the Arduino nodes but when I try to have openHab recognize the serial port "/dev/ttyMySensorsGateway" instead of the "/dev/ttyUSB99@115200" used in the openHab tutorial I get messages from openHab saying it could not open serial port '/dev/ttyMySensorsGateway'...
                                      Just wondering if anyone else has tried to marry the two projects or has any suggestions. (Perhaps I should also post this in TimO's openHab thread...)
                                      • R Offline
                                        R Offline
                                        revoltec112
                                        upload-3f496795-4ae3-4ed2-b533-3f5e9fd6283e
                                        Hi I am a beginner
                                        If I have something that's ok , I plugged in humidity and temperature sensor , and for what I have in front of ./PiGatewaySerial enter sudo ? ,
                                        how to make the data visible in Domoticz please help
                                        • R Offline
                                          R Offline
                                          revoltec112
                                          whether in the / dev file must be named ttyMySensorsGeteway ? if so how it developed and what it should contain
