  3. Anyone using/tried the E28-2G4M27S 2.4Ghz LoRa SX1280 27dB module?
249 Posts 10 Posters 70.3k Views 11 Watching
  • L Larson
    @NeverDie Yea, I think I knew you upversioned the silkscreen. I think I remember you commenting on it. Looks pretty. BUT in my effort to add to the community, since I typed it for my self for my V001 boards, I thought I'd share it incase there is anybody like me with V001.
    I like the V003 upgrades, specially that reset bypass via as discussed with @alphaHotel . Maybe I'll try it. I've got so much into my little V001's (yours actually) that I just can't give-em up. When I get the boards rigged up with radios, GPS (on the USART bus) and SD Card reader (on the SPI bus with a different CS), I'll shoot and send a picture in the spirit of a party!
    L Offline
    L Offline
    Larson
    wrote on last edited by Larson
    #241
    @Larson Okay, No picture party yet. But, I did get a notification from Digikey that the Atmega328P-AN is back in stock for $3 each.
    • mfalkviddM Offline
      #242
      @NeverDie today I re-read the fcc rules and I may have mislead you back in https://forum.mysensors.org/post/111853
      It seems like the fcc rules say that if you use more than 500kHz bandwidth, you don't need to use frequency hopping, and there is no dwell time requirement.
      (2) Systems using digital modulation techniques may operate in the 902-928 MHz, 2400-2483.5 MHz, and 5725-5850 MHz bands. The minimum 6 dB bandwidth shall be at least 500 kHz.
      I don't understand why fcc encourages applications to hog a big portion of the spectrum but it looks like you can go willy-nilly if you just use enough bandwidth.
      • SMH17S Offline
        SMH17S Offline
        SMH17
        2.4GHz LoRa modules offer a good data rate compared to lower frequency ones that are very limited on this aspect, but they suffer path loss much more and wide use of 2.4GHz increase interference problem a lot.
        I'm interested to know how they perform in typical urban use scenarios.
        Has someone tested E28-2G4M27S in urban environment?
        I have found only test result of people in very good condition as line of sight with no buildings or other obstacle interposed or at very short range (from a room to another in same building).
        • SMH17S Offline
          SMH17S Offline
          SMH17
          @NeverDie I have noticed that in the latest version of your adapter you have lowered the capacitor value used for the first stage filtering from 100uF to 10uF, leaving the second stage one to 0.1uF. Did you have empirical benefit in tests with this configuration? 0.1uF it seems to me at first glance too small to accommodate current draw fluctuation of this module. Would be appreciated if you explain your design choice. Thank you.
          N 1 Reply Last reply
          • SMH17S SMH17
            N Offline
            N Offline
            #245
            @SMH17 said in Anyone using/tried the E28-2G4M27S 2.4Ghz LoRa SX1280 27dB module?:
            The 10uF isn't for filtering. It's just to prevent voltage droop at the radio when the radio starts to pull current. So, yes, testing reveals that it seems adequate for that purpose. I originally slotted in 100uF because I wasn't sure, and overkill is better than underkill. It's possible that 10uF may also be overkill....
            • H Offline
              H Offline
              haxn2
              @NeverDie @Larson Have you had success with the Ra-01SH? I'm having trouble using high SF values (11, 12) with low bandwidth (<250 kHz). I wanted to know if you had the same experience and if you have other recommendations for sx126 modules if I just want really long ranges.
              N mfalkviddM 2 Replies Last reply
              • H haxn2
                N Offline
                N Offline
                #247
                @haxn2 I don't recall there being any problems of the type you describe. You didn't say what kind of "trouble" you were having, but, if anything, the high coding factor and narrow bandwidth should improve range, unless there is interference in the narrower band. Have you tried changing the frequency? Are you sure you're using a suitable antenna? Exactly what kind of range are you trying to achieve?
                • H haxn2
                  @haxn2 https://github.com/jgromes/RadioLib/issues/388 might be useful
                    N Offline
                    N Offline
                    ^^^This. Good point. Maybe do some testing with RadioLib to see whether or not you experience the same problem.
