  3. NRF5 Receive Challenges
5 Posts 2 Posters 801 Views 1 Watching
  • nagelcN
    nagelcN
    nagelc
    wrote on last edited by nagelc
    Hi All,
    I have not been able to connect my NRF52832 nodes to the gateway when using the MySensors development branch. I used the MySensors PassiveNode sketch to run some tests. It is a very simple sketch that sends random temperature readings. I tried the basic passive node, commenting out passive node, and disabling the uplink check on using both branches. Results:
    So the node appears to have some difficulty receiving messages from the gateway and has different issues between Master and Development branches. I have done some diffs of likely files but nothing jumps out at me as a suspicious difference between Master and Development.
    I'm using MY_RADIO_NRF5_ESB and assigning a static node number.
    I have to define MY_NRF5_ESB_MODE (NRF5_250KBPS) when using the Development Branch because my network is 250KBPS. I know this is deprecated. Could the low data rate be causing the receive issues?
    Can anyone point me to next steps for troubleshooting?
    • nagelcN nagelc
      Hi All,
      @nagelc maybe https://github.com/mysensors/MySensors/pull/1455#issuecomment-778836586 is related?
      And https://github.com/mysensors/MySensors/pull/1473
      nagelcN 1 Reply Last reply
        nagelcN
        nagelcN
        nagelc
        Thanks @mfalkvidd I'll check these out.
        I'm seeing an upgrade to 1MBS in my future, but I have a lot on nodes that would need to be updated. I'll probably put that off as long as I can : )
        • nagelcN
          nagelcN
          nagelc
          Ah ha. It worked. Updated the 250KBS callouts per the pull request.
          NRF5 communicates normally.
          Thanks!
          • nagelcN nagelc
            Thanks!
            Nice work @nagelc, thanks for reporting back.
