  3. Home Assistant
  4. Gateway on my PI when i run HA
5 Posts 3 Posters 839 Views 3 Watching
  • D
    D
    diltech
    Is it possible to put a gateway (Radio RF24) on my PI when i run my Home assistant on same machine ?
    • D diltech
      @diltech yes it should work. But it depends a bit on which installation method you used for HA.
      There are 4:
      Home Assistant Operating System
      Home Assistant Container
      Home Assistant Core
      Home Assistant Supervised
      • D
        D
        diltech
        @mfalkvidd said in Gateway on my PI when i run HA:
        • S
          se-O-matic
          With Home Assistant as Operating System it might not work, if the radio is connected to the GPIO of the Pi. The HASS-Os has some restrictions to run software like the Pi gateway beside Homeassistant.
          I have currently a setup with a RFM69 connected to the GPIO for the RPI ethernet gateway. Homeassistant runs in a container and the mysensors plugin connects in Homeassistant to localhost or 127.0.0.1. But I have problems with the stability (I think so) with this combination, as seen in this forum.
          In my opinion is a Serial (USB-Serial-Converter) Gateway with Homeassistant the best choice. So I want to build another gateway and resinstall my Pi with HASS-Os.
          • D
            D
            diltech
            Thank for your reply. Yes, i run since many years with a serial Gateway connected with my PI.
            I thought it was possible to use the same machine to remove this extra element.
            If you had a stability issue, I would just stick with my current formula and not change everything for now.
            Regards,
