  3. Pjon Script
Pjon Script
10 Posts 6 Posters 2.4k Views 5 Watching
  • S
    sindrome73
    Hello, good evening!!
    I'm trying to build two Nodes with two Arduino Pro Minis (a Gateway and a Node, to be precise) connected to each other using the Pjon Protocol.
    If I understand correctly, the nodes are connected to each other by a single wire, specifically Pin 12 by default.
    I just can't create the sketch.
    Can someone provide the Gateway and Node scripts?
    Thanks for your help.
    David JenkinsD 1 Reply Last reply
    • OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      @sindrome73 said in Pjon Script:
      Pjon Protocol
      The only way I see this working is that the remote device (non-gateway sensor) sends the data using the PJON protocol over whatever medium. The remote device would not use any MySensors code.
      On the gateway, a "sensor" would be created that would receive the data using the PJON protocol over that medium. Once the data is received, it would be "sent" to the gateway portion of the code that is running on the gateway.
      Thus, for every remote sensor there would have to be a "sensor" on the gateway. Sort of defeats the purpose of a gateway.
      It would be nice if MySensors were media independent and PJON would be a good candidate. Alas, I don't believe there is sufficient support for MySensors these days to create that environment.
      As far as someone creating these scripts, I would advise you do a deep dive into PJON. The first part would be to create the POJON "Hello World" pair. Once you have this working, then you could incorporate it into your MySensors gateway.
      Let us know how it works out.
      -OSD
        Thers is actually support for pjon as transport in MySensors: https://github.com/mysensors/MySensors/pull/1278
        I don’t know how it works though.
        TheoLT 1 Reply Last reply
          TheoLT
          TheoLT
          TheoL
          @mfalkvidd Is the PJON support in current release? Pjon is something that is on my wish list
          • nagelcN
            nagelcN
            nagelc
            It's in the development branch.
            How do you plan to use it? Sounds fascinating, but I haven't quite been able to wrap my head around it.
            • nagelcN nagelc
              TheoLT
              TheoLT
              TheoL
              @nagelc I'm thinking about making some kind of shelves with PJON built in. The shelves will have a wireless charger and with PJON I can communicate "Wireless". So on that shelf I can put some things like small candles, maybe a modified humidifier.
              Things like that xd
              • nagelcN
                nagelcN
                nagelc
                Cool. I'll have to get smarter about it
                • TheoLT
                  TheoLT
                  TheoL
                  PJON is really Cool. But not always very practical. But the whole eco system is well thought off. I was much impressed when I read about it.
                  • S sindrome73
                    David JenkinsD
                    David JenkinsD
                    David Jenkins
                    Yes, PJON can use a single wire on pin 12 by default. Try the basic PJON gateway and node examples as a starting point.
                    S 1 Reply Last reply
                    • David JenkinsD David Jenkins
                      sindrome73
                      @David-Jenkins Hi, good evening!! I can't find these examples. Can you share the link to the sketches?
                      Thank you so much!
