  3. Universal wireless sensor board w/NRF24l01+ and ESP8266 socket - ceech board
board
41 Posts 9 Posters 26.0k Views 4 Watching
  • S shabba
    EDITED
    Nevermind!!
    "- with CE and CSN pins connected to digital pins 7 and 8 (you must update MyConfig.h with these values). There is a 4.7uF capacitor connected across Vin and GND of the port"
    A Offline
    A Offline
    AWI
    @shabba You do not need to update MyConfig.h. Just instantiate MySensor with the right parameters (default is 9, 10).
    // PIN Radio
    #define RADIO_CE_PIN    7       // radio chip enable
    #define RADIO_SS_PIN    8      // CS SS serial select
    MySensor gw(RADIO_CE_PIN, RADIO_SS_PIN);
    • E Offline
      E Offline
      epierre
      I'm trying mine... any idea why the gateway doesn't receive it at 20cm distance ?
      req node id
      send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
      sensor started, id 255
      req node id
      req node id
      req node id
      req node id
      z-wave - Vera -> Domoticz
      • E Offline
        E Offline
        epierre
        @ceech sorry seems the radio was dead ...
        • E Offline
          E Offline
          epierre
          @ceech I have an issue on a board (lipo+solar) where when I put the programmer it works, when I remove it and leave it on battery it doesn't... battery is 94%, I checked sensors get the energy.. but no more radio it seems, an idea ?
          C 1 Reply Last reply
          • E epierre
            C Offline
            C Offline
            ceech
            @epierre It is probably a loose contact on the battery connector. Try using a multimeter and check the important connections.
            • E Offline
              E Offline
              epierre
              @ceech can you point me to the wirings ? thanks,
              • E epierre
                C Offline
                C Offline
                ceech
                @epierre Which board are you using?
                • E Offline
                  E Offline
                  epierre
                  on this one this is the lipo+solar.
                  On the other thread, I mistakenly ordered the "standard" version through mysensor website, and had no time till now to test this out... so bard both weren't proposed...
                  • E epierre
                    C Offline
                    C Offline
                    ceech
                    wrote on last edited by ceech
                    #29
                    @epierre The battery is connected with the marked trace:
                    It goes to the switch an over to the voltage regulator:
                    You should measure battery voltage along those lines with respect to the GND. On the other side of the voltage regulator there should be 3V3.
                    On the side note -- you can use those boards that you've mentioned on the other thread to charge the battery. No problem.
                    E 1 Reply Last reply
                    • C ceech
                      E Offline
                      E Offline
                      epierre
                      wrote on last edited by epierre
                      #30
                      thanks, but I should not have mixed both, my issue is with the other one.
                      • E epierre
                        C Offline
                        C Offline
                        ceech
                        #31
                        @epierre The one with LTC4067 or the one with LTC4079? It's probably the one with LTC4067.
                        Here, this is the battery path to the charger:
                        and then to the voltage regulator:
                        • E Offline
                          E Offline
                          epierre
                          #32
                          on the LCT4067, I have 4.17 , on the battery, VCC/GND gives 1.608, same on programmer pin. But this is correct with the programmer, so I get I have an issue from the battery circuit voltage transformation.
                          on the standard one LTC4079, voltages are correct, 4.17 on Vin/GND, 3.3 on VCC/GND
                          • E epierre
                            C Offline
                            C Offline
                            ceech
                            @epierre It's either the LTC4067, or the voltage regulator. Can you send me the board back?
                            I'll repair it and send you back.
                            • E Offline
                              E Offline
                              epierre
                              hello fine, also I wanted to try the thermopile so there will be more on return ;-)
                              In the meanwhile, how can I have my solar panel on the LTC4079 ? can the lithium charger do the trick ?
                              Thanks,
                              • E epierre
                                Thanks,
                                C Offline
                                C Offline
                                ceech
                                @epierre I've received the board and repaired it. I had to replace the battery management IC. The LTC4067. The output was fried. I also replaced the voltage regulator while I was at it.
                                • E Offline
                                  E Offline
                                  epierre
                                  @ceech thanks a lot, any idea why this would happen ?
                                  what kind of bluetooth module are you using ? I've managed nothing good with the HC-05, maybe faulty hard to know.
                                  • C Offline
                                    C Offline
                                    ceech
                                    There are current limiters on input and output side. So short circuit is out of the question. Maybe overvoltage on the input side.
                                    Yes, that's HC-05. Just use it as a serial monitor. It's the same.
                                    • N Offline
                                      N Offline
                                      nunver
                                      @ceech for the solar panel and lipo version, could you let me know what type of battery and panel I shoulld buy? Also, is there a tutorial for usage of that version? I am new in solar panel and cahrging batteries. Thanks
                                      • N nunver
                                        C Offline
                                        C Offline
                                        ceech
                                        #39
                                        @nunver The best solar panel is the one with voltages between 5 and 12 volts. And the board is set for a standard 3.7V Li-ion single cell battery. I've just updated the board with a DC-DC buck-boost converter which works below and above battery voltage. There is also plenty of other information on the following page:
                                        http://www.ebay.com/itm/331800929918?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
                                        • E Offline
                                          E Offline
                                          epierre
                                          @ceech what did you use for soldering, I cannot see it myself (sure I have a lot to learn for SMD soldering...
                                          12.1k
