  3. Domoticz
  4. No devices in Domoticz
6 Posts 4 Posters 4.9k Views 2 Watching
  • K
    K
    kopite
    Has anyone had success with Domoticz?
    I have added a serial usb gateway and pulse sensor but no devices show up?
    I can see in the log the following lines
    2015-04-30 21:47:31.646 MySensors: Node: 86, Sketch Name: Energy Meter
    2015-04-30 21:47:31.654 MySensors: Node: 86, Sketch Version: 1.0
    but i cannot see the device....anyone know how to resolve
    AWIA 1 Reply Last reply
    • K kopite
      AWIA
      AWIA
      AWI
      @kopite Are you sure the gateway is receiving "data" messages from the pulse sensor, other than the "presence" messages your see in the Domoticz log?
      • A
        A
        andriej
        Domoticz has something wrong with water/pulse meters.
        It does not send it's VAR (even if it's 0) for a long time.
        Try to reset it a lot and assing node ID by yourself.
        • hautomateH
          hautomateH
          hautomate
          When you go to Setup > Devices and click All Devices does it show?
          • K
            K
            kopite
            @AWI - How do i check this?
            @Andriej - How do i Assess the node ID?
            @hautomate - Only my RPi internals show up in devices
            • K kopite
              AWIA
              AWIA
              AWI
              @kopite Use the Serial monitor on the pulse meter Arduino and check if any VAR messages are sent with status ok. (debug on = default). If so then you know that at least the Gateway (and therefore Domoticz) is receiving information.
              If so and the Pulse meter data is not receive you could try a Temp or Light sensor to test if that works.
              Happy debugging :)
