  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    Sensebender is still on 1.4, as we haven't prepared new firmware for it yet.
    Mysensors 1.4 and 1.5 should be compatible with each other, right @hek ?
      Yes, it should.
      But as @Dewalt says, there was a bug in repeater functionality. So upgrading the repeater is a good tip.
      • J
        J
        johnr
        Upgrading repeater to 1.5 solved this issue. Thanks for the quick help. 1.4 sensors communicate OK with the 1.5 repeater as far as I can see right now.
        • F
          F
          Fabien
          I try to make a 3D box for SenseBender Micro with CR123 battery.
          Screenchot :
          • F
            F
            Fabien
            first print test : IMG_20150921_230740.jpg
            • tbowmoT
              tbowmoT
              tbowmo
              @Fabien
              Nice work, what is the dimensions of the enclosure?
                mvader
                @mvader said:
                question about the default sketch for this board.
                if i read correctly
                // How many milli seconds between each measurement
                #define MEASURE_INTERVAL 60000
                // How many milli seconds should we wait for OTA?
                #define OTA_WAIT_PERIOD 300
                // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
                #define FORCE_TRANSMIT_INTERVAL 30
                // When MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
                // Between the forced transmissions a tranmission will only occur if the measured value differs from the previous measurement
                // HUMI_TRANSMIT_THRESHOLD tells how much the humidity should have changed since last time it was transmitted. Likewise with
                // TEMP_TRANSMIT_THRESHOLD for temperature threshold.
                #define HUMI_TRANSMIT_THRESHOLD 0.5
                #define TEMP_TRANSMIT_THRESHOLD 0.5
                if temps don't change more than .5 i shouldn't see a transmit but once every 30 minutes
                i have 2 running right now
                and both send temp and humidity every 1-2 minutes and the numbers are the same or in some cases only different by .1
                i have it set to .5 so the question is
                1. why does it transmit every minutes when the temp and humidity are the same
                2. why is it transmitting even with as little as .1 change
                  1 board is running 1.2 and the other is running the 1.3 sketch from git
                  Battery however does transmit every 60 minutes as it's supposed to.,
                  thx
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @mvader
                  Have you tried to hook up a serial connection to your sensebender? It writes the difference from the last transmitted measurement, everytime a new measurement is taken (every minute).
                  M 1 Reply Last reply
                  • F
                    F
                    Fabien
                    @tbowmo 47x37 height : 27
                    I will make some improvment (can not test, my printer is in maintenance mode !) and post files for others.
                    • tbowmoT tbowmo
                      @mvader
                      mvader
                      @tbowmo said:
                      @mvader
                      so if i want it to transmit less frequently (save battery?) i would increase the measure interval. correct?
                      I have some situations where i want frequent measuring (1 minute), and some where 15 minutes or 30 minutes would do fine.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @mvader
                        Yes, you could save battery, by changing to 10/15 minute check interval..
                        But still, the interesting thing is why it transmits every minute.. That's why I would suggest to check the serial output..
                        • G gloob
                          Hello
                          I found an error in the sensebender micro sketch in the latest release.
                          The calculation of the temperature change is wrong.
                          float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100);
                          needs to be replaced with
                          float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0);
                          The division with 100 needs to be 100.0 otherwise the result will be an integer instead of a float value and the difference will be the decimal places of the last temperature.
                          korttomaK
                          korttomaK
                          korttoma
                          #272
                          There is an explanation to the problem further up in the thread:
                          @gloob said:
                          Hello
                          • Tomas
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @korttoma
                            thanks for helping my memory :)
                            • korttomaK korttoma
                              @gloob said:
                              Hello
                              mvader
                              @korttoma i did see that. but your saying that is what is causing it to transmit every 1 minute?
                              korttomaK 1 Reply Last reply
                              • M mvader
                                korttomaK
                                korttomaK
                                korttoma
                                @mvader yes, it is rounding the temperature difference to the nearest degree so the difference is almost always more then the 0.5.
                                • Tomas
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  Just a hint, itead studio is starting a sale with 10% off on all imall items.. So maybe it's time to buy some Christmas presents for the inner geek :)
                                  • A
                                    A
                                    akbooer
                                    Oh no! Lousy timing, I just bought some...
                                    ... in fact, they arrived today.
                                    Speaking of which, whilst I got them to run the default sketch, do I actually need a programmer to do anything different, or can this be done OTA (from a Mac) ?
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @akbooer
                                      The default sketch doesn't support OTA, as it wasn't available in the stable branch at the time of launch
                                      • 5546dug5
                                        5546dug5
                                        5546dug
                                        @tbowmo Good sales but did not see the Sensebender too bad .
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @akbooer
                                          It's here http://www.itead.cc/mysensors-micro.html
