  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @ahmedadelhosni
    What @Anticimex said.. And at the time when I created the sensebender, I didn't know that the interrupt wasn't used (I was relatively new to the project) so I thought that we had to have it connected..
      It is used by the RF69, right @tbowmo? (when using adapter plate...)
      • AnticimexA Anticimex
        @ahmedadelhosni because it is not in use by the library <yet>. Would be a shame if the library some day gets updated with support for a radio that can enter low power sleep and still wake when needed.
        ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        wrote on last edited by ahmedadelhosni
        #383
        @Anticimex @tbowmo This a valid point which I thought of but I needed two interrupt pins. As far as I knew from fast searching is that external interrupts which react to CHANGE in pin state are only valid for pins 2 and 3. Correct ?
        Maybe there is another solution which I missed.
        • tbowmoT
          tbowmoT
          tbowmo
          @hek
          Yes, that's right, RFM69 is using interrupts.. (and rfm69 is possible on the sensebender using for example this pcb)
          • AnticimexA
            AnticimexA
            Anticimex
            And with a scalpel and a soldering iron you should be able to use both interrupts by disconnecting the one reserved for nrf24. Of course that would disable the use for rfm69 om that board.
            ahmedadelhosniA 1 Reply Last reply
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              @Anticimex Yeah I could just connect my device to the atmega pin directly as I can see/find any pin header to route the interrupt pin 2. They are all used.
              Thanks guys.
              • TheoLT
                TheoLT
                TheoL
                I just received two sensebenders. I'm really impressed by the great engineering behind the board. I can't wait to heat up my soldering iron. I love them!
                • user2334U
                  user2334U
                  user2334
                  wrote on last edited by user2334
                  #388
                  I just received two Sensebenders, but have problems getting the device to consume little power. I get totally different values as displayed above.
                  With the following sketch, I get about 5,6mA in active state and 1,6mA in sleep mode with nRF24 attached. I have compared different nRF24-chips and this one consumed the least power.
                  Without the nRF24, I get 4mA and 0,025mA (=25µA) during sleep mode.
                  #include <LowPower.h>
                  #include "RF24.h"
                  RF24 radio(9, 10);
                      delay(8000);
                      LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
                  mfalkviddM user2334U 2 Replies Last reply
                  • user2334U user2334
                    #include "RF24.h"
                    RF24 radio(9, 10);
                        delay(8000);
                    @user2334 I don't think the LowPower library shuts off the radio. Use MySensor's sleep function instead.
                    • ximinezX
                      ximinezX
                      ximinez
                      A general question regarding these types of boards that are generally designed to be used on battery power. Is there a reason to not power the ATSH204A and Si7021 from AVR pins? The pins can source far more than what these devices can sink (even when using the heating on the Si7021), and it would allow squeezing a tiny bit more out of the battery life by selectively powering down the devices.
                      Eg., if I'm not using the ATSHA204A at all, I can save 150nA continuous current. The power saving from disabling the Si7021 is less at about 60nA, so that might just be eaten up by having to wait up to 80ms before a full conversion.
                      I'm aware that we're talking about saving a tiny ~200nA here, but over the span of two years that adds up to about 350mAh.
                      So what I'm wondering is simply, is there a technical reason saying that this really isn't a Good Idea (tm)? Should I avoid doing so if I design my own similar device?
                      L tbowmoT 2 Replies Last reply
                      • ximinezX ximinez
                        L
                        L
                        LastSamurai
                        I second that question. I was just thinking about a similar idea.
                        • ximinezX ximinez
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @ximinez @LastSamurai
                          That is indeed a good question. The straight answer is that I didn't think about that when I designed the board.
                          In theory you could also power the radio from a digital pin on the avr, and power that down completely.
                          BTW. If you turn on the heating element in the si7021 at full power, I think the power drain exceeds what the avr can deliver on a digital pin. But one could just avoid that.
                          ximinezX 1 Reply Last reply
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            I have been thinking about this as well. But I discarded parts of the idea because I needed the IO for other stuff (MYSX in my case). Instead I designed a switched rail where one could attach sensor power sinks. It's not io powered but it is io controlled.
                            Though I did not attach the si or atsha to this switch function as I decided to make it an optional feature but wanted to make sure authentication and temp/hum would always be available.
                            • tbowmoT tbowmo
                              ximinezX
                              ximinezX
                              ximinez
                              Oh, I thought it was a design decision :)
                              I've been wondering about the radio in particular. Does the radio keep any state locally, and will it have to be reinitialized upon powerup?
                              The heating element eats a measly 3.1mA according to the datasheet, so even that would be well within the limits for a single in on a 328p.
                              Now, I don't have Eagle installed on this laptop, and my bandwidth is limited right now. Is there a picture of the PCB traces available? Wondering if atleast some of this can be hacked on by cutting traces.
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @ximinez
                                Nope, there are only the eagle design files.. (Or gerbers, you could use a gerber viewer)
                                I have 4 sensors operating for almost a year on two AA batteries, they all report around 73% battery left. So in my opinion, it's not that necessary to do extra optimization on the power drain..
                                • tbowmoT tbowmo
                                  @ximinez
                                  ximinezX
                                  ximinezX
                                  ximinez
                                  @tbowmo
                                  While 73% after one year is good, it doesn't mean that it can't get better. The ATSHA204a and Si7021 draw about 350mAh from the battery over two years from idling alone. The NRF24L01+ draws around 1500mAh.
                                  Remember, you will never get close to emptying out the battery before the voltage drops below working voltage. Using alkaline batteries, you'll get around 2000mAh before the batteries reach 2v (which, if you're using battery voltage as a pure percentage, is 66%), at which point the voltage curve drops sharply - and your sensors die. The radio and sensors have drawn more than 900mAh from your battery during the year you have run the device (and that's just idling) - close to half your battery life.
                                  Assuming your battery percentage is correct, and you started at 100% one year ago, I'm betting your sensors will die sometime during this summer. While you may think that extra optimization isn't worth it, I do. The nanoAmp draws may not seem like much, but drawn out on a timescale like this, it is a major power draw.
                                  AnticimexA 1 Reply Last reply
                                  • ximinezX ximinez
                                    @tbowmo
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @ximinez That depend on how you define battery percentage. I have chosen to adjust my measurements to let 0% mean when voltage drops below the highest requirements of the onboard devices. Since that particular device will fail when voltage goes lower, it serves no purpose to provide a false battery percentage. 0% is when the node no longer operates according to specs. But this is of course hw/sketch-dependent.
                                      ximinezX
                                      ximinezX
                                      ximinez
                                      wrote on last edited by ximinez
                                      #398
                                      @Anticimex The point still stands however. The discharge graph is far from linear, and your sensors and radio have already drawn close to half of your battery life by idling alone. A colleague of mine has had to replace the batteries in his two sensors already.
                                      • ximinezX ximinez
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @ximinez I do not recall sharing my statistics, so I assume you refer to @tbowmo's stats?
                                          ximinezX
                                          ximinezX
                                          ximinez
                                          @Anticimex Ah, yes. sed /your/@tbowmo's/g. I blame lack of caffeine.
