  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • AnticimexA Anticimex
    @ahmedadelhosni because it is not in use by the library <yet>. Would be a shame if the library some day gets updated with support for a radio that can enter low power sleep and still wake when needed.
    ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    wrote on last edited by ahmedadelhosni
    #383
    @Anticimex @tbowmo This a valid point which I thought of but I needed two interrupt pins. As far as I knew from fast searching is that external interrupts which react to CHANGE in pin state are only valid for pins 2 and 3. Correct ?
    Maybe there is another solution which I missed.
    • tbowmoT
      tbowmoT
      tbowmo
      @hek
      Yes, that's right, RFM69 is using interrupts.. (and rfm69 is possible on the sensebender using for example this pcb)
      • AnticimexA
        AnticimexA
        Anticimex
        And with a scalpel and a soldering iron you should be able to use both interrupts by disconnecting the one reserved for nrf24. Of course that would disable the use for rfm69 om that board.
          ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          @Anticimex Yeah I could just connect my device to the atmega pin directly as I can see/find any pin header to route the interrupt pin 2. They are all used.
          Thanks guys.
          • TheoLT
            TheoLT
            TheoL
            I just received two sensebenders. I'm really impressed by the great engineering behind the board. I can't wait to heat up my soldering iron. I love them!
            • user2334U
              user2334U
              user2334
              wrote on last edited by user2334
              #388
              I just received two Sensebenders, but have problems getting the device to consume little power. I get totally different values as displayed above.
              #include <LowPower.h>
              #include "RF24.h"
              RF24 radio(9, 10);
                  delay(8000);
              mfalkviddM user2334U 2 Replies Last reply
              • user2334U user2334
                #include "RF24.h"
                RF24 radio(9, 10);
                    delay(8000);
                @user2334 I don't think the LowPower library shuts off the radio. Use MySensor's sleep function instead.
                • ximinezX
                  ximinezX
                  ximinez
                  A general question regarding these types of boards that are generally designed to be used on battery power. Is there a reason to not power the ATSH204A and Si7021 from AVR pins? The pins can source far more than what these devices can sink (even when using the heating on the Si7021), and it would allow squeezing a tiny bit more out of the battery life by selectively powering down the devices.
                  Eg., if I'm not using the ATSHA204A at all, I can save 150nA continuous current. The power saving from disabling the Si7021 is less at about 60nA, so that might just be eaten up by having to wait up to 80ms before a full conversion.
                  I'm aware that we're talking about saving a tiny ~200nA here, but over the span of two years that adds up to about 350mAh.
                  So what I'm wondering is simply, is there a technical reason saying that this really isn't a Good Idea (tm)? Should I avoid doing so if I design my own similar device?
                  L tbowmoT 2 Replies Last reply
                  • ximinezX ximinez
                    L
                    L
                    LastSamurai
                    I second that question. I was just thinking about a similar idea.
                    • ximinezX ximinez
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @ximinez @LastSamurai
                      That is indeed a good question. The straight answer is that I didn't think about that when I designed the board.
                      In theory you could also power the radio from a digital pin on the avr, and power that down completely.
                      BTW. If you turn on the heating element in the si7021 at full power, I think the power drain exceeds what the avr can deliver on a digital pin. But one could just avoid that.
                      ximinezX 1 Reply Last reply
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        I have been thinking about this as well. But I discarded parts of the idea because I needed the IO for other stuff (MYSX in my case). Instead I designed a switched rail where one could attach sensor power sinks. It's not io powered but it is io controlled.
                        Though I did not attach the si or atsha to this switch function as I decided to make it an optional feature but wanted to make sure authentication and temp/hum would always be available.
                        • tbowmoT tbowmo
                          ximinezX
                          ximinezX
                          ximinez
                          Oh, I thought it was a design decision :)
                          I've been wondering about the radio in particular. Does the radio keep any state locally, and will it have to be reinitialized upon powerup?
                          The heating element eats a measly 3.1mA according to the datasheet, so even that would be well within the limits for a single in on a 328p.
                          Now, I don't have Eagle installed on this laptop, and my bandwidth is limited right now. Is there a picture of the PCB traces available? Wondering if atleast some of this can be hacked on by cutting traces.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @ximinez
                            Nope, there are only the eagle design files.. (Or gerbers, you could use a gerber viewer)
                            I have 4 sensors operating for almost a year on two AA batteries, they all report around 73% battery left. So in my opinion, it's not that necessary to do extra optimization on the power drain..
                            • tbowmoT tbowmo
                              @ximinez
                              ximinezX
                              ximinezX
                              ximinez
                              @tbowmo
                              While 73% after one year is good, it doesn't mean that it can't get better. The ATSHA204a and Si7021 draw about 350mAh from the battery over two years from idling alone. The NRF24L01+ draws around 1500mAh.
                              Remember, you will never get close to emptying out the battery before the voltage drops below working voltage. Using alkaline batteries, you'll get around 2000mAh before the batteries reach 2v (which, if you're using battery voltage as a pure percentage, is 66%), at which point the voltage curve drops sharply - and your sensors die. The radio and sensors have drawn more than 900mAh from your battery during the year you have run the device (and that's just idling) - close to half your battery life.
                              Assuming your battery percentage is correct, and you started at 100% one year ago, I'm betting your sensors will die sometime during this summer. While you may think that extra optimization isn't worth it, I do. The nanoAmp draws may not seem like much, but drawn out on a timescale like this, it is a major power draw.
                              AnticimexA 1 Reply Last reply
                              • ximinezX ximinez
                                @tbowmo
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @ximinez That depend on how you define battery percentage. I have chosen to adjust my measurements to let 0% mean when voltage drops below the highest requirements of the onboard devices. Since that particular device will fail when voltage goes lower, it serves no purpose to provide a false battery percentage. 0% is when the node no longer operates according to specs. But this is of course hw/sketch-dependent.
                                  ximinezX
                                  ximinezX
                                  ximinez
                                  wrote on last edited by ximinez
                                  #398
                                  @Anticimex The point still stands however. The discharge graph is far from linear, and your sensors and radio have already drawn close to half of your battery life by idling alone. A colleague of mine has had to replace the batteries in his two sensors already.
                                  • ximinezX ximinez
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @ximinez I do not recall sharing my statistics, so I assume you refer to @tbowmo's stats?
                                      ximinezX
                                      ximinezX
                                      ximinez
                                      @Anticimex Ah, yes. sed /your/@tbowmo's/g. I blame lack of caffeine.
                                      • ximinezX ximinez
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @ximinez makes sense. I'm sure you can cut down on power consumption by cutting power to those peripherals. I do not know how signing would be affected by this though, as I have not tested it with switching the atsha on and off between calls. I would like to hear from you on that topic if you choose to try it though :)
                                          ximinezX
                                          ximinezX
                                          ximinez
                                          Ok, I've been looking at the image and my spare sensor. It looks like:
                                          Power to the NRF can be cut between C3 and VCC pin.
                                          ATSHA204a power can be cut on the trace that goes from the atsha and beneath the flash.
                                          Si7021 power can be cut at the trace that goes from C4.
                                          I just might have to dig out my scalpel and iron for this. If the components magically work without any extra initialization on powerup, modifying the code looks easy.
                                          I'll report back with my findings
