  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • FotoFieberF FotoFieber
    @Anticimex
    Thx. This is an old version. I found a newer on my hard drive (old development branch). As I do only need temp/hum, I reduced the sketch and it is working fine.
    AnticimexA
    AnticimexA
    Anticimex
    @FotoFieber @tbowmo isn't the one in the SenseBender repo supposed to be the latest&greatest?
    • tbowmoT
      tbowmoT
      tbowmo
      @Anticimex @FotoFieber
      Yup, it was moved over from development branch on the release night. So should be the latest and greatest
      • J
        J
        jovo
        Hi!
        I am in process of upgrading my Sensebenders to V2.0 and like to enable the OTA function.
        Who can give me some pointers on the capabilities of OTA for this Sensebender Micro board?
        I know that has external flash for this purpose, but i am stuggling a bit finding how to use it.
        So I am keen to read information on dependencies of the Sensebender sketch as well as the controller options.
        My environment:
        6x Sensebender
        Wifi based Gateway
        Domoticz as controller
        Things I like to know:
        • Is my sensebender shipped with optiboot bootloader? (have them about 1 year now)?
        • do i require special Gateway software? (i noticed a sketch called something like GatewayESP8266OTA)
        • what can i expect from Domoticz? probably not much, so do i need to connect to another controller (e.g. MYSController) to perform an update?
        • What controller is advised for the standard bootloader (optiboot bootloader)?
        I am sure those things are discussed in the past, but I was unable to find it.
        Would be great if somebody can share a howto or wiki on this topic.
        thanks in advance
        • tbowmoT
          tbowmoT
          tbowmo
          @jovo
          Sensebender is delivered with "DualOptiboot" which uses the external flash.
          To enable OTA with 2.0.0, you have to compile your sketches with
          #define MY_OTA_FIRMWARE_FEATURE
          enabled. For controller / Gateway, you need something else than domoticz. I haven't tried OTA firmware upgrades myself yet, so I do not have any experience with what works, and what doesn't work, other than the fact that domoticz doesn't support OTA..
          TheoLT 1 Reply Last reply
          • tbowmoT tbowmo
            @jovo
            TheoLT
            TheoLT
            TheoL
            Today I soldered the headers to a new sensebender and try to start it. I've uploaded the 2.0 example but it can't find the gateway:
            Started
            Starting sensor (RNONA-, 2.0.0)
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            My other sense benders worked flawelessly. But this one can't communicate. Does anyone have any idea, what might be wrong?
            alexsh1A Q 2 Replies Last reply
            • TheoLT TheoL
              Started
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              alexsh1A
              alexsh1A
              alexsh1
              @TheoL I have exactly the same issue with one of the nodes though not the sensebender.
              All other nodes work just fine.
              Take a look:
              https://forum.mysensors.org/topic/4723/tsp-chkupl-fail
              • TheoLT TheoL
                Started
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                Q
                Q
                Qu3Uk
                @TheoL I had this problem last night, its unable to find the parent/gateway. I ended up swapping out the radio with one I'd extended the antenna on and it worked. I then attached a piece of wire to the original radio and that was worked too. I put it down to knock off components.
                I think there is a video detailing the correct length etc.
                • TheoLT
                  TheoLT
                  TheoL
                  Solved. I had forgotten to config the correct baudrate. My network is on one 1 mbyte, because of the mixed NRF24L01 and NRF24L01+ radios.
                  • stefaanvS
                    stefaanvS
                    stefaanv
                    I get "not in sync" errors from avrdude if I try uploading a sketch to the sensorbender.
                    I do have correct serial communication, when I open the serial monitor, I get the info from the default sketch (which unfortunately uses the 1.4.1 API).
                    I tried with a different SenseBender board, same result. Tried with an older IDE version (1.6.9) on an other computer, same result.
                    Any suggestions ?
                    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x20
                    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2d
                    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x20
                    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4f
                    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6e
                    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6c
                    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x69
                    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6e
                    An error occurred while uploading the sketch
                    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x65
                    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x21
                    alexsh1A 1 Reply Last reply
                    • stefaanvS stefaanv
                      Any suggestions ?
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @stefaanv sounds like you have a wrong board in Arduino. Did you install the correct board in Arduino IDE? I'm programming the Sensebender in 1.6.9 via the FTDI adapter without any difficulties
                      stefaanvS 1 Reply Last reply
                      • alexsh1A alexsh1
                        stefaanvS
                        stefaanvS
                        stefaanv
                        @alexsh1 I'm using the Uno board. Which one should I use ? Can't find anything in the SenseBender page.
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @stefaanv well, that's the problem - you must install Sensebender Micro (or I think you can use Arduino Pro Mini 3.3V) board. You MUST NOT provide more than 3.3V otherwise you may damage the board or radio. Please double check
                          Please refer to this link below to install the correct board in Arduino:
                          https://github.com/mysensors/ArduinoBoards
                          • alexsh1A alexsh1
                            stefaanvS
                            stefaanvS
                            stefaanv
                            @alexsh1 Thanks, got it working now.
                            • J
                              J
                              jovo
                              Is there anybody who can comment if the battery usage is increased in V2.0?
                              I feel that my batteries are draining faster then with 1.4 I had installed before.
                              Also I am seeing issues with the Force Retransmit. I dont see this working either. it just transmits when Transmit_Treshhold is kicked.
                              My sketch is pretty default. As far as I can see, I only turned Batt_Sensor on.
                              M 1 Reply Last reply
                              • J jovo
                                mvader
                                @jovo what is your usage? I'm getting 8+ months easily
                                I have a sensor in my deep freeze, been there for 8+ months and still working fine.
                                J 1 Reply Last reply
                                • M mvader
                                  J
                                  J
                                  jovo
                                  @mvader Hi,
                                  I guess you are not for 8 months on v2?
                                  I had a long time on the previous version as well.
                                  Haven't done the measurements, but I noticed my batteries were depleted quickly since v2 was on.
                                  I am more concerned about the fact that the force transmission doesn't seem to be working.
                                  • J jovo
                                    @mvader Hi,
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @jovo how exactly do you define "quicker" please? I do not think anyone had enough time to test it. My batteries dropped 0.2V for 2 months (reporting temp/humidity/pressure every minute) but that does not mean anything at all. I would need to run it for another 6 months at least to say what I think.
                                    • Mitja BlazinsekM
                                      Mitja BlazinsekM
                                      Mitja Blazinsek
                                      i have some problems with sensbender micro it all work fine it shows temp and hum in mycontroller bu then i try to program the board to test my FTDI programmer, for test i was try to upload default sketch but since then it showing me only node in mycontroller without any sensors :(
                                      this is my log from debug:
                                      0 MCO:BGN:INIT NODE,CP=RNONA--,VER=2.1.1
                                      4 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      12 TSM:INIT:TSP OK
                                      14 TSF:SID:OK,ID=5
                                      16 TSM:FPAR
                                      53 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2062 !TSM:FPAR:NO REPLY
                                      2064 TSM:FPAR
                                      2101 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      4110 !TSM:FPAR:NO REPLY
                                      4112 TSM:FPAR
                                      4149 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      6158 !TSM:FPAR:NO REPLY
                                      6160 TSM:FPAR
                                      6197 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      8206 !TSM:FPAR:FAIL
                                      8208 TSM:FAIL:CNT=1
                                      8210 TSM:FAIL:PDT
                                      18214 TSM:FAIL:RE-INIT
                                      18216 TSM:INIT
                                      18225 TSM:INIT:TSP OK
                                      18227 TSF:SID:OK,ID=5
                                      18229 TSM:FPAR
                                        That looks like there is no communication with gateway. Did you check gw log? You could also update mysensors to latest 2.2
                                        • Mitja BlazinsekM
                                          Mitja BlazinsekM
                                          Mitja Blazinsek
                                          but before it was working im using sensebender gateway and i see node in controler, i update my sensors and still nothing
