  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
    mvader
    @hek said:
    A->flash requires sketches running library code from the development branch (which it isn't currently). The boards comes
    thanks for the info. I was hoping i wouldn't have to connect up my programmer.. oh well.
      mvader
      I guess these can't be programmed, if my programmer doesn't have a DTR line?
      was hoping OTA would work :)
      I'll order a new programmer any way, but if there is any other way let me know.
      I tried starting it in test mode. but that didn't work
      • tbowmoT
        tbowmoT
        tbowmo
        @mvader
        It's using a standard ftdi header, as used in the arduino mini pro.
        About the testmode, you should hold A0 to GND, while applying power to the unit. Then it starts spewing data to the serial port.
        M 1 Reply Last reply
        • F
          F
          Fabien
          Just recieve my 5 sensbender today. Workin fine after some problem with nrf24L01 and Arduino uno (+3.3V doesn't work)
          • tbowmoT
            tbowmoT
            tbowmo
            It's almost too easy to setup a sensor network (for temperature and humidity) now.
            solder a socket for the NRF module, a battery holder. Plug in the NRF module, put batteries in, and you have a sensor online. (I have 3 sensebenders from tiead online at the moment, together with 2 prototypes). Need to get some more battery holders, before I can make more sensors now.
            blaceyB 1 Reply Last reply
            • tbowmoT tbowmo
              blaceyB
              blaceyB
              blacey
              I agree! I ordered 4 from the second ITead batch (I let others get their hands on the first batch because I already had a couple OSHPark deployed) and had the first sensor up and running in no time! Great job and contribution to the MySensor's community! :+1: :+1: :+1:
              • tbowmoT
                tbowmoT
                tbowmo
                @blacey
                Thanks.. It's actually kind of fun, when I see that things I have created, actually brings value to other people.. Always been a driving force for me (no matter what I have had my hands in, whether it's software of various types,VHF radios for ships, mobile phones, bluetooth headsets, or sensor modules :) )
                • tbowmoT tbowmo
                  @mvader
                  mvader
                  @tbowmo said:
                  @mvader
                  I had meant that i put it in test mode to try and program it.
                  getting it in test mode worked. i could see the led blinking.
                  however when i gave up and put the radio back on and turn it on, i guess it had actually taken my upload.
                  it was reporting in F now.
                  so i know the DTR does the auto reset, i guess upload works, but no reset and/or completed msg in the IDE.
                  i ordered a new programmer anyway with DTR.
                  • nutcrackerN
                    nutcrackerN
                    nutcracker
                    wrote on last edited by nutcracker
                    #149
                    I've received some boards and all working good.
                    I'd like to upload a new sketch to the Sensebender Micro board and I'm attempting to do this via the FTDI FT232RL USB to TTL serial converter adapter that I purchased here (http://www.ebay.co.uk/itm/221552218333).
                    Could someone kindly confirm the pin to pin mapping between the FTDI board and the Senseboard Micro as when I attempt to upload I receive the message:
                       Programmer Type : butterfly
                             Description     : Atmel AppNote AVR109 Boot Loader
                    Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
                    Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
                    I'm using Arduino 1.6.5 running on Windows 8.1 (inside parallels on a Mac).
                    Any ideas?
                    Thank you
                    Nutz
                    hekH 1 Reply Last reply
                    • nutcrackerN nutcracker
                      Any ideas?
                      Thank you
                      Nutz
                      @nutcracker
                      I usually use the GND pin as a guide.
                      What happens if you run Arduino IDE directly in your native OS?
                      • nutcrackerN
                        nutcrackerN
                        nutcracker
                        #151
                        Thanks @hek. I've had to run Arduino on Windows before because of compatibility issues with certain chip sets on Arduino boards and I didn't fancy running unsigned drivers on my Mac to resolve... I'm able to upload sketches to other boards with no issues.
                        That said, I've updated Arduino to 1.6.5 on my Mac and have attempted to upload the default Sensebendermicro.ino sketch to the micro with a similar error:
                        Arduino: 1.6.5 (Mac OS X), Board: "Arduino Micro"
                        Build options changed, rebuilding all
                        Sketch uses 26,414 bytes (92%) of program storage space. Maximum is 28,672 bytes.
                        Global variables use 799 bytes (31%) of dynamic memory, leaving 1,761 bytes for local variables. Maximum is 2,560 bytes.
                        Found programmer: Id = "�d��b�"; type = F
                            Software Version = �.�; Hardware Version = �.�
                        avrdude: error: buffered memory access not supported. Maybe it isn't
                        a butterfly/AVR109 but a AVR910 device?
                          enabled in File > Preferences.
                        With verbose output enabled:
                        avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
                                 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                                 Copyright (c) 2007-2009 Joerg Wunsch
                                 System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
                                 User configuration file is "/Users/nutcracker/.avrduderc"
                                 User configuration file does not exist or is not a regular file, skipping
                                 Using Port                    : /dev/cu.usbserial-A50285BI
                                 Using Programmer              : avr109
                                 Overriding Baud Rate          : 57600
                                 AVR Part                      : ATmega32U4
                                 Chip Erase delay              : 9000 us
                                 PAGEL                         : PD7
                                 BS2                           : PA0
                                 RESET disposition             : dedicated
                                 RETRY pulse                   : SCK
                                 serial program mode           : yes
                                 parallel program mode         : yes
                                 Timeout                       : 200
                                 StabDelay                     : 100
                                 CmdexeDelay                   : 25
                                 SyncLoops                     : 32
                                 ByteDelay                     : 0
                                 PollIndex                     : 3
                                 PollValue                     : 0x53
                                 Memory Detail                 :
                                                          Block Poll               Page                       Polled
                                   Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                                   eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
                                   flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
                                   lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                   hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                   efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                   lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                   calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                                   signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                        Nutz
                          @nutcracker said:
                          Maybe it isn't
                          Is your programmer setting in Arduino IDE set to "USBasp"?
                          • nutcrackerN
                            nutcrackerN
                            nutcracker
                            Hi @hek, I've never had to change the programmer setting before... I've changed it to USBasp and re-uploaded but same error. I've always used the menu options Sketch=>Upload to upload a sketch to the board. Should I be using Sketch=>Upload via programmer for this micro board ? If so, that fails too but something to do with it not being able to find the USB device.
                                     Using Port                    : usb
                                     Using Programmer              : usbasp
                            avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
                            avrdude done.  Thank you.
                            Nutz
                              Hmm. I think I understand what the problem is now. You've selected the "Arduino Micro" board. Not our "MySensors/Sensebender Micro" .
                              Did you follow the instructions here?
                              http://www.mysensors.org/hardware/micro-ide-setup
                              • nutcrackerN
                                nutcrackerN
                                nutcracker
                                Thanks @hek, I also realised my mistake once I retraced my steps...I hadn't scrolled down fully on that screenshot that shows the Sensebender Micro board... I think what through me is that screenshot also shows a "dot" against another board - the Arduino Micro board...and I was selecting that... duh! (may be worth changing the screenshot? ;))
                                Anyway, thanks for your help...sketch uploaded perfectly after that!
                                         Using Programmer              : arduino
                                         AVR Part                      : ATmega328P
                                         PAGEL                         : PD7
                                         BS2                           : PC2
                                         RETRY pulse                   : SCK
                                         Timeout                       : 200
                                         StabDelay                     : 100
                                         CmdexeDelay                   : 25
                                         SyncLoops                     : 32
                                         ByteDelay                     : 0
                                         PollIndex                     : 3
                                         PollValue                     : 0x53
                                         Memory Detail                 :
                                           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                                           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                                           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                         Programmer Type : Arduino
                                         Description     : Arduino
                                         Hardware Version: 3
                                         Firmware Version: 5.0
                                         Vtarget         : 0.3 V
                                         Varef           : 0.3 V
                                         Oscillator      : 28.800 kHz
                                         SCK period      : 3.3 us
                                avrdude: AVR device initialized and ready to accept instructions
                                Reading | ################################################## | 100% 0.00s
                                avrdude: Device signature = 0x1e950f
                                avrdude: reading input file "/var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex"
                                avrdude: writing flash (23678 bytes):
                                Writing | ################################################## | 100% 8.84s
                                avrdude: 23678 bytes of flash written
                                avrdude: verifying flash memory against /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex:
                                avrdude: load data flash data from input file /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex:
                                avrdude: input file /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex contains 23678 bytes
                                avrdude: reading on-chip flash data:
                                Reading | ################################################## | 100% 9.94s
                                avrdude: verifying ...
                                avrdude: 23678 bytes of flash verified
                                Cheers!
                                Nutz
                                  Ah... there is a dot in the menu-image. Will update it. Thanks.
                                  RJ_MakeR 1 Reply Last reply
                                    RJ_MakeR
                                    RJ_MakeR
                                    RJ_Make
                                    @hek Interesting.. I didn't know this.. I used the standard Pro Mini 3v3 and it worked...????
                                    RJ_Make
                                    • G
                                      G
                                      gloob
                                      Received my Micros today. Luckily there was no custom and a lot of pins to solder. Can't wait to solder them on wednesday on work and test them.
                                      Is there any instruction how to solder everything? On which side the radio module needs to be soldered.
                                      tbowmoT 1 Reply Last reply
                                      • G gloob
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        #159
                                        @gloob
                                        This might help you out :)
                                        • G
                                          G
                                          gbfromhb
                                          I hope this question has not been answered already and I did not miss the answer. I was thinking about connecting a motion sensor to this and was hoping that one of the digital pins supports an interrupt. Is there an interrupt available?
