  3. DHT22 and DS18b20 on same node: DS shows up with Humidity now.
15 Posts 8 Posters 10.7k Views 5 Watching
  • J
    J
    jbishop129
    Hey guys,
    I'm new to MySensors but not Arduino in general. I'm using several MySensors nodes with RF24L01+ radios, talking thru a MySensors USB/Serial Gateway to my Domoticz server on a rPi. I can easily add nodes and they auto-register in Domoticz, and all is well.
    One issue I'm still scratching my head on, is I have a node that consists of a DHT22 temp+hum, two OneWire DS18b20/Dallas temp sensors, and a IR motion sensor. They all work fine and report good data, but the Dallas temp sensors show up in Domoticz as temp+hum. Reading the graphs over time, the data is real, and it is actually just pairing up its' temp with the humidity reading from the DHT22, on all three of the temp sensors. Now, in some regard, I suppose it's handy that it combines that data, but since the Dallas temp probes are actually measuring temp in a different area, it's not desirable for me to report the humidity on those sensors, since the reading is not actually "at" the sensor location for those particular Dallas sensors.
    When looking at the logic of the MySensors code, it makes sense, since all of the data coming from that one node is a child of the overall node. So with that, is there a way to parse off the DHT22 in code so it presents as its' own Node, so its' temp+hum will be child nodes, then the other sensors can present as a Node (two Dallas temps, and motion)? I am thinking that would pass thru the gateway to my Domoticz server, it would think they are separate nodes, and not combine data.
    Here's my sketch in question; it's hacked together from two example sketches. Any advice would be appreciated!
    #include <DHT.h>
    #include <OneWire.h>
    #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOT 2   // Id of the sensor child
    #define CHILD_ID_DS1 3
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
    OneWire oneWire(ONE_WIRE_BUS);
    DHT dht;
    float lastTemp;
    float lastHum;
    int numSensors=0;
    boolean metric = false;
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
    MyMessage msgOneWire(0, V_TEMP);
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Temp/Humidity/Motion", "1.0");
      gw.present(CHILD_ID_MOT, S_MOTION);
      for (int j=CHILD_ID_DS1; j < (numSensors + CHILD_ID_DS1) && j<MAX_ATTACHED_DS18B20; j++) {
      gw.present(j, S_TEMP);
      gw.process();
      // Read digital motion value
      Serial.print("Motion: ");
      Serial.println(tripped);
      gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric){
        Serial.print("DHT Temp: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("DHT RH: ");
          Serial.println(humidity);
      for (int i=0; i < numSensors && i<MAX_ATTACHED_DS18B20; i++) {
    //int i = 0;
        float temp = static_cast<float>(static_cast<int>((sensors.getTempCByIndex(i)) * 10.)) / 10.;
        if (lastTemperature[i] != temp && temp != -127.00) {
          Serial.print("DS");
          Serial.print(i);
          Serial.print(": ");
          Serial.println(temp);
          gw.send(msgOneWire.setSensor(i+CHILD_ID_DS1).set(temp, 1));
          lastTemperature[i]=temp;
      // Sleep until interrupt comes in on motion sensor. Send update every two minutes.
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    T 1 Reply Last reply
    • J jbishop129
      Hey guys,
      #include <DHT.h>
      DHT dht;
      float lastTemp;
      float lastHum;
      int numSensors=0;
        sensors.begin();
        gw.begin();
        gw.process();
          if (!metric){
            lastHum = humidity;
      //int i = 0;
            Serial.print("DS");
            Serial.print(i);
            Serial.print(": ");
      torfinn
      @jbishop129 Hi I am sorry have the same problem but have not found any solution to it yet.
      • A
        A
        andriej
        Until Domoticz team doesn't fix it, there's no solution.
        Even registering second ID for arduino didn't solve problem.
        • T
          torfinn
          Seems to be related to the domoticz gateway. Also tried to downgrade to the first version that supported Arduino as serial controller but same problem. Strange thing is that if you restart controller and only present temp in the sketch its working until you present the humidity??
          • T
            torfinn
            Hi ! You can get a partly workaround using V_DUST_LEVEL or something instead of V_HUM.
            • Z
              Z
              zampedro
              This is a really annoying thing.
              I finally decided to modify the Domoticz sources, and now
              temperature shows up with humidity only if they have
              consecutive ID, otherwise they are shown separated.
              miljumeM 1 Reply Last reply
              • Z zampedro
                miljumeM
                miljumeM
                miljume
                @zampedro I have exactly the same problem
                Could you please tell me more of how you modified Domoticz source?
                This bug is really annoying!
                Regards,
                Mikael
                AWIA 1 Reply Last reply
                • miljumeM miljume
                  Regards,
                  Mikael
                  AWIA
                  AWIA
                  AWI
                  @miljume Domoticz developers consider this a feature... not a bug ;-)
                    I get a similar problem on my plant monitoring. The graph always says "Temperature" even though the sensors only report humidity. I need to explain it every time I show the graphs to anyone.
                    • Z
                      Z
                      zampedro
                      I modified MySensorBase.cpp
                      void MySensorsBase::SendSensor2Domoticz
                      case V_TEMP:
                      at lines 595 and 603 (numbers from last git code) for Temperature
                      // SendTempHumBaroSensorFloat(cNode, pChild->batValue, Temp, Humidity, Baro, nforecast, (!pChild->childName.empty()) ? pChild->childName : "TempHumBaro");
                      if ( (pChildHum->childID+1)== pChild->childID)
                      else
                      SendTempSensor(cNode, pChild->batValue, Temp, (!pChild->childName.empty()) ? pChild->childName : "Temp");
                      // SendTempHumSensor(cNode, pChild->batValue, Temp, Humidity, (!pChild->childName.empty()) ? pChild->childName : "TempHum");
                      else
                      case V_HUM:
                      at lines 678 and 686 for Humidity
                      // SendTempHumBaroSensorFloat(cNode, pChildTemp->batValue, Temp, Humidity, Baro, nforecast, (!pChild->childName.empty()) ? pChild->childName : "TempHumBaro");
                      if ( (pChild->childID+1)== pChildTemp->childID)
                      else
                      SendHumiditySensor(cNode, pChild->batValue, Humidity, (!pChild->childName.empty()) ? pChild->childName : "Hum");
                      // SendTempHumSensor(cNode, pChildTemp->batValue, Temp, Humidity, (!pChild->childName.empty()) ? pChild->childName : "TempHum");
                      else
                      In this way hum+temp of DHT11 are shown together ( CHILD_ID_HUM +1 == CHILD_ID_TEMP ) and
                      temperatures from ds18b20 are alone in separate widgets.
                      #define CHILD_ID_HUM 9 // DHT11
                      #define CHILD_ID_TEMP 10 // DHT11
                      #define DS18B20_STARTID 15 // DS18B20
                      Regards
                      palande.vaibhavP 1 Reply Last reply
                      • miljumeM
                        miljumeM
                        miljume
                        wrote on last edited by miljume
                        @zampedro Sounds perfect, is there any chance this change can be merged into the source of Domoticz?
                        • Z zampedro
                          case V_TEMP:
                          else
                          else
                          case V_HUM:
                          else
                          else
                          Regards
                          palande.vaibhavP
                          palande.vaibhavP
                          palande.vaibhav
                          case V_TEMP:
                          else
                          else
                          case V_HUM:
                          else
                          else
                          Regards
                          Where can I find the MySensorsBase.cpp? I am running domoticz on windows and in the installation folder I can't find the file. I can see the file on GitHub but how do I install domoticz from GitHub?
                          Z 1 Reply Last reply
                          • palande.vaibhavP palande.vaibhav
                            case V_TEMP:
                            else
                            else
                            case V_HUM:
                            else
                            else
                            Regards
                            Z
                            Z
                            zampedro
                            @palande.vaibhav You have to compile domoticz from source, highly recommended if
                            you run it on raspberry, orangepi etc...
                            • Z zampedro
                              AWIA
                              AWIA
                              AWI
                              @zampedro Please have a look at this thread. The "combination issue" is discussed and solved. There is no reason to compile Domoticz yourself when running on Raspberry. I discourage compiling yourself (unless you like the excercise). The precompiled image works out of the box.
                              • AWIA AWI
                                Z
                                Z
                                zampedro
                                @AWI Thanks for the hint.
                                I thought this wasn't a "issue" but just a "really annoying thing".
                                However i run domoticz on a Orange PI PC with WiringOP support and i can't find precompiled images.
