  3. Restricting Node Output Data to the Gateway
4 Posts 3 Posters 1.6k Views 1 Watching
  • B
    B
    Baran
    Hi Everyone,
    I have a gateway that requests data from one node at a time. Each node streams data readings from analog inputs 1 through 8. Including my request, the code looks like this:
    1;0;2;1;17;
    0;0;3;0;9;read: 1-1-0 s=0,c=1,t=17,pt=2,l=2:418
    1;0;1;0;17;418
    0;0;3;0;9;read: 1-1-0 s=0,c=1,t=17,pt=2,l=2:406
    1;0;1;0;17;406
    0;0;3;0;9;read: 1-1-0 s=0,c=1,t=17,pt=2,l=2:476
    1;0;1;0;17;476
    0;0;3;0;9;read: 1-1-0 s=0,c=1,t=17,pt=2,l=2:520
    1;0;1;0;17;520
    0;0;3;0;9;read: 1-1-0 s=0,c=1,t=17,pt=2,l=2:526
    1;0;1;0;17;526
    0;0;3;0;9;read: 1-1-0 s=0,c=1,t=17,pt=2,l=2:350
    1;0;1;0;17;350
    0;0;3;0;9;read: 1-1-0 s=0,c=1,t=17,pt=2,l=2:487
    1;0;1;0;17;487
    0;0;3;0;9;read: 1-1-0 s=0,c=1,t=17,pt=2,l=2:343
    1;0;1;0;17;343
    My question is, can I "mute" the node from sending lines that look like:
    "0;0;3;0;9;read: 1-1-0 s=0,c=1,t=17,pt=2,l=2:343" while sending lines that look like:
    "1;0;1;0;17;343"? The information that I need is redundant and eliminating a line would result in less information to have to decode on my gateway side and would increase speed, as well. Another way of saying it is that I am only interested in the node ID and the payload, as I know the sensor ID base upon the data stream (0 - 7).
    Thank you for any suggestions - Baran
    • AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      Disable debug in the configuration file..
      • B
        B
        Baran
        Hi Again,
        Thanks;)-.
          This post is deleted!
