  3. Newbie with arduino problems
7 Posts 3 Posters 3.3k Views 2 Watching
  • C
    C
    csnij
    I have athome a vera edge with a lot of sensors.
    now i wil tray to bild some things, and i found thise wonderfull site.
    I have order some componets to build a weather station.
    But i wil tray to understand what happens in the arduino file.
    I have instal the software for the arduino, and the file of the solar weather station out the build tap of this forum.
    Now i tray this; Serial.print("temperature"); with Serial.begin(9600); to see what happens,but i see strange characters in the serieel monitor of the arduino software. is this normale or do somthing wrong.
    by a test file works it good and see i good and excepet valuels.
    I hoop that you understand me, and sorry for my bad englisch.
    • C csnij
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      make sure that your serial monitor is set to the same baud rate (9600) in your code
      • C
        C
        csnij
        Hello bulldoglwell,
        thanks for your replay. but i have the baudrate at 9600 in the serial monitor.
        I have tray all baudrats and baudrate 115200 see i the valuels.
        i don't no why but it works
        I am happy.
        thanks for the help.
        • J
          J
          Jan Gatzke
          Did you flash the sketch with the correct speed setting for the MCU? Try to change it to 16 Mhz or 8 Mhz, if you already set the MCU to 16 Mhz before. If the frequency setting for the MCU is not correct this breaks the uart timing.
          • C
            C
            csnij
            Oke,
            and how can i change this.
            I can't find it.
            chris
            • J
              J
              Jan Gatzke
              Just choose another Arduino board in the Arduino IDE. Pro Mini 5V 16 Mhz or Pro Mini 3.3V 8 Mhz.
              • C
                C
                csnij
                :thumbsup: thank you Jan Gatzke.
