  3. Rain Guage
Rain Guage
128 Posts 23 Posters 156.2k Views 21 Watching
  • mrc-coreM mrc-core
    At the rain gauge i have an arduino nano conneting PIN "d3" to TX2 over the rain gauge circuit, the arduino is powered at pins VIN and GND.
    The rain gauge gets its power from the 3.3V over the arduino.
    im posting two images from the rain gauge circuit:
    IMG_1
    IMG_2
    Starting to believe i had connect someting rong like for example had switched TX1 and TX2 at the rain gauge
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @mrc-core
    No PULLUP or PULLDOWN resistor?
    • mrc-coreM
      mrc-coreM
      mrc-core
      no i cant find any pullup or pulldown resistor.
      You can see the images from de interior of the rain gauge hi have.
      • mrc-coreM
        mrc-coreM
        mrc-core
        Which resistor do i pu between the 5v and the D3 pin ???
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @mrc-core
          if you don't pull up/down the signal, you may get floating voltages and spurious interrupts occurring.
          try to use the internal pullup
          pinMode(yourInterruptPin, INPUT_PULLUP);
          if that does not work try an external 10kOhm resistor to pull it up/down for your switch.
          • mrc-coreM
            mrc-coreM
            mrc-core
            Going to put the 10kOhm resistor. the internall pullup did not work.
            One question. the resistor i put it between de 5v and the D3 pin
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @mrc-core
              to PULL UP, yes.
              • mrc-coreM
                mrc-coreM
                mrc-core
                wrote on last edited by mrc-core
                #107
                Thanks going to try it now. And today is a good day since its raining.
                No luck... now i'm getting only "0"
                What i have done until now:
                Put a resistor 10kOhm between the GND and D3 Pin from arduino and connect it to TX2 over rthe rain gauge.
                And connected the 5V from arduino to the VCC over the rain gauge.
                But i'm only getting 0 ...
                send: 4-4-0-0 s=3,c=1,t=28,pt=7,l=5,sg=0,st=fail:-0.2
                read: 5-5-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                send: 4-4-0-0 s=4,c=1,t=16,pt=1,l=1,sg=0,st=ok:0
                New Sensor State... Sensor: Not Tripped
                read: 3-3-0 s=0,c=1,t=38,pt=7,l=5,sg=0:4.748
                read: 0-0-4 s=4,c=2,t=24,pt=0,l=1,sg=0:1
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @mrc-core
                  I guess I'd need to see a schematic or a good photo.
                  can you generate a simple interrupt with a pushbutton and a resistor?
                  • mrc-coreM
                    mrc-coreM
                    mrc-core
                    Hi. yesterday i disassembled the rain gauge circuit removed from it the reed switch and created a new circuit.
                    I have connnected the reed switch to GND and PIN3 whit 10kOhm resistor.
                    I'll post an image tonight.
                    Up until now the values i'me getting from this new circuit is:
                    rain gauge log
                    Values i'm getting from serial port:
                    Rain last 24 hours:
                    1.80
                    Rain last 48 hours:
                    12481.94
                    Rain last 72 hours:
                    28210.34
                    Rain last 96 hours:
                    43938.74
                    Rain last 120 hours:
                    59667.14
                    read and drop: 6-6-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    read and drop: 5-5-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    Seeing the graphic and this values it seems the problem i was having is fixed...
                    But tonight i'm going do spread some water over the bucket to see if i get any values and not just 0
                    • Ivan ZI
                      Ivan ZI
                      Ivan Z
                      MI-SOL Rain Guage has CALIBRATE_FACTOR = 36
                      • Ivan ZI
                        Ivan ZI
                        Ivan Z
                        Sensor manufacturer has sent information about the sensor. 0.3 mm to 1 tick
                        petewillP 1 Reply Last reply
                        • Ivan ZI Ivan Z
                          petewillP
                          petewillP
                          petewill
                          @Ivan-Z :thumbsup: Thanks for the info.
                          • petewillP petewill
                            @BulldogLowell Awesome, thank you very much! I know what it's like to lose code that way. I have done the same thing myself...
                            Yes, I will test this. I'll do my best to get it tested tonight. I'm combining it with some other sensors (light and temp/humidity) so once I get everything merged I'll be able to upload it.
                            I'll let you know what I find.
                            Thanks again!
                            Pete
                            TheekshanaT
                            TheekshanaT
                            Theekshana
                            Hey guys,
                            Sorry if this is a stupid question but how does the Arduino interact with the tipping bucket to detect rain?
                            Thanks!
                            • TheekshanaT Theekshana
                              Hey guys,
                              Thanks!
                              petewillP
                              petewillP
                              petewill
                              @Theekshana There is a magnet on the tipping bucket and a reed switch that detects the magnet each time it passes by. So each time the bucket tips it will trigger to the Arduino and it can count from there.
                              • N
                                N
                                niccodemi
                                Has anyone converted this sketch to Mysensors 2.0 already? I've tried but received following error when compiling:
                                Rain-gauge.ino: In function 'void setup()':
                                Rain-gauge.ino:151:28: error: too many arguments to function 'void requestTime()'
                                In file included from D:\Programs\Arduino\Sketchbook\libraries\libraries\MySensors/MySensors.h:293:0,
                                             from Rain-gauge.ino:71:
                                D:\Programs\Arduino\Sketchbook\libraries\libraries\MySensors/core/MySensorsCore.cpp:296:6: note: declared here
                                 void requestTime() {
                                Rain-gauge.ino: In function 'void loop()':
                                Rain-gauge.ino:323:28: error: too many arguments to function 'void requestTime()'
                                Modified sketch below:
                                 Arduino Tipping Bucket Rain Gauge
                                 April 26, 2015
                                 Version 1.4.1 alpha
                                 Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
                                 gateway you can measure and sense local rain.  This sketch will create two devices on your
                                 Vera controller.  One will display your total precipitation for the last 5 days.  The other,
                                 a sensor that changes state if there is recent rain (up to last 120 hours)  above a threshold.
                                 Both these settings are user definable.
                                 There is a build overview video here: https://youtu.be/1eMfKQaLROo
                                 This sketch features the following:
                                 * Allows you to set the rain threshold in mm
                                 * Allows you to determine the tripped indicator window up to 120 hours.
                                 * Displays the last 5 days of rain in Variable1 through Variable5
                                   of the Rain Sensor device
                                 * Configuration changes to Sensor device updated every hour
                                 * Should run on any Arduino
                                 * Will retain Tripped/Not Tripped status and data in a power interruption, saving small amount
                                   of data to EEPROM (Circular Buffer to maximize life of EEPROM)
                                 * LED status indicator
                                 * Optional Temp/Humidity (DHT-22 or DHT-11) and Light LUX (BH1750) sensors. To use, uncomment
                                   #define DHT_ON  and/or #define LUX_ON
                                 * Optionally send total accumulation of each day's rainfall or send only individual days rainfall totals.
                                   Comment out #define USE_DAILY to display individual daily rainfall.
                                 by @BulldogLowell and @PeteWill for free public use
                                #include <math.h>
                                #include <Time.h>
                                //#define NODE_ID AUTO //or AUTO to let controller assign
                                #define SKETCH_NAME "Rain Gauge"
                                #define SKETCH_VERSION "1.4.1a"
                                #define DWELL_TIME 125  // this allows for radio to come back to power after a transmission, ideally 0
                                //#define DEBUG_ON  // comment out this line to disable serial debug
                                //#define DHT_ON // uncomment out this line to enable DHT sensor
                                //#define LUX_ON // uncomment out this line to enable BH1750 sensor
                                //#define USE_DAILY // displays each time segment as an accumulation of prior periods inclusive.  Comment out to display individual daily rainfall totals in the variables sent to your controller.
                                #define CALIBRATE_FACTOR 60 // amount of rain per rain bucket tip e.g. 5 is .05mm
                                #define DHT_LUX_DELAY 300000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
                                #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
                                #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
                                #define EEPROM_BUFFER_LOCATION 0  // location of the EEPROM circular buffer
                                #define E_BUFFER_LENGTH 240
                                #define RAIN_BUCKET_SIZE 120
                                #ifdef  DEBUG_ON
                                  #define DEBUG_PRINT(x)   Serial.print(x)
                                  #define SERIAL_START(x)  Serial.begin(x)
                                  #else
                                MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
                                MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
                                MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
                                MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
                                MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
                                MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
                                MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
                                MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
                                MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
                                MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
                                #ifdef DHT_ON
                                  #include <DHT.h>
                                  #define CHILD_ID_HUM 0
                                  #define CHILD_ID_TEMP 1
                                  #define HUMIDITY_SENSOR_DIGITAL_PIN 8
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                  boolean metric = true;
                                #ifdef LUX_ON
                                  //BH1750 is connected to SCL (analog input A5) and SDA (analog input A4)
                                  #include <BH1750.h>
                                  #include <Wire.h>
                                  #define CHILD_ID_LIGHT 2
                                  BH1750 lightSensor;
                                  unsigned int lastlux;
                                  byte heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
                                unsigned long sensorPreviousMillis;
                                int eepromIndex;
                                int tipSensorPin = 3; // Pin the tipping bucket is connected to. Must be interrupt capable pin
                                int ledPin = 5; // Pin the LED is connected to.  PWM capable pin required
                                unsigned long dataMillis;
                                unsigned long serialInterval = 600000UL;
                                const unsigned long oneHour = 3600000UL;
                                unsigned long lastTipTime;
                                unsigned long lastRainTime; //Used for rainRate calculation
                                unsigned int rainBucket [RAIN_BUCKET_SIZE] ; /* 24 hours x 5 Days = 120 hours */
                                unsigned int rainRate = 0;
                                byte rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
                                volatile int wasTippedBuffer = 0;
                                int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
                                byte state = 0;
                                byte oldState = -1;
                                int lastRainRate = 0;
                                int lastMeasure = 0;
                                boolean gotTime = false;
                                byte lastHour;
                                byte currentHour;
                                  SERIAL_START(115200);
                                  // Set up the IO
                                  pinMode(tipSensorPin, INPUT_PULLUP);
                                  attachInterrupt (1, sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
                                  pinMode(ledPin, OUTPUT);
                                  digitalWrite(ledPin, HIGH);
                                  //Let's get the controller talking to the Arduino
                                  //begin(getVariables, NODE_ID);
                                  //Sync time with the server, this will be called hourly in order to keep time from creeping with the crystal
                                  unsigned long functionTimeout = millis();
                                  while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
                                //    process();
                                    requestTime(receiveTime);
                                    DEBUG_PRINTLN(F("Getting Time"));
                                    wait(1000); // call once per second
                                    DEBUG_PRINTLN(F("."));
                                  currentHour = hour();
                                  lastHour = hour();
                                  //retrieve from EEPROM stored values on a power cycle.
                                  boolean isDataOnEeprom = false;
                                  for (int i = 0; i < E_BUFFER_LENGTH; i++)
                                    byte locator = loadState(EEPROM_BUFFER_LOCATION + i);
                                    if (locator == 0xFE)  // found the EEPROM circular buffer index
                                      eepromIndex = EEPROM_BUFFER_LOCATION + i;
                                      DEBUG_PRINT(F("EEPROM Index "));
                                      DEBUG_PRINTLN(eepromIndex);
                                      //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
                                      loadRainArray(eepromIndex);
                                      isDataOnEeprom = true;
                                      break;
                                  if (!isDataOnEeprom) // Added for the first time it is run on a new Arduino
                                    DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
                                    eepromIndex = EEPROM_BUFFER_LOCATION;
                                    saveState(eepromIndex, 0xFE);
                                    saveState(eepromIndex + 1, 0xFE);
                                    //then I will clear out any bad data
                                    for (int i = 2; i <= E_BUFFER_LENGTH; i++)
                                      saveState(i, 0x00);
                                  dataMillis = millis();
                                  lastTipTime = millis() - oneHour; //why is this -oneHour?? Doesn't millis() start at 0 when first powered on?
                                  request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
                                  wait(DWELL_TIME);
                                  request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
                                  wait(DWELL_TIME);
                                #ifdef DHT_ON
                                  present(CHILD_ID_HUM, S_HUM);
                                  wait(DWELL_TIME);
                                  wait(DWELL_TIME);
                                  metric = getConfig().isMetric;
                                  .wait(DWELL_TIME);
                                #ifdef LUX_ON
                                  wait(DWELL_TIME);
                                  lightSensor.begin();
                                  DEBUG_PRINTLN(F("Radio Setup Complete!"));
                                  transmitRainData();
                                  wait(DWELL_TIME);
                                  present(CHILD_ID_RAIN_LOG, S_RAIN);
                                  wait(DWELL_TIME);
                                  present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
                                  wait(DWELL_TIME);
                                  DEBUG_PRINTLN(F("Sensor Presentation Complete"));
                                //  process();
                                  if (state)
                                    prettyFade();  // breathe if tripped
                                  else
                                    slowFlash();   // blink if not tripped
                                #ifdef DEBUG_ON  // Serial Debug Block
                                  if ( (millis() - dataMillis) >= serialInterval)
                                    for (int i = 24; i <= 120; i = i + 24)
                                      updateSerialData(i);
                                  // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
                                  int measure = 0; // Check to see if we need to show sensor tripped in this block
                                  for (int i = 0; i < rainWindow; i++)
                                    measure += rainBucket [i];
                                    if (measure != lastMeasure)
                                      //      DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
                                      //      DEBUG_PRINTLN(measure);
                                      lastMeasure = measure;
                                  state = (measure >= (rainSensorThreshold * 100));
                                  if (state != oldState)
                                    send(msgTripped.set(state));
                                    wait(DWELL_TIME);
                                    DEBUG_PRINT(F("New Sensor State... Sensor: "));
                                    DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
                                    oldState = state;
                                  unsigned long tipDelay = millis() - lastRainTime;
                                  if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
                                    DEBUG_PRINTLN(F("Sensor Tipped"));
                                    DEBUG_PRINT(F("rainBucket [0] value: "));
                                    DEBUG_PRINTLN(rainBucket [0]);
                                    send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); //Calculate the total rain for the day
                                    wait(DWELL_TIME);
                                    wasTippedBuffer--;
                                    rainRate = ((oneHour) / tipDelay);
                                    if (rainRate != lastRainRate)
                                      send(msgRainRate.set(rainRate, 1));
                                      wait(DWELL_TIME);
                                      DEBUG_PRINT(F("RainRate= "));
                                      DEBUG_PRINTLN(rainRate);
                                      lastRainRate = rainRate;
                                    lastRainTime = lastTipTime;
                                  if (currentHour != lastHour)
                                    DEBUG_PRINTLN(F("One hour elapsed."));
                                    send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); // send today's rainfall
                                    wait(DWELL_TIME);
                                    saveState(eepromIndex, highByte(rainBucket[0]));
                                    saveState(eepromIndex + 1, lowByte(rainBucket[0]));
                                    DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
                                    DEBUG_PRINTLN(rainBucket[0]);
                                    for (int i = RAIN_BUCKET_SIZE - 1; i >= 0; i--)//cascade an hour of values back into the array
                                      rainBucket [i + 1] = rainBucket [i];
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                    rainBucket[0] = 0;
                                    eepromIndex = eepromIndex + 2;
                                    if (eepromIndex > EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH)
                                    DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
                                    requestTime(receiveTime); // sync the time every hour
                                    wait(DWELL_TIME);
                                    transmitRainData();
                                    rainRate = 0;
                                    wait(DWELL_TIME);
                                    DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
                                    lastHour = currentHour;
                                  if (millis() - sensorPreviousMillis > DHT_LUX_DELAY)
                                    #ifdef DHT_ON  //DHT Code
                                      doDHT();
                                    #ifdef LUX_ON
                                      doLUX();
                                    sensorPreviousMillis = millis();
                                #ifdef DHT_ON
                                void doDHT(void)
                                    if (isnan(temperature))
                                      DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
                                    } else if (temperature != lastTemp)
                                      lastTemp = temperature;
                                      if (!metric)
                                      gw.wait(DWELL_TIME);
                                      DEBUG_PRINT(F("Temperature is: "));
                                      DEBUG_PRINTLN(temperature);
                                    float humidity = dht.getHumidity();;
                                    if (isnan(humidity))
                                      DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
                                    } else if (humidity != lastHum)
                                      lastHum = humidity;
                                      DEBUG_PRINT(F("Humidity is: "));
                                      DEBUG_PRINTLN(humidity);
                                #ifdef LUX_ON
                                void doLUX(void)
                                  unsigned int lux = lightSensor.readLightLevel();// Get Lux value
                                  DEBUG_PRINT(F("Current LUX Level: "));
                                  DEBUG_PRINTLN(lux);
                                  heartbeat++;
                                  if (lux != lastlux || heartbeat > 10)
                                    gw.send(msg.set(lux));
                                    lastlux = lux;
                                  if (heartbeat > 10)
                                    heartbeat = 0;
                                void sensorTipped()
                                  unsigned long thisTipTime = millis();
                                  if (thisTipTime - lastTipTime > 100UL)
                                    rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
                                    wasTippedBuffer++;
                                  lastTipTime = thisTipTime;
                                int rainTotal(int hours)
                                  int total = 0;
                                  for ( int i = 0; i <= hours; i++)
                                    total += rainBucket [i];
                                  return total;
                                void updateSerialData(int x)
                                  DEBUG_PRINT(F("Rain last "));
                                  DEBUG_PRINT(x);
                                  DEBUG_PRINTLN(F(" hours: "));
                                  float tipCount = 0;
                                  for (int i = 0; i < x; i++)
                                    tipCount = tipCount + rainBucket [i];
                                  tipCount = tipCount / 100;
                                  DEBUG_PRINTLN(tipCount);
                                void loadRainArray(int value) // retrieve stored rain array from EEPROM on powerup
                                  for (int i = 0; i < RAIN_BUCKET_SIZE; i++)
                                    value = value - 2;
                                    if (value < EEPROM_BUFFER_LOCATION)
                                      value = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
                                    DEBUG_PRINT(F("EEPROM location: "));
                                    DEBUG_PRINTLN(value);
                                    byte rainValueHigh = loadState(value);
                                    byte rainValueLow = loadState(value + 1);
                                    unsigned int rainValue = rainValueHigh << 8;
                                    rainValue |= rainValueLow;
                                    rainBucket[i + 1] = rainValue;
                                    DEBUG_PRINT(F("rainBucket[ value: "));
                                    DEBUG_PRINT(i + 1);
                                    DEBUG_PRINT(F("] value: "));
                                    DEBUG_PRINTLN(rainBucket[i + 1]);
                                void transmitRainData(void)
                                  DEBUG_PRINT(F("In transmitRainData. currentHour = "));
                                  DEBUG_PRINTLN(currentHour);
                                  int rainUpdateTotal = 0;
                                  for (int i = currentHour; i >= 0; i--)
                                    rainUpdateTotal += rainBucket[i];
                                    DEBUG_PRINT(F("Adding rainBucket["));
                                    DEBUG_PRINT(i);
                                    DEBUG_PRINTLN(F("] to rainUpdateTotal."));
                                  DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
                                  DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
                                  send(msgRainVAR1.set((float)rainUpdateTotal / 100.0, 1)); //Send current day rain totals (resets at midnight)
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                  for (int i = currentHour + 24; i > currentHour; i--)
                                    DEBUG_PRINT(i);
                                  DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
                                  send(msgRainVAR2.set((float)rainUpdateTotal / 100.0, 1));
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                  for (int i = currentHour + 48; i > currentHour + 24; i--)
                                    DEBUG_PRINT(i);
                                  DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
                                  send(msgRainVAR3.set((float)rainUpdateTotal / 100.0, 1));
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                  for (int i = currentHour + 72; i > currentHour + 48; i--)
                                    DEBUG_PRINT(i);
                                  DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
                                  send(msgRainVAR4.set((float)rainUpdateTotal / 100.0, 1));
                                  wait(DWELL_TIME);
                                #ifdef USE_DAILY
                                  for (int i = currentHour + 96; i > currentHour + 72; i--)
                                    DEBUG_PRINT(i);
                                  DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
                                  send(msgRainVAR5.set((float)rainUpdateTotal / 100.0, 1));
                                  wait(DWELL_TIME);
                                void getVariables(const MyMessage &message)
                                  if (message.sensor == CHILD_ID_RAIN_LOG)
                                    // nothing to do here
                                  else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
                                    if (message.type == V_VAR1)
                                      rainWindow = atoi(message.data);
                                      if (rainWindow > 120)
                                        rainWindow = 120;
                                      else if (rainWindow < 1)
                                        rainWindow = 1;
                                      if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
                                        send(msgTrippedVar1.set(rainWindow));
                                    else if (message.type == V_VAR2)
                                      rainSensorThreshold = atoi(message.data);
                                      if (rainSensorThreshold > 10000)
                                        rainSensorThreshold = 10000;
                                      else if (rainSensorThreshold < 1)
                                        rainSensorThreshold = 1;
                                      if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
                                        send(msgTrippedVar2.set(rainSensorThreshold));
                                void prettyFade(void)
                                  float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
                                  analogWrite(ledPin, val);
                                void slowFlash(void)
                                  static boolean ledState = true;
                                  static unsigned long pulseStart = millis();
                                  if (millis() - pulseStart < 100UL)
                                    digitalWrite(ledPin, !ledState);
                                void receiveTime(unsigned long time)
                                  DEBUG_PRINTLN(F("Time received..."));
                                  setTime(time);
                                  char theTime[6];
                                  sprintf(theTime, "%d:%2d", hour(), minute());
                                  DEBUG_PRINTLN(theTime);
                                AWIA 1 Reply Last reply
                                • N niccodemi
                                   April 26, 2015
                                   Version 1.4.1 alpha
                                  #include <math.h>
                                  #include <Time.h>
                                  #ifdef  DEBUG_ON
                                    #else
                                  #ifdef DHT_ON
                                    #include <DHT.h>
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                  #ifdef LUX_ON
                                    #include <BH1750.h>
                                    #include <Wire.h>
                                    BH1750 lightSensor;
                                  int eepromIndex;
                                  byte state = 0;
                                  byte oldState = -1;
                                  byte lastHour;
                                  byte currentHour;
                                    // Set up the IO
                                  //    process();
                                    lastHour = hour();
                                        break;
                                        saveState(i, 0x00);
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                  #ifdef DHT_ON
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                    .wait(DWELL_TIME);
                                  #ifdef LUX_ON
                                    wait(DWELL_TIME);
                                    transmitRainData();
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                    wait(DWELL_TIME);
                                  //  process();
                                    if (state)
                                    else
                                      wait(DWELL_TIME);
                                      oldState = state;
                                      wait(DWELL_TIME);
                                      wasTippedBuffer--;
                                        wait(DWELL_TIME);
                                      wait(DWELL_TIME);
                                      wait(DWELL_TIME);
                                      wait(DWELL_TIME);
                                      rainBucket[0] = 0;
                                      wait(DWELL_TIME);
                                      transmitRainData();
                                      rainRate = 0;
                                      wait(DWELL_TIME);
                                        doDHT();
                                      #ifdef LUX_ON
                                        doLUX();
                                  #ifdef DHT_ON
                                  void doDHT(void)
                                        if (!metric)
                                        lastHum = humidity;
                                  #ifdef LUX_ON
                                  void doLUX(void)
                                    DEBUG_PRINTLN(lux);
                                    heartbeat++;
                                      lastlux = lux;
                                    if (heartbeat > 10)
                                      heartbeat = 0;
                                  void sensorTipped()
                                      wasTippedBuffer++;
                                    int total = 0;
                                    return total;
                                    DEBUG_PRINT(x);
                                    float tipCount = 0;
                                      value = value - 2;
                                      DEBUG_PRINT(i + 1);
                                      DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                  #ifdef USE_DAILY
                                      DEBUG_PRINT(i);
                                    wait(DWELL_TIME);
                                          rainWindow = 120;
                                          rainWindow = 1;
                                    setTime(time);
                                    char theTime[6];
                                  AWIA
                                  AWIA
                                  AWI
                                  @niccodemi syntax for time functions is:
                                  requestTime();						// Request latest time from controller
                                  // This is called when a new time value was received
                                  void receiveTime(unsigned long controllerTime) {
                                  N 1 Reply Last reply
                                  • AWIA AWI
                                    N
                                    N
                                    niccodemi
                                    @AWI thank you. Sketch compiles now but after uploading it still doesn't work - serial monitor is blank (debug on).
                                    • mrc-coreM
                                      mrc-coreM
                                      mrc-core
                                      #118
                                      Using the new code for version 2.0.0 i'm getting this errors:
                                      C:\Users\marco\Documents\Arduino\Nova pasta\RainGauge\RainGauge.ino: In function 'void setup()':
                                      RainGauge:145: error: 'timeStatus' was not declared in this scope
                                      RainGauge:145: error: 'timeNotSet' was not declared in this scope
                                      RainGauge:152: error: 'hour' was not declared in this scope
                                      C:\Users\marco\Documents\Arduino\Nova pasta\RainGauge\RainGauge.ino: In function 'void loop()':
                                      RainGauge:299: error: 'hour' was not declared in this scope
                                      C:\Users\marco\Documents\Arduino\Nova pasta\RainGauge\RainGauge.ino: In function 'void receiveTime(long unsigned int)':
                                      RainGauge:597: error: 'setTime' was not declared in this scope
                                      setTime(time);
                                      RainGauge:599: error: 'hour' was not declared in this scope
                                      RainGauge:599: error: 'minute' was not declared in this scope
                                      Using library MySensors at version 2.0.0 in folder: C:\Users\marco\Documents\Arduino\libraries\MySensors
                                      Using library SPI at version 1.0 in folder: C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI
                                      Using library Wire at version 1.0 in folder: C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire
                                      exit status 1
                                      Does anyone now how to fix this ??
                                        setTime(time);
                                        exit status 1
                                        N
                                        N
                                        niccodemi
                                        @mrc-core is this the sketch you are using?
                                         April 26, 2015
                                         Version 1.4.1 alpha
                                        //#define MY_NODE_ID 7
                                        #include <math.h>
                                        #include <Time.h>
                                        #define TIP_SENSOR_PIN 3
                                        #ifdef  DEBUG_ON
                                          #else
                                        #ifdef DHT_ON
                                          #include <DHT.h>
                                          DHT dht;
                                          float lastTemp;
                                          float lastHum;
                                        #ifdef LUX_ON
                                          #include <BH1750.h>
                                          #include <Wire.h>
                                          BH1750 lightSensor;
                                        int eepromIndex;
                                        byte state = 0;
                                        byte oldState = -1;
                                        unsigned int lastRainRate = 0;
                                        byte lastHour;
                                        byte currentHour;
                                          // Set up the IO
                                          pinMode(TIP_SENSOR_PIN, INPUT_PULLUP);
                                          attachInterrupt (digitalPinToInterrupt(TIP_SENSOR_PIN), sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
                                            requestTime();
                                          lastHour = hour();
                                              break;
                                              saveState(i, 0x00);
                                          wait(DWELL_TIME);
                                          wait(DWELL_TIME);
                                        #ifdef DHT_ON
                                          wait(DWELL_TIME);
                                        #ifdef LUX_ON
                                          wait(DWELL_TIME);
                                          transmitRainData();
                                        void presentation()  {
                                          wait(DWELL_TIME);
                                          wait(DWELL_TIME);
                                          wait(DWELL_TIME);
                                        #ifdef DHT_ON
                                          wait(DWELL_TIME);
                                          wait(DWELL_TIME);
                                        #ifdef LUX_ON
                                          if (state)
                                          else
                                            wait(DWELL_TIME);
                                            oldState = state;
                                            wait(DWELL_TIME);
                                            wasTippedBuffer--;
                                              wait(DWELL_TIME);
                                            wait(DWELL_TIME);
                                            wait(DWELL_TIME);
                                            wait(DWELL_TIME);
                                            rainBucket[0] = 0;
                                            requestTime(); // sync the time every hour
                                            wait(DWELL_TIME);
                                            transmitRainData();
                                            rainRate = 0;
                                            wait(DWELL_TIME);
                                              doDHT();
                                            #ifdef LUX_ON
                                              doLUX();
                                        #ifdef DHT_ON
                                        void doDHT(void)
                                              if (!metric)
                                              wait(DWELL_TIME);
                                              lastHum = humidity;
                                              wait(DWELL_TIME);
                                        #ifdef LUX_ON
                                        void doLUX(void)
                                          DEBUG_PRINTLN(lux);
                                          heartbeat++;
                                            send(msg.set(lux));
                                            lastlux = lux;
                                          if (heartbeat > 10)
                                            heartbeat = 0;
                                        void sensorTipped()
                                            wasTippedBuffer++;
                                          int total = 0;
                                          return total;
                                          DEBUG_PRINT(x);
                                          float tipCount = 0;
                                            value = value - 2;
                                            DEBUG_PRINT(i + 1);
                                            DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                        #ifdef USE_DAILY
                                            DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                        #ifdef USE_DAILY
                                            DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                        #ifdef USE_DAILY
                                            DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                        #ifdef USE_DAILY
                                            DEBUG_PRINT(i);
                                          wait(DWELL_TIME);
                                                rainWindow = 120;
                                                rainWindow = 1;
                                          setTime(time);
                                          char theTime[6];
                                        It compiles fine with Arduino IDE 1.6.5, Mysensors 2.0.0 and libraries (Time, BH1750).
                                        • mrc-coreM
                                          mrc-coreM
                                          mrc-core
                                          Yes that's the one.
