  3. DIY Blind Control Motor
49 Posts 9 Posters 51.7k Views 8 Watching
  • R rafael.brasilia
    I've mounted a little Fubata servo motor to my blinds and it works just fine. I drive it directly from my Arduino so no need to an external power supply. I have a button that opens and closes it. Now Im looking forward to connecting a RF Receiver on my Arduino so I can control it from my Veralite.
    I like the servo motor better because it's smaller, cheaper and you can tell it exactly how many degrees it should turn (0 - 180).
    N
    N
    naveen
    Servo would be great if you're able to do only 180 degrees to open/close your blinds - like venetian blinds or something
    • N naveen
      @korttoma said:
      @naveen could be that you are right and the 700mA current is just not enough for your motor. Sorry I can't be of more help with your problems.
      btw, I have updated my sketch to 1.4b1 and at the same time changed it so that I can basically send the blinds to any position between fully open and closed using the dimmer slider in Vera. And my setup has now performed flawlessly for over 1 month opening/closing twice every day.
      I will share the sketch file when I get home if I remember.
      I pulled some of the pins to ground on the Big EasyDriver and it changed the number of microsteps and I was able to drive it faster, now I've got to find a decent gear to connect it to the blinds!
      korttomaK
      korttomaK
      korttoma
      Ahh, that explains it I checked the Big Easy Driver user guide and it seems that it is set to "Sixteenth Step" Microstep Resolution by default compared to the EasyDriver that is set to "Eight step". So what did you set it to? I did not try anything else than the default, guess I could sett it to "Full Step" just to see if it would run more quiet.
      • Tomas
      N 1 Reply Last reply
      • korttomaK
        korttomaK
        korttoma
        btw, here is the sketch I'm currently running on 1.4b1 will be updateing to 1.4 soon.
        https://codebender.cc/sketch:44733
        • Tomas
        • korttomaK korttoma
          N
          N
          naveen
          I've got it running on full steps right now and it seems to run pretty good. I might end up running it on half steps in the end.
          • N
            N
            naveen
            So I finally got the blinds set-up and working. A few tweaks to be made but overall it is working OK. One thing that would be really handy is if I could alter the speed variable through Vera, is there any way to create a custom variable in vera and send it to the Arduino?
            hekH 1 Reply Last reply
            • N naveen
              @naveen
              Yes, it is possible! You have a couple of options.
              ##Poll configuration data from node
              • Select one of V_VAR1, V_VAR2, V_VAR3, V_VAR4, V_VAR5 to use for your configuration;
                choose from your root or child nodes. You can use all five parameters per each of your root and child device. It is up to you how to design this;
              • Program your sketch to fetch variable from vera using gw.request(). You will have to take care to get reply later by yourself using in your callback method initialized in gw.setup(). See RelayActuator sketch for an example on how to handle incoming messages.
              • First run of your modified sketch to request parameters. Be prepared that you will receive an empty string because at this time we have just created empty variables at vera side;
              • Refresh your vera and go to particular child into Advanced Tab. You should be able to see your new variables named Variable1...Variable5. Variable1 corresponds to V_VAR1 inside your sketch etc.;
                fill free to change empty field on vera side to the value your needed, Save changes; forcase1.jpg
              • Check with you Arduino, it should receive correct data at this point;
              • You free to use whatever design you want. You can pull/request data at each start of you node or you can pull each 30 minutes like many z-wave devices do if they operate from battery. Other example can be if you need for your to nodes to communicate to each other and you need to tell a radio ID to one/both nodes to establish their communication. But for this one you probably want to use Push...
              ##Push configuration data from Vera to node
              Example: You need to push data from vera on event or using schedule and it should be initiated instantly by vera, not by node. For example you want your clock to show external temperature received by vera from the Weather plugin or from other sensor.
              • Choose from V_VAR1, V_VAR2, V_VAR3, V_VAR4, V_VAR5 to be used for data push
              • Design your sketch to listen for incoming messages with desired variable. See RelayActuator for an example on how to handle incoming data.
              • Create a new scene on vera side. The scene should be run according to your goal. For example each 10 minutes;
              • Use Lua tab while editing scene to provide data for the push. For example this Lua is taking current temperature from Weather (vera id = 61) plugin and pushing it to the node (vera id for root device = 372) using VAR_5:
                local temp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 61)
                temp = temp*10.0
                luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="4;255", variableId="VAR_5", value=temp}, 372)
              SendCommand will push a message to your node. You can also call it with static values (without programming) using the Advanced tab in the scene editor.
              (This post was updated to 1.4 from from @axillent old tips page on micasaverde)
              N 3 Replies Last reply
                @naveen
                  temp = temp*10.0
                N
                N
                naveen
                @hek
                Awesome, thanks! I'll give it a go.
                  @naveen
                    temp = temp*10.0
                  N
                  N
                  naveen
                  This post is deleted!
                  • N
                    N
                    naveen
                    • N
                      N
                      naveen
                      Finally finished my setup, here is a picture. Works pretty well, it is slightly louder than I would have hoped but if you run it at 1/16th microsteps its almost silent. The only issue is that it won't run very fast at 1/16 microsteps.IMG_1795-2.jpg
                      L 1 Reply Last reply
                      • RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        Pretty cool, would it be possible to get a video with audio of the final 'product'?
                        RJ_Make
                        • RJ_MakeR RJ_Make
                          N
                          N
                          naveen
                          Sure! This is with eighth steps - and it seems to be as fast as the motor will go without reducing the microsteps.
                          http://youtu.be/imQj-p-GoYQ
                          korttomaK RJ_MakeR 2 Replies Last reply
                          • N naveen
                            korttomaK
                            korttomaK
                            korttoma
                            @naveen nice!!
                            • Tomas
                            • N naveen
                              RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              @naveen
                              Thank you! Gives me an ideal of speed and noise. Both seem very reasonable.
                              RJ_Make
                              • RJ_MakeR RJ_Make
                                @naveen
                                N
                                N
                                naveen
                                wrote on last edited by naveen
                                #35
                                @ServiceXp
                                A few things I should mention for anyone trying to undertake this project:
                                -I'm assuming that the choice of stepper motor is important to control noise. It is possible that a different stepper would give an improved speed/noise ratio.
                                -One of the most important factor in reducing noise is ensuring there is no hard surface for the motor to 'rumble' on. This is especially bad when using full stepping - the motor rumbles like crazy. The more microsteps, the less rumble and the less noise.
                                -I coated the sprocket and bracket in silicon caulking to reduce noise, it seemed to help a little, but was nothing compared to reducing the microsteps
                                -If you are looking to have the best of both worlds, you can add some code as follows in order to choose the microsteps based on the desired RPM. This way you can control the speed via vera and the arduino will actively choose the best microstepping mode. The regular EasyDriver has similar pins, but I believe the most microsteps is 8 and there are only two pins to control
                                -I am using a 8Mhz 3.3V APM and it may be possible to increase the steps/second if you use a more powerful processor (for example, 16Mhz APM) - I will test it with a nano when I get a chance. @hek, the nano used for the gateway is 16Mhz, correct? It says 16M on the eBay page but I just wanted to confirm.
                                void newnMicroSteps(){
                                  if(nMicroSteps==1){
                                    digitalWrite(MS1pin,LOW);
                                    digitalWrite(MS2pin,LOW);
                                    digitalWrite(MS3pin,LOW);
                                  if(nMicroSteps==2){
                                    digitalWrite(MS1pin,HIGH);
                                  if(nMicroSteps==4){
                                    digitalWrite(MS2pin,HIGH);
                                  if(nMicroSteps==8){
                                  if(nMicroSteps==16){
                                    digitalWrite(MS3pin,HIGH);
                                  maxStepperSpeed = maxRPM/60*stepsPerRev*nMicroSteps;
                                  fullOpenSteps = fullOpenRevs*stepsPerRev*nMicroSteps;
                                  maxStepperAccel = maxAccelRPMPM/60*stepsPerRev*nMicroSteps;
                                  stepper1.setMaxSpeed(maxStepperSpeed);
                                  stepper1.setAcceleration(maxStepperAccel);
                                Edit: I just noticed that I calculated acceleration wrong. Here is the correct equation:
                                maxStepperAccel = maxAccelRPMPM/60/60*stepsPerRev*nMicroSteps;
                                RJ_MakeR 1 Reply Last reply
                                • N naveen
                                  @ServiceXp
                                    if(nMicroSteps==1){
                                    if(nMicroSteps==2){
                                    if(nMicroSteps==4){
                                    if(nMicroSteps==8){
                                  RJ_MakeR
                                  RJ_MakeR
                                  RJ_Make
                                  @naveen
                                  Thanks for the update.
                                  RJ_Make
                                  • RJ_MakeR RJ_Make
                                    @naveen
                                    N
                                    N
                                    naveen
                                    @ServiceXp
                                    Note: I tried the 16Mhz Arduino Nano and I seem to be able to get much higher speeds with high microstepping. I have almost silent operation with 8 microsteps and the blinds open in about 10 seconds. I assume if you get an even faster processor you can step it even more quickly.
                                    • N
                                      N
                                      naveen
                                      For the next part of my project I'm looking to have two interlocking gears which grab and pull the string in order to slide the vines of the blinds to one side.
                                      I can attach one gear to the servo, but the other gear would require some sort of bearing? Does anyone have any idea what type of bearing I can use? If there's a name I can search for them on eBay (I assume they are available there).
                                        I really did not put much thought in to the physical setup, I just squeezed it in to as small a box I could. Here is some pictures. Still waiting for some parts to get it mounted.
                                        I forgot to mention that the "sleep" pin of the driver board is also connected to the arduino to enable the motor to spin freely when it is not being controlled from the arduino. I want it to be possible to use the original cord to open/close the blinds also (WAF).
                                        N
                                        N
                                        naveen
                                        @korttoma , did you ever try using the accelstepper run() command instead of runToPosition(). From my understanding the run() command is non-blocking and you put it in your main-loop. That way, if Vera sends a new commands you can set it to stop immediately using:
                                        stop();
                                        runToPosition();
                                        I gave it a shot and the motor didn't seem to move at all - I'm not sure if you ever experimented with it, thought I'd ask.
                                        korttomaK 1 Reply Last reply
                                        • N naveen
                                          stop();
                                          runToPosition();
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          #40
                                          @naveen
                                          Sorry, I have not experimented with other functions than the once I have in my current sketch since it is working according to my needs except for the problem with position updates to Vera I'm having.
                                          I guess some people would like it if it was possible to use up/down/stop if it is possible with the run() function but I have schedules running my blinds 95% of the time.
                                          I managed to workaround the position updates to vera problem by using the up/down instead of open/close, I will look in to it when I find some time and then I could check out the run() function too.
                                          • Tomas
