  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 678.3k Views 99 Watching
  • dakkyD dakky
    I think i need some help. I am not shure, if my problem lies on the openHab2 side or if there is a problem with the mysensors addon.
    This is what i I have:
    A working mysensors addon. I receive updates in OpenHab:
    2016-06-06 07:12:08.483 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
    2016-06-06 07:12:08.550 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.mysensors.internal.MySensorsHandlerFactory, component.id=7, service.id=102, service.bundleid=11, service.scope=bundle} - org.openhab.binding.mysensors
    2016-06-06 07:12:09.070 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
    2016-06-06 07:12:12.062 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
    2016-06-06 07:12:18.694 [ERROR] [org.openhab.ui.habmin               ] - [org.openhab.ui.habmin.designer(3)] bind method [setItemRegistry] not found; Component will fail
    2016-06-06 07:12:18.702 [ERROR] [org.openhab.ui.habmin               ] - [org.openhab.ui.habmin.designer(3)] bind method [setItemRegistry] not found
    2016-06-06 07:12:25.252 [ERROR] [org.eclipse.smarthome.core.transform] - [org.eclipse.smarthome.action.transformation.action(51)] Circular reference detected, getService returning null
    2016-06-06 07:12:39.288 [INFO ] [rthome.event.ItemThingLinkAddedEvent] - Link 'mysensors_light_gateway_Light_1_0-mysensors:light:gateway:Light_1_0' has been added.
    2016-06-06 07:12:39.315 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'home_group_88a3d2a1' has been added.
    2016-06-06 07:12:42.030 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
    2016-06-06 07:12:42.261 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
    2016-06-06 07:12:42.825 [WARN ] [sql.internal.MysqlPersistenceService] - The SQL user is missing - please configure the sql:user parameter in openhab.cfg
    2016-06-06 07:12:43.071 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
    2016-06-06 07:12:43.114 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
    2016-06-06 07:12:43.470 [INFO ] [.openhab.core.internal.CoreActivator] - openHAB runtime has been started (v2.0.0, build b2).
    2016-06-06 07:12:43.479 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
    2016-06-06 07:12:44.159 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
    2016-06-06 07:12:44.397 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'mysensors:bridge-eth:gateway' has been added.
    2016-06-06 07:12:44.468 [INFO ] [nsors.handler.MySensorsBridgeHandler] - Using Metric measure unit
    2016-06-06 07:12:44.470 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Set skip check on startup to: false
    2016-06-06 07:12:44.489 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=278, service.bundleid=11, service.scope=singleton} - org.openhab.binding.mysensors
    2016-06-06 07:12:44.527 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors Bridge
    2016-06-06 07:12:44.531 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:gateway' changed from UNINITIALIZED to INITIALIZING
    2016-06-06 07:12:44.540 [DEBUG] [rs.protocol.ip.MySensorsIpConnection] - Connecting to bridge ...
    2016-06-06 07:12:44.762 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    2016-06-06 07:12:44.770 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
    2016-06-06 07:12:44.776 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;11;EthernetGateway
    2016-06-06 07:12:44.778 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;12;1.0
    2016-06-06 07:12:44.849 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;2;2.0.0-beta
    2016-06-06 07:12:44.852 [DEBUG] [s.internal.MySensorsBridgeConnection] - Good,Gateway is up and running! (Ver:2.0.0-beta)
    2016-06-06 07:12:44.858 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=mysensors:bridge-eth, thing.id=mysensors:bridge-eth:gateway, service.id=279, service.bundleid=11, service.scope=singleton} - org.openhab.binding.mysensors
    2016-06-06 07:12:44.859 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-eth:gateway' changed from INITIALIZING to ONLINE
    2016-06-06 07:12:44.900 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'logging.persist'
    2016-06-06 07:12:44.990 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
    2016-06-06 07:12:45.047 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
    2016-06-06 07:12:45.168 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c0-mysensors:light:gateway:n1c0:status' has been added.
    2016-06-06 07:12:45.171 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c1-mysensors:light:gateway:n1c1:status' has been added.
    2016-06-06 07:12:45.174 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c2-mysensors:humidity:gateway:n1c2:hum' has been added.
    2016-06-06 07:12:45.178 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c3-mysensors:humidity:gateway:n1c3:hum' has been added.
    2016-06-06 07:12:45.182 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'n1c4-mysensors:humidity:gateway:n1c4:hum' has been added.
    2016-06-06 07:14:50.818 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;1
    2016-06-06 07:14:50.820 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
    2016-06-06 07:14:55.831 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;0
    2016-06-06 07:14:55.832 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
    2016-06-06 07:28:01.373 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;1
    2016-06-06 07:28:01.375 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
    2016-06-06 07:28:06.385 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;0
    2016-06-06 07:28:06.387 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
    2016-06-06 07:32:21.567 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;1
    2016-06-06 07:32:21.568 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
    2016-06-06 07:32:26.578 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;3;1;1;1;0
    2016-06-06 07:32:26.582 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - ACK received!
    Seems ok.
    But I am not able to see the result in Openhab
    my.thing:
    mysensors:bridge-eth:gateway [ ipAddress="192.168.100.10", tcpPort=5003, sendDelay=200 ] {
            /** define things connected to that bridge here */
            light           n1c0   [ nodeId="1", childId="0", requestAck=true ]
            light           n1c1   [ nodeId="1", childId="1", requestAck=true ]
            humidity        n1c2   [ nodeId="1", childId="2" ]
            humidity        n1c3   [ nodeId="1", childId="3" ]
            humidity        n1c4   [ nodeId="1", childId="4" ]
    my.item:
    Switch n1c0    "PFLANZENNAME1 Pumpe"                    <water> (gGF_irrigation01) { channel="mysensors:light:gateway:n1c0:status" }
    Switch n1c1    "PFLANZENNAME1 Pumpe Automatikmodus"     <water> (gGF_irrigation01) { channel="mysensors:light:gateway:n1c1:status" }
    Number n1c2    "PFLANZENNAME1 Bodenfeuchtigkeit max"    <water> (gGF_irrigation01) { channel="mysensors:humidity:gateway:n1c2:hum" }
    Number n1c3    "PFLANZENNAME1 Bodenfeuchtigkeit min"    <water> (gGF_irrigation01) { channel="mysensors:humidity:gateway:n1c3:hum" }
    Number n1c4    "PFLANZENNAME1 Bodenfeuchtigkeit"        <water> (gGF_irrigation01,gGF_eating) { channel="mysensors:humidity:gateway:n1c4:hum" }
    There are simply no values in openhab although I see the debug messages in the openhab log.
    Any idea how to fix it? I did not use the autodicovery of openhab paper UI. what confuses me is the name of the link used by openhab:
    That does not match the channel. is that ok?
    Thank
    Dakky
    EDIT: updated openhab log to complete startup process and added question
    dakkyD
    dakkyD
    dakky
    wrote on last edited by dakky
    #221
    No idea anyone? i'm stucked here and I'd really like to continue :(
    EDIT: MAybe this helps debugging: it seem there is no "link" between things and items. The rest endpoints reveals, that the thing has no item:
        "statusInfo": {
          "status": "ONLINE",
          "statusDetail": "NONE"
        "link": "http://autohome:8080/rest/things/mysensors:bridge-eth:gateway",
        "configuration": {
          "tcpPort": 5003,
          "ipAddress": "192.168.100.10",
          "skipStartupCheck": false,
          "imperial": false,
          "sendDelay": 200
        "properties": {},
        "UID": "mysensors:bridge-eth:gateway",
        "channels": [
            "linkedItems": [],
            "id": "n1c0",
            "itemType": "light",
            "properties": {}
            "linkedItems": [],
            "id": "n1c1",
            "properties": {}
            "linkedItems": [],
            "id": "n1c2",
            "itemType": "humidity",
            "properties": {}
            "linkedItems": [],
            "id": "n1c3",
            "properties": {}
            "linkedItems": [],
            "id": "n1c4",
            "properties": {}
    Greetings
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    • dakkyD
      dakkyD
      dakky
      Dammit ... found the error ;)
      created a pull request: https://github.com/tobof/openhab2-addons/pull/18
      Greetings
      Dakky
      • T
        TimO
        Glad you found it! :+1:
        I'm a little low in time at the moment, I will look at the PRs next weekend. Thank you for the contributions! :)
        • T
          TimO
          There is a new jar available that fixes the bug with the high CPU usage.
          Additionally @meju25 added support for customSensor and an option to adjust the behavior in case no ACK could be received (see wiki). Thanks a lot!
          avinazA 1 Reply Last reply
          • T TimO
            avinazA
            avinazA
            avinaz
            Thanks @TimO , seems is working fine. I updated my installation with the new jar and now CPU is around 4-6%. Thanks a lot. By the way, I did not see a commit in the code repository.
            T 1 Reply Last reply
            • avinazA avinaz
              TimO
              @avinaz: I'm glad, thanks for testing!
              Did you look into the right branch? I've committed all changes to github.
              • D
                D
                Denke
                Hi all
                Implemented a barometric sensor "pressure meter" that i sample in the sensor. Then i send the value Through "BARO". I can see in both the sensor output and the openhab debug that i receive a value for example "1.2".
                I try to display this in the openhab and i dont get the Text item to update.
                Anyone know how this can be as i have other values that i am able to display.
                line in .items
                String Pool_Pressure "Pressure (bar) [%s]" <pressure> (gPool)
                line in .sitemap
                Text item=Pool_Pressure
                any help is appriciated as i have tried different options with Number and so on
                RaspberryPi-Openhab
                • D
                  D
                  Denke
                  Merging sensor to one
                  Hi
                  I have been thinking and i think it would be nice if there is a way to merge sensor data to one in the mysensors binding.
                  Background
                  I am trying to build a pool control based on mysensors and i have a lot of options that i wan it to handle. For example:
                  • on/off of my pool pumps (S_LIGHT)
                  • on/off of lights around the pool (S_LIGHT)
                  • thermostat function for heaters (S_HVAC)
                  • measuring pressure on pump (S_BARO)
                  • measuring consumed power on pump (S_POWER)
                  All this are using the same sensor ID and getting own child IDs. When they now are brought in to openhab they appear as single sensors
                  Is there a possibility to get an automatic merge for thes combined sensors?
                  And what do you think about the idea.
                  Or is there already a solution that exist that I am not aware about
                  example from paper UI
                  0_1465935938914_upload-2840e8d0-1b09-4aa8-965a-4193011e843b
                  with openhab poolcontrol view
                  0_1465936019282_upload-4ee31603-3e67-467c-86ff-d93a758d56d3
                  RaspberryPi-Openhab
                  meju25M 1 Reply Last reply
                  • D Denke
                    Hi
                    Background
                    meju25M
                    meju25M
                    meju25
                    @Denke
                    If I understand correctly, you are suggesting to combine different sensor types in one thing.
                    IMHO this would jeopardize the concept of the binding. The binding provides one thing per message type (see https://www.mysensors.org/download/serial_api_15). the thing has one channel per supported sub type.
                    I also do not see the advantage of combining different sensor/message types in one thing as you need one item per channel anyhow.
                    => this would not reduce the number of items needed.
                    Grouping the items in the site map - as you already did - is the best way here.
                    Does anybody see this differently?
                    D 1 Reply Last reply
                    • meju25M meju25
                      @Denke
                      D
                      D
                      Denke
                      @meju25 I saw this from a management perspective.
                      I have one device, my pool controller, that has multiple sensors and also channels per sensor just as HVAC that has a sum of channels. In my case i implemented a number of sensors in different types of channels "S_HVAC, S_LIGHT,...." what i see that it gets messy when you try to see if the channels are active or the pool control is active it has multiple sensors.
                      So maybe a suggestion is to maybe implement this in the mysensors instead of in the openhab binding.
                      In that case i would like to add something that allows me to tell what channels are in a "sensor" by combining differnt channels and sensor types.
                      I don't know if i got my message through.
                      But all this is mainly for management of my devices so that this gets less messy
                      RaspberryPi-Openhab
                      • dakkyD
                        dakkyD
                        dakky
                        @TimO do you plan to implement the reconnect thing? I often have to struggle with that and the only solution is the restart the openhab service :S Is there a problem with the reconnect or is it just "another task on the todo list"?
                        Greetings
                        Dakky
                        • D
                          D
                          Denke
                          Hi
                          Is there anybody that have had a problem with the S_BARO and the V_PRESSURE channel?
                          I try to send a value on this channel as 1.2 I can see that the serial gateway receives it
                          23:10:51.808 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;0;3;0;9;read: 163-163-0 s=10,c=1,t=4,pt=7,l=5,sg=0:1.2
                          I set up the channel as i have done for alot of other channels through the paper ui. where i link the channel to an item.
                          The item file looks like this
                          String Pool_Pressure "Pressure [%s]" <pressure> (gPool)
                          the sitemap file looks like this
                          result is this
                          0_1466111768156_upload-9d8b8d90-c258-4979-b27f-0162a9ffcdc5
                          The field never gets updated.
                          any suggestions?
                          RaspberryPi-Openhab
                          • D Denke
                            Hi
                            result is this
                            any suggestions?
                            D
                            D
                            Denke
                            @Denke
                            I cant find V_PRESSURE connected to CHANNEL_BARO below, can that be the reason?
                            0_1466112268981_upload-f457bebe-d1b9-41d0-9f82-a7c55307e5d5
                            RaspberryPi-Openhab
                            • T
                              TimO
                              @Denke : You're right, the pressure channel was missing in the thing definition. This is fixed in the current version!
                              @dakky : Which gateway type keeps disconnecting and why? I've a serial and ethernet gateway running side by side in OH2 and both didn't get disconnected so far. The hardest part is to recognize if the connection gets down.
                              G dakkyD 2 Replies Last reply
                              • T TimO
                                G
                                G
                                gonzalonal
                                Hi @TimO . Are you having both gateways connected to same the OH simultaneously?
                                Any troubles with that? I imagine you should have different radio channels for each gateway, right? like two separate sensors networks.
                                • G gonzalonal
                                  TimO
                                  Hi @gonzalonal !
                                  Only the ethernet gateway has an attached radio.
                                  Here is my current (MySensors) setup:
                                  Bridge mysensors:bridge-eth:MySGW [ ipAddress="192.168.2.99", tcpPort=5003, sendDelay=100, skipStartupCheck=true  ] {
                                  	humidity        bathHum01   			[ nodeId="101", childId="0" ]
                                      temperature     bathTemp01  			[ nodeId="101", childId="1" ]
                                      humidity		bathBat01				[ nodeId="101", childId="255" ]
                                      humidity        bedHum01   				[ nodeId="103", childId="2" ]
                                      temperature     bedTemp01  				[ nodeId="103", childId="1" ]
                                      humidity		bedBat01				[ nodeId="103", childId="255" ]
                                      humidity        workHum01  				[ nodeId="104", childId="2" ]
                                      temperature     workTemp01 				[ nodeId="104", childId="1" ]
                                      humidity		workBat01				[ nodeId="104", childId="255" ]
                                      humidity        kitchenHum01			[ nodeId="105", childId="2" ]
                                      temperature     kitchenTemp01			[ nodeId="105", childId="1" ]
                                  	humidity		kitchenBat01			[ nodeId="105", childId="255" ]
                                      humidity        childHum01 				[ nodeId="107", childId="3" ]
                                      temperature     childTemp01				[ nodeId="107", childId="4" ]
                                      light			childLight01			[ nodeId="107", childId="0" ]
                                      light			childLight02			[ nodeId="107", childId="1" ]
                                      light			childLight03			[ nodeId="107", childId="2" ]
                                      humidity        guestHum01				[ nodeId="106", childId="0" ]
                                      temperature     guestTemp01				[ nodeId="106", childId="1" ]
                                  	light			guestPresence01			[ nodeId="106", childId="3" ]
                                      light			livingLight01			[ nodeId="106", childId="4" ]
                                      light			livingLight02			[ nodeId="106", childId="5" ]
                                      light			livingLight03			[ nodeId="106", childId="6" ]
                                      light			livingLight04			[ nodeId="106", childId="7" ]
                                      light			corridorLight03			[ nodeId="106", childId="8" ]
                                      light			livingLight06			[ nodeId="106", childId="9" ]
                                      humidity        livingHum01				[ nodeId="108", childId="2" ]
                                      temperature     livingTemp01			[ nodeId="108", childId="1" ]
                                  	humidity		livingBat01				[ nodeId="108", childId="255" ]
                                  	humidity        gardenHum01				[ nodeId="110", childId="2" ]
                                      temperature     gardenTemp01			[ nodeId="110", childId="1" ]
                                  	humidity		gardenBat01				[ nodeId="110", childId="255" ]
                                  	motion			gardenMotion01			[ nodeId="110", childId="3" ]
                                  Bridge mysensors:bridge-ser:MySGWKeller [ serialPort="/dev/ttyUSB0", sendDelay=100, skipStartupCheck=true ] {
                                      cover			kitchenShutter02 	[ nodeId="0", childId="0" ]
                                      cover			kitchenShutter03	[ nodeId="0", childId="1" ]
                                      cover			livingShutter01 	[ nodeId="0", childId="2" ]
                                      cover			livingShutter02 	[ nodeId="0", childId="3" ]
                                      cover			kitchenShutter01 	[ nodeId="0", childId="4" ]
                                      light			corridorLight01		[ nodeId="0", childId="5" ]
                                      light			corridorLight02		[ nodeId="0", childId="6" ]
                                      power			corridorLight01watt	[ nodeId="0", childId="7" ]
                                  G 1 Reply Last reply
                                  • T TimO
                                    dakkyD
                                    dakkyD
                                    dakky
                                    @TimO
                                    I'm using a ethernet gateway.
                                    the problem is: if the sensors gateway gets restarted/disconnected/updated/whatever the binding does not reconnect. The only way to fix that, is to restart openhab in order to force the binding to connect again.
                                    Detecting an disconnect is really that hard? in the worst case, what about simply reconnecting timebased? not as cute as only reconnect when nessecary but a dirty quickfix.
                                    • T TimO
                                      Hi @gonzalonal !
                                      G
                                      G
                                      gonzalonal
                                      Thanks @TimO. Now I get it.
                                      What do you think about having two gateways, one with NRF radio and the other one with RFM69 radio?
                                      Will the binding support both gateways simultaneusly with no issues?
                                      Another question..Will you support HearbeatRequest for the development branch?
                                      Thanks, regards.
                                      • G
                                        G
                                        gonzalonal
                                        wrote on last edited by gonzalonal
                                        #239
                                        Hello againg.
                                        I have updated my OH2 to latest nightbuild from cloudbees, and also updated to lastest realease of OH2 MyS Binding.
                                        Now, I am facing an issue, that everytime that OH2 starts, it sends out all the items status to its respective node. This is causing, for example, to open my gates, or lowering my rollershutters, even disabling/enabling my alarm system. So I have shutdown OH2 for time being.
                                        Have anyone faced this behavior before?
                                        This is some of the log:
                                        15:41:40.241 [WARN ] [ome.core.thing.internal.ThingManager] - Initializing handler for thing 'mysensors:bridge-ser:gateway' takes more than 5000ms.
                                        15:41:40.272 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.295 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.322 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.335 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.348 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.362 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.375 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.388 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.402 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.545 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Home.items'
                                        15:41:40.671 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.685 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.697 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.710 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.724 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.738 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.755 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.768 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.783 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.806 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;14;Gateway startup complete.
                                        15:41:40.811 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.856 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.871 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.885 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.898 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.914 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.928 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:40.941 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:41.029 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 2;3;1;0;0;
                                        15:41:41.110 [DEBUG] [g.mysensors.handler.MySensorsHandler] - handleCommand called
                                        15:41:41.288 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 3;253;1;0;2;
                                        15:41:41.546 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 1;6;1;0;2;
                                        15:41:41.799 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 3;252;1;0;24;REFRESH
                                        15:41:42.052 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 3;254;1;0;2;
                                        15:41:42.307 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 1;254;1;0;2;
                                        15:41:42.562 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 3;3;1;0;2;
                                        15:41:42.817 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 1;253;1;0;2;
                                        15:41:43.073 [DEBUG] [g.mysensors.protocol.MySensorsWriter] - Sending to MySensors: 2;252;1;0;24;REFRESH
                                        I would really appreciate your help.
                                        • G gonzalonal
                                          Hello againg.
                                          TimO
                                          @gonzalonal I have no idea why this should happen. The binding isn't that smart to do something like that. I've done a complete fresh installation on 21.06. with the nightly build from cloudbees and don't see this issue.
                                          @dakky Do you see disconnection messages in the log? The binding already tries to detect a disconnect and tries to reestablish the connection when an ethernet gateway is used. Currently the time within a reconnect would be successful is very small due to sleep limitations of threads in OH2 bindings.
