  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 678.3k Views 99 Watching
  • FutureCowF
    FutureCowF
    FutureCow
    I have a problem with adding one of my nodes.
    My temp en hum nodes are working perfectly, but i try to add a Light Level node. The sensor is sending the amount of Lux and not the percentage:
    18:14:59.572 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=23,pt=3,l=2,sg=0:3
    18:14:59.572 [DEBUG] [g.mysensors.protocol.MySensorsReader] - 1;0;1;0;23;3
    18:14:59.574 [ERROR] [g.mysensors.protocol.MySensorsReader] - (java.lang.IllegalStateException: Could not update state, because callback is missing) on reading from serial port, message: class org.openhab.binding.mysensors.protocol.serial.MySensorsSerialReader
    It is using CHILD_ID_LIGHT inside the skechts. Is this light level node supported?
    T 1 Reply Last reply
    • FutureCowF FutureCow
      TimO
      According to this: https://www.mysensors.org/download/serial_api_20
      V_LIGHT_LEVEL	23	Uncalibrated light level. 0-100%. Use V_LEVEL for light level in lux.	S_LIGHT_LEVEL
      V_LEVEL	37	Used for sending level-value	S_DUST, S_AIR_QUALITY, S_SOUND (dB), S_VIBRATION (hz), S_LIGHT_LEVEL (lux)
      Your node should send "1;0;1;0;37;3 if I'm not mistaken.
      The light level message is supported by the binding.
      • T
        TimO
        wrote on last edited by TimO
        #263
        Small update to the progress:
        1. Expert mode: I've added a special thing that will allow rule based parsing and sending of MySensors messages. If the binding is limiting your creativity you are now free to go. ;-) You are now able to combine/adapt rules like in this Thread with the easy process of thing/item/sensor configuration. I've added a description to the Wiki. This may solve some problems mentioned above with sensors requesting information like pulse count.
        2. Last week the OH2 core team has released beta4 of OH2. I've tested the binding against the current beta and it is working fine.
        3. I've created a PR against the official openhab2-addons repository. I'm now awaiting feedback and hope to introduce the MySensors binding as part of OH2.
          Great job @Timo!
          • G
            G
            gonzalonal
            Great news to hear @TimO .
            I will be testing the binding in a couple of hours. It's really usefull the new RAW messenger things.
            Thanks!
            • xliborX
              xliborX
              xlibor
              Hi all, i am new in mysensors, but i have problem with install this plugin to OpenHab2.0 i tried versions 2.0 and 2.0b4 but i couldn't see this plugin in OpenHab2, i tried with RPi B, RPi3 with Raspian Jessie, and with Windows 10. But all with the same result.
              I placed org.openhab.binding.mysensors-2.0.0.SNAPSHOT.jar into addons directory, but i can't se it in OpenHab.
              Can anyone help me?
              • xliborX xlibor
                Can anyone help me?
                TimO
                @xlibor Did you follow the instructions on the wiki and installed serial transport first? Is there a log file entry? How did you install OH2? Debian Package or Zip File?
                xliborX 2 Replies Last reply
                • T TimO
                  xliborX
                  xliborX
                  xlibor
                  This post is deleted!
                  • T TimO
                    xliborX
                    xliborX
                    xlibor
                    wrote on last edited by xlibor
                    #269
                    @TimO Yes, i follow instruction on wiki and install serial transport sucesfully. I tried both types, first zip file and next package, but both with the same result :-(
                    In log file is nothing about mysensors or any error.
                    Now i downloaded again from github and now all works without any problem. But i don't know where was problem.
                    • daxjonesD
                      daxjonesD
                      daxjones
                      Hey All. Newbie alert here. I love the work you all do on here and this project is so exciting. I'm hooked after 2 weeks of 'fettling' and building sensors.
                      I've hit a brick wall though. after struggling with openhab1 I decided to make the leap straight to openhab2. Although in early days of testing it seems immediately abit more user friendly.
                      What I've done so far...
                      RaspberryPi3 is acting as controller with openhab2 installed and running fine. bindings to TV and Nest thermostat all working lovely.
                      Clone arduino Uno's with capacitors added for radio with NRF24 radio cards
                      Created GatewayW5100 gateway using the mysensors library sketch for it and set static IP to 192.168.0.11 (Openhab2 is set to 192.168.0.10) and my router gives DHCP from 192.168.0.20 up
                      created a temp and humidity sensor node and a node with a relay to turn a lamp on (both from mysensors library). Tested radio on all before moving ahead.
                      Installed the mysensors binding on OH2
                      Added a ethernet gateway
                      disabled startup connection check as it kept failing to initialise and showed as offline
                      Tried auto discovery of nodes... NOTHING
                      Tried setting node ID manually on the arduinos.. Still NOTHING, even if i add a thing manually to OH2.
                      I'm hoping i'm doing something stupid and its an easy fix.. Any pointers for a newbie??
                      D.
                      • daxjonesD daxjones
                        D.
                        TimO
                        @daxjones
                        Have you tried to reach your gateway with telnet?
                        telnet 192.168.2.11 5003
                        Does it respond? Do you see the messages from the node arriving?
                        Have you enabled debug output of the binding like described in the wiki? What does the log say?
                        FleischtorteF 1 Reply Last reply
                        • T TimO
                          @daxjones
                          FleischtorteF
                          FleischtorteF
                          Fleischtorte
                          Hi@TimO
                          first, thanks for your awesome work :+1:
                          On the weekend i switched from OH1 to OH2 and your binding is working just out of the box :)
                          Im only missing the IR_Send and the V_TEXT sensor to integrate all of my sensors :(
                          could you integrate them in your binding?
                          • FleischtorteF Fleischtorte
                            Hi@TimO
                            TimO
                            Thanks @Fleischtorte!
                            There already was a request for IR and I've added one for V_TEXT.
                            https://github.com/tobof/openhab2-addons/issues
                            @andreacioni has done some serious refactoring of the code. After looking in the refactoring I'll add the missing sensors.
                            • Meshx86M
                              Meshx86M
                              Meshx86
                              I have the following setup:
                              1. MQTT Gateway on Wemos D1 mini (ESP8266)
                              2. Node on Arduin pro mini
                              i can't get the openhab binding to distribute address to the nodes, in things in openhab there is no option for MQTT Gateway to add, what is the procedure ?
                              Cheers
                              Q 1 Reply Last reply
                              • Meshx86M Meshx86
                                Cheers
                                Q
                                Q
                                Qu3Uk
                                @Meshx86 the openhab binding doesnt support MQTT as far as I know.
                                If you are using the MQTT binding then you need another controller/method to provide the internal functions for my sensors. I use NodeRed workflow to listen for ID requests and it provides them.
                                Or static assign them in the node stretch.
                                • carlylerC
                                  carlylerC
                                  carlyler
                                  @TimO: Thanks to you this weekend, while kids slept or napped, I managed to setup RPi gateway/controller with NRF24 and OH2.
                                  Following the OH2 install instructions caused me some trouble, not sure why, but following your install instructions it came right up.
                                  Thank you for the time and effort here.
                                  • carlylerC
                                    carlylerC
                                    carlyler
                                    Having a couple issues:
                                    1. while adding 2nd node (tried power and temp/hum) OH2 would not assign node ID.
                                    2. assigned node ID manually (ID=2) and OH2 recognized power node but will not respond to V_VAR1 request.
                                    16:23:58.850 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;1;1;0;0;20.4
                                    16:23:58.874 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.3
                                    16:24:01.910 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                    16:24:09.293 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.5
                                    16:24:11.911 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                    16:24:11.942 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                                    16:24:19.736 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.7
                                    16:24:21.912 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                    16:24:26.987 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                                    16:24:30.177 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.6
                                    16:24:31.913 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                    16:24:40.604 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.5
                                    16:24:41.914 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                    16:24:42.044 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                                    16:24:51.916 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                    16:24:57.102 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                                    16:25:01.917 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                    16:25:11.919 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                    16:25:12.145 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;0;2;0;24;
                                    16:25:21.921 [DEBUG] [col.serial.MySensorsSerialConnection] - Bridge is connected, connection skipped
                                    16:25:22.304 [DEBUG] [rs.internal.protocol.MySensorsReader] - 1;0;1;0;1;47.6
                                    Things:
                                    Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {
                                       /** define things connected to that bridge here */
                                       humidity        hum01   [ nodeId="1", childId="0" ]
                                       temperature     temp01  [ nodeId="1", childId="1" ]
                                       power           power01 [ nodeId="2", childId="0" ]
                                    Items:
                                    Number hum01   "Humidity"              <humidity> { channel="mysensors:humidity:gateway:hum01:hum" }
                                    Number temp01  "Temperature"           <temperature> { channel="mysensors:temperature:gateway:temp01:temp" }
                                    Number temp01F "Temperature [%.1f °F]" <temperature>
                                    DateTime Sensor01LastUpdate "Last seen [%1$ta %1$tR]" <clock>
                                    DateTime Sensor02LastUpdate "Last seen [%1$ta %1$tR]" <clock>
                                    Number watt01  "Current Demand [%.0f Watt]" { channel="mysensors:power:gateway:power01:watt" }
                                    Number kwh01  "Daily Use [%.1f kWh]"        { channel="mysensors:power:gateway:power01:kwh" }
                                    What am i doing wrong?
                                    • carlylerC
                                      carlylerC
                                      carlyler
                                      OK, I think I got past that, I reinstalled everything and cleaned up my MySensors libraries.There is a chance I was pulling from different version when compiling the different examples from different packages.
                                      But, I noticed this exception at OH2 startup:
                                      06:29:26.838 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from UNINITIALIZED to INITIALIZING
                                      06:29:26.924 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 1, chiledId: 1, revertState: false
                                      06:29:26.924 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 1, chiledId: 0, revertState: false
                                      06:29:26.932 [DEBUG] [ternal.handler.MySensorsThingHandler] - Configuration: node 2, chiledId: 0, revertState: false
                                      06:29:26.951 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:humidity:gateway:hum01' changed from UNINITIALIZED to INITIALIZING
                                      06:29:26.946 [DEBUG] [col.serial.MySensorsSerialConnection] - Set skip check on startup to: false
                                      06:29:26.956 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                                      06:29:26.964 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:temp01' changed from UNINITIALIZED to INITIALIZING
                                      06:29:26.969 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:power:gateway:power01' changed from UNINITIALIZED to INITIALIZING
                                      06:29:26.993 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                                      06:29:27.001 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/pts/3 [baudRate:115200]
                                      06:29:27.032 [DEBUG] [ternal.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                                      06:29:27.067 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:bridge-ser:gateway' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
                                      06:29:27.041 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'mysensors:bridge-ser:gateway': java.lang.UnsupportedOperationException
                                      java.util.concurrent.ExecutionException: java.lang.UnsupportedOperationException
                                      	at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_65]
                                      	at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_65]
                                      	at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                                      	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                                      	at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                                      	at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:755)[106:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
                                      	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
                                      	at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_65]
                                      	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_65]
                                      	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_65]
                                      	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
                                      	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
                                      	at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
                                      Caused by: java.lang.UnsupportedOperationException
                                      	at java.util.AbstractList.add(AbstractList.java:148)[:1.8.0_65]
                                      	at java.util.AbstractList.add(AbstractList.java:108)[:1.8.0_65]
                                      	at org.openhab.binding.mysensors.internal.handler.MySensorsBridgeHandler.loadCacheFile(MySensorsBridgeHandler.java:176)[10:org.openhab.binding.mysensors:2.0.0.201610021604]
                                      	at org.openhab.binding.mysensors.internal.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:90)[10:org.openhab.binding.mysensors:2.0.0.201610021604]
                                      	at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:758)[106:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
                                      	at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)[106:org.eclipse.smarthome.core.thing:0.9.0.201610220816]
                                      	at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)[99:org.eclipse.smarthome.core:0.9.0.201610220816]
                                      	... 3 more
                                      06:29:27.198 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/pts/3
                                      06:29:27.232 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
                                      06:29:27.234 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
                                      06:29:29.428 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                                      06:29:29.897 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                                      06:29:30.262 [DEBUG] [rs.internal.protocol.MySensorsReader] - ;255;3;0;14;Gateway startup complete.
                                      06:29:30.274 [ERROR] [rs.internal.protocol.MySensorsReader] - (java.lang.NumberFormatException: For input string: "") on reading from serial port, message: class org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialReader
                                      06:29:30.283 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;0;0;18;2.0.1-beta
                                      Things still seem to work, but do I have something wrong?
                                      andreacioniA 1 Reply Last reply
                                      • carlylerC carlyler
                                        	... 3 more
                                        andreacioniA
                                        andreacioniA
                                        andreacioni
                                        Hi @carlyler :)
                                        what version of JVM are you using? 1.7 or 1.8?
                                        carlylerC 1 Reply Last reply
                                        • andreacioniA andreacioni
                                          Hi @carlyler :)
                                          carlylerC
                                          carlylerC
                                          carlyler
                                          @andreacioni after reading this thread I realized you have done a lot of work here as well, thank you.
                                          I am running:
                                          pi@raspberrypi:~ $ java -version
                                          java version "1.8.0_65"
                                          Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
                                          Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
                                          pi@raspberrypi:~ $
