  3. A very beginner needs help - MySensors and OpenHab !
43 Posts 7 Posters 33.2k Views 6 Watching
  • E Offline
    E Offline
    ewgor
    People, still struggling to get the relay with button actuator working with openhab!
    This time im using the Arduino example from here http://www.mysensors.org/build/relay (the 2nd one) with this Openhab configuration:
    Rules (forget the temp and hum part):
    import org.openhab.core.library.types.*
    import org.openhab.core.persistence.*
    import org.openhab.model.script.actions.*
    import org.joda.time.*
    import java.util.*
    import org.eclipse.xtext.xbase.lib.*
    import org.openhab.core.items.*
    var String ArduinoUpdate = ""
    var String sketchName = ""
    var int V_TEMP = 0
    var int V_HUM = 1
    var int V_LIGHT = 2
    var int V_DIMMER = 3
    var int V_PRESSURE = 4
    var int V_FORECAST = 5
    var int V_RAIN = 6
    var int V_RAINRATE = 7
    var int V_WIND = 8
    var int V_GUST = 9
    var int V_DIRECTION = 10
    var int V_UV = 11
    var int V_WEIGHT = 12
    var int V_DISTANCE = 13
    var int V_IMPEDANCE = 14
    var int V_ARMED = 15
    var int V_TRIPPED = 16
    var int V_WATT = 17
    var int V_KWH = 18
    var int V_SCENE_ON = 19
    var int V_SCENE_OFF = 20
    var int V_HEATER = 21
    var int V_HEATER_SW = 22
    var int V_LIGHT_LEVEL = 23
    var int V_VAR1 = 24
    var int V_VAR2 = 25
    var int V_VAR3 = 26
    var int V_VAR4 = 27
    var int V_VAR5 = 28
    var int V_UP = 29
    var int V_DOWN = 30
    var int V_STOP = 31
    var int V_IR_SEND = 32
    var int V_IR_RECEIVE = 33
    var int V_FLOW = 34
    var int V_VOLUME = 35
    var int V_LOCK_STATUS = 36
    var int V_DUST_LEVEL = 37
    var int V_VOLTAGE = 38
    var int V_CURRENT = 39
    var int msgPresentation = 0
    var int msgSet = 1
    var int msgReq = 2
    var int msgInternal = 3
    var int msgStream = 4
    var int alarmArmor = 1
    // Internal Commands
    var int I_BATTERY_LEVEL = 0
    var int I_TIME = 1
    var int I_VERSION = 2
    var int I_ID_REQUEST = 3
    var int I_ID_RESPONSE = 4
    var int I_INCLUSION_MODE = 5
    var int I_CONFIG = 6
    var int I_FIND_PARENT = 7
    var int I_FIND_PARENT_RESPONSE = 8
    var int I_LOG_MESSAGE = 9
    var int I_CHILDREN = 10
    var int I_SKETCH_NAME = 11
    var int I_SKETCH_VERSION = 12
    var int I_REBOOT = 13
    var int I_GATEWAY_READY = 14
    // Mappings
    var HashMap<String, String> sensorToItemsMap = newLinkedHashMap(
        "101;0;"            -> "livingHum01",    // looks good
        "livingHum01"       -> "101;0;",
    	"101;3;"            -> "livingTemp01",
        "livingTemp01"      -> "101;3;"
       "101;1;"            -> "lightBar01",
        "lightBar01"      -> "101;1;"
    //receiving msg from mysensors gateway
    rule "Arduino sends to Openhab"
        when
            Item Arduino received update
        then
            var String lineBuffer =  Arduino.state.toString.split("\n")
            for (String line : lineBuffer) {
                var String[] message = line.split(";")
                var Integer nodeId = new Integer(message.get(0))
                var Integer childId = new Integer(message.get(1))
                var Integer msgType = new Integer(message.get(2))
                var Integer ack = new Integer(message.get(3))
                var Integer subType = new Integer(message.get(4))
                var String msg = message.get(5)
                if(msgType == 1 ){
                    if (subType == V_TEMP){
                        postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), msg)
                        println ("Temp item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " temp: " + msg )
                    if (subType == V_HUM){
                        println ("Hum item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " hum: " + msg )
                    if (subType == V_WATT){
                        println ("Watt item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " watt: " + msg )
    				if (subType == V_KWH){
                        println ("Kwh item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " kwh: " + msg )
                    if (subType == V_LIGHT){
                        var String state
                        var Integer statusInt = new Integer(message.get(5))
                        if(statusInt == 1) {
                            state = "ON"
                        else {
                            state = "OFF"
                        postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), state)
                        println ("Light Item: " + sensorToItemsMap.get( nodeId + ";" + childId + ";") + " Light: " + state )
                // Internal Command
                if(msgType == 3){
                    if(subType == I_SKETCH_NAME){
                            println("Sketch name: " + msg )
                            sketchName=msg
                    if(subType == I_SKETCH_VERSION){
                            println("Sketch version: " + msg )
                            postUpdate(sensorToItemsMap.get( nodeId + ";" + childId + ";"), sketchName+" " +msg )
                            sketchName=""
    end
    rule "Light"
            when
                    Item lightBar01 received update
            then
                   if(receivedCommand == ON) {
                sendCommand(Arduino, "101;1;1;0;2;1\n")
            if(receivedCommand == OFF) {
               sendCommand(Arduino, "101;1;1;0;2;0\n")
    end
    items:
    String Arduino "Arduino" { serial="COM4@115200" }
    Number          livingTemp01                            "Temperatura [%.1f °C]" <temperature>
    Number          livingHum01                             "Umiditate [%.1f %%]" <water>
    Number          livingWatt01                             "Consum Electric Watt [%.1f Watt]" <energy>
    Number          livingKwh01                             "Consum Electric Kilowattora [%.1f kWh]" <energy>
    Switch           lightBar01                          "Bar Lights"
    Switch           lightKitchenCabinet01               "Cabinet Lights"
    sitemap:
    sitemap demo label="Acasa"
      Frame label="Dormitor" {
        Text item=livingTemp01
        Text item=livingHum01
        Text item=livingWatt01
    	Text item=livingKwh01
       Frame label="Lights" {
            Group label="Lights" {
                Switch item=lightBar01 label="Bar Lights"
                Switch item=lightKitchenCabinet01 label="Cabinet Lights"
    The physical button is connected to digital pin 3 and a LED to digital pin 4.
    If the LED is switched on/ off from physical button the server shows this:
    2015-07-31 11:36:02.067 [INFO ] [runtime.busevents             ] - Arduino state
     updated to 0;0;3;0;9;read: 101-101-0 s=1,c=1,t=2,pt=2,l=2:1
    0;0;3;0;9;send: 0-0-101-101 s=1,c=1,t=2,pt=2,l=2,st=ok:1
    101;1;1;0;2;1
    If the Openhab switch is activated on/off the server shows this:
    2015-07-31 11:38:13.435 [INFO ] [runtime.busevents             ] - lightBar01 re
    ceived command ON
    but the LED is not switching on or off.
    On the other hand when pressing the physical button on / off the LED is working but the switch in Openhab is not moving or refreshing.
    i'm trying to take it easy! please help masters :)
    • E Offline
      E Offline
      ewgor
      Update:
      i noticed that if i leave only the light Openhab config as bellow, when pressing the physical button on my breadboard it turns the led on or off and it changes the Openhab switch state from on to off and vice-versa but it doesn't work from Openhab to Arduino.
      Openhab configuration (sitemap, items, rules):
      // items
      //sitemap
      //rules
      import java.util.*
      var int V_TEMP = 0
      var int V_HUM = 1
      var int V_LIGHT = 2
      var int V_RAIN = 6
      var int V_WIND = 8
      var int V_GUST = 9
      var int V_UV = 11
      var int V_WATT = 17
      var int V_KWH = 18
      var int V_VAR1 = 24
      var int V_VAR2 = 25
      var int V_VAR3 = 26
      var int V_VAR4 = 27
      var int V_VAR5 = 28
      var int V_UP = 29
      var int V_DOWN = 30
      var int V_STOP = 31
      var int V_FLOW = 34
      var int msgSet = 1
      var int msgReq = 2
      var int I_TIME = 1
      // Mappings
          "101;1;"            -> "lightBar01",    // looks good
          "lightBar01"       -> "101;1;",
          when
          then
                  if(msgType == 1 ){
                          var String state
                              state = "ON"
                          else {
                              state = "OFF"
                  // Internal Command
                  if(msgType == 3){
                              sketchName=msg
                              sketchName=""
      end
      rule "Light"
              when
              then
      end
      The server returns this error but its still working:
      2015-07-31 17:52:01.787 [INFO ] [runtime.busevents             ] - lightBar01 st
      ate updated to ON
      Light Item: lightBar01 Light: ON
      2015-07-31 17:52:01.795 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during
      the execution of rule 'Light': The name 'receivedCommand' cannot be resolved to
      an item or type.
      If i delete the rule "light" (the last part of rule file) the server doesn't show the error and the server still works so pressing the physical button it turns on or off the LED and it change the Openhab switch from on to off but from Openhab to Arduino, the same, still not communicating, not turning any LED!
      This is how the server looks if i delete the rule "light" and i press the physical button on my breadboard:
      2015-07-31 17:56:03.448 [INFO ] [runtime.busevents             ] - lightBar01 st
      ate updated to OFF
      Light Item: lightBar01 Light: OFF
      and switching from Openhab but without changing the LED real state:
      2015-07-31 17:57:43.719 [INFO ] [runtime.busevents             ] - lightBar01 re
      ceived command ON
      2015-07-31 17:57:45.004 [INFO ] [runtime.busevents             ] - lightBar01 re
      ceived command OFF
      This makes sens and the problem i know is on the rule file. Now is there anyone who can help me make this work from Openhab to Arduino too? thanks all for your kindness :)
      PS: using the Arduino relay with button actuator sketch on which i added the node id 101 and the pins 48,49 for my Arduino mega.
      • E Offline
        E Offline
        ewgor
        No body? Any idea?
        • T Offline
          T Offline
          TimO
          Found it!
          "received command" not "received update"!
          rule "Light"
                  when
                          Item lightBar01 received command
                  then
          end
          E 1 Reply Last reply
          • T TimO
            Found it!
            rule "Light"
                    when
                    then
            end
            E Offline
            E Offline
            ewgor
            @TimO yuhuuuuuuu super! finally the damn led works ! thanks @TimO one small step for mankind but a huge step for me :)
            • E Offline
              E Offline
              ewgor
              @TimO finally I managed to add the dht 11 too and it works fine. Can you please tell me what to change in the rule file to add more buttons (same as this one that works)? I tried to change some parts of the light address but it doesn't work.
              I would like to add a normal button too (not like a switch) with a door symbol like door open or close for my exit door and to change its status from blue to red when you push the button.
              Thank you for the help you gave me by now!
              All the best!
              • E Offline
                E Offline
                ewgor
                wrote on last edited by ewgor
                #27
                Hi All,
                Can anyone please tell me if I want to add a few more buttons (same as this one with relay with button actuator) what should i change in the Openhab rules and in the Arduino sketch too? can it be done as the relay actuator example ?
                i mean first relay is connected to pin 3 and the next relay to pin 3+1=4, pin 4+1=5 and so on and the buttons pins to be alocated in the same way? is there any way to do it like this but for the relay with button actuator example?
                In the Openhab rules i tried to modify as i said above some of the addresses of the commands on or off from here:
                except the last numbers which i understand are like 1 for ON and 0 for OFF but it didn't work.
                The last thing that i would like to add is related only to Openhab if ill get an answer or a suggestion to my ask here above is a normal button (not like a slider) to control an electrical strike through a relay so when pressed once door open for 5 seconds or more and than close again. I know that here are more to discuss because maybe the door its not gonna be psychically closed but the Openhab status could show that the door is closed but this can be solved with a magnetic contact (i think) that can be added so the Openhab rules should be made like so: if the magnetic contact is connected than the door is closed and locked, else the door is open / unlocked even the electrical strike is closed until the magnetic contact will be connected! or to close the electrical strike only after the magnetic contact is closed.
                OH too much talking, I know this is maybe too much for me but theoretical speaking I know how to make it and I think i know how to set up the connection but physically is impossible because of missing knowledge in programming Arduino or Openhab!
                Lets take it one by one: Can anyone help me with first part of my request, how to add a few more buttons same as the only one working now?
                Thanks all
                • E Offline
                  E Offline
                  ewgor
                  People i see that this post was seen by more than 2k times but nobody is answering! How is this possible? Nobody knows how to do it or everybody enjoy watching a noob asking for help? Common people at least off topic let's say hi each other!
                  H 1 Reply Last reply
                  • E ewgor
                    H Offline
                    H Offline
                    Hey @ewgor, tone it down a bit. You won't get any answers by acting aggressive.
                    It could be as simple as no-one has the the answer and you got to find a solution yourself.
                    • H hek
                      E Offline
                      E Offline
                      ewgor
                      @hek thanks for the answer. At least now i know i'm not alone :). Anyhow as far as i've seen by now only @TimO was the only one who answered me and gave me some info. It is possible that non of the heros, admins or other kind of this forum members to have a suggestion for me?
                      Sorry if i was aggressive again!
                      Good help :)
                      • T Offline
                        T Offline
                        TimO
                        Well, the short answer for this is yes. It depends on your sketch. The loop with pin+1 is just a short notation.
                        I would suggest to start with the simple sketch with one button here: http://www.mysensors.org/build/binary
                        Give the node a static id, change items, rules and sitemap in OH.
                        You have to change V_TRIPPED to V_LIGHT:
                        So the OH rule with V_LIGHT will match and the item state is changed, when the button is pressed.
                        • E Offline
                          E Offline
                          ewgor
                          Oh TimO i thought i'll never see you again here :) thanks for the answer.
                          I'm using the RelayWithButtonActuator example on which i added the humidity and temperature part and its working well. I choose this example because in this way i can get in real time the light status in Openhab even the light is turned ON / OFF from physical button on the breadboard or from the Openhab button.
                          The Openhab rules are already made with the V_LIGHT command not the V_TRIPPED.
                          I cant figure out what to add in the Arduino sketch to add more relays and more buttons and to make it work in the setup or loop functions. Than, on the Openhab rules i tried to copy the only light rule i have right now and to change some of the numbers in the
                          but its not working :(
                          If i'll get at least 5 buttons and 5 relays working in this way it would be perfect.
                          Looking for any answer.
                          • E Offline
                            E Offline
                            ewgor
                            Hello? TimO? :) are you there?
                            • T Offline
                              T Offline
                              TimO
                              Well, there are many approaches and I would go the easiest (but not the most elegant) way.
                              Double everything for every additional button / relay. If that works for two/three buttons/relays use arrays (like in the relay example sketch).
                              #include <Bounce2.h>
                              #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                              #define RELAY_PIN2 5 ######## ADD THAT ######
                              #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                              #define BUTTON_PIN2 6 ######## ADD THAT ######
                              #define CHILD_ID2 2 ######## ADD THAT ######
                              #define RELAY_ON 1
                              #define RELAY_OFF 0
                              Bounce debouncer = Bounce();
                              Bounce debouncer2 = Bounce(); ######## ADD THAT ######
                              int oldValue=0;
                              int oldValue2=0; ######## ADD THAT ######
                              bool state;
                              bool state2; ######## ADD THAT ######
                              MyMessage msg(CHILD_ID,V_LIGHT);
                              MyMessage msg2(CHILD_ID2,V_LIGHT); ######## ADD THAT ######
                                gw.sendSketchInfo("Relay & Button", "1.0");
                               // Setup the button
                                pinMode(BUTTON_PIN,INPUT);
                                pinMode(BUTTON_PIN2,INPUT); ######## ADD THAT ######
                                // Activate internal pull-up
                                digitalWrite(BUTTON_PIN2,HIGH); ######## ADD THAT ######
                                debouncer.attach(BUTTON_PIN);
                                debouncer2.attach(BUTTON_PIN2); ######## ADD THAT ######
                                debouncer.interval(5);
                                debounder2.interval(5);######## ADD THAT ######
                                gw.present(CHILD_ID, S_LIGHT);
                                gw.present(CHILD_ID2,S_LIGHT);######## ADD THAT ######
                                digitalWrite(RELAY_PIN2,RELAY_OFF); ######## ADD THAT ######
                                pinMode(RELAY_PIN, OUTPUT);
                                pinMode(RELAY_PIN2, OUTPUT); ######## ADD THAT ######
                                state = gw.loadState(CHILD_ID);
                                state2 = gw.loadState(CHILD_ID2); ######## ADD THAT ######
                                digitalWrite(RELAY_PIN2, state2?RELAY_ON:RELAY_OFF); ######## ADD THAT ######
                                gw.process();
                                debouncer.update();
                                debounder2.update(); ######## ADD THAT ######
                                // Get the update value
                                int value = debouncer.read();
                                if (value != oldValue && value==0) {
                                    gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                                oldValue = value;
                              value = debouncer2.read(); ######## ADD THAT ######
                                if (value != oldValue2 && value==0) { ######## ADD THAT ######
                                    gw.send(msg2.set(state?false:true), true); // Send new state and request ack back ######## ADD THAT ######
                                } ######## ADD THAT ######
                                oldValue2 = value; ######## ADD THAT ######
                                if (message.isAck()) {
                                   // Change relay state
                                   state = message.getBool();
                                   if(message.sensor == 1) { ######## ADD THAT ######
                                     // Store state in eeprom
                                     gw.saveState(CHILD_ID, state);
                                   } else if(message.sensor == 2) { ######## ADD THAT ######
                                     digitalWrite(RELAY_PIN2, state?RELAY_ON:RELAY_OFF); ######## ADD THAT ######
                                     // Store state in eeprom ######## ADD THAT ######
                                     gw.saveState(CHILD_ID2, state); ######## ADD THAT ######
                                   // Write some debug info
                                   Serial.print(message.sensor);
                              The code is not tested nor compiled, but I hope you'll get the idea of how to add a button and a relay.
                              Of course this could be done much more elegant with arrays, that could be your next step.
                              • E Offline
                                E Offline
                                ewgor
                                #35
                                Wow! thanks for your time to fill this sketch! appreciate that.
                                I tried your sketch and after cleaning some small mistakes i got these errors and i don't know how to lose them.
                                this is how the sketch looks:
                                #define RELAY_PIN2 5 //######## ADD THAT ######
                                #define BUTTON_PIN2 6 //######## ADD THAT ######
                                #define CHILD_ID2 2 //######## ADD THAT ######
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                Bounce debouncer2 = Bounce(); //######## ADD THAT ######
                                int oldValue=0;
                                int oldValue2=0; //######## ADD THAT ######
                                bool state;
                                bool state2; //######## ADD THAT ######
                                MyMessage msg2(CHILD_ID2,V_LIGHT); //######## ADD THAT ######
                                 // Setup the button
                                  pinMode(BUTTON_PIN2,INPUT); //######## ADD THAT ######
                                  digitalWrite(BUTTON_PIN2,HIGH); //######## ADD THAT ######
                                  debouncer2.attach(BUTTON_PIN2); //######## ADD THAT ######
                                  debouncer2.interval(5);//######## ADD THAT ######
                                  gw.present(CHILD_ID2, S_LIGHT);//######## ADD THAT ######
                                  digitalWrite(RELAY_PIN2, RELAY_OFF); //######## ADD THAT ######
                                  pinMode(RELAY_PIN2, OUTPUT); //######## ADD THAT ######
                                  state2 = gw.loadState(CHILD_ID2); //######## ADD THAT ######
                                  digitalWrite(RELAY_PIN2, state2?RELAY_ON:RELAY_OFF); //######## ADD THAT ######
                                  gw.process();
                                  debouncer.update();
                                  debouncer2.update(); //######## ADD THAT ######
                                  oldValue = value;
                                  int value2 = debouncer2.read();
                                  if (value2 != oldValue && value==0) {
                                  oldValue2 = value;
                                     if(message.sensor == 1) { //######## ADD THAT ######
                                     } else if(message.sensor == 2) { //######## ADD THAT ######
                                       digitalWrite(RELAY_PIN2, state?RELAY_ON:RELAY_OFF); //######## ADD THAT ######
                                       gw.saveState(CHILD_ID2, state); //######## ADD THAT ######
                                and those are the errors:
                                sketch_sep09a.ino:81:3: error: expected unqualified-id before 'if'
                                sketch_sep09a.ino:84:3: error: 'oldValue2' does not name a type
                                sketch_sep09a.ino:85:1: error: expected declaration before '}' token
                                Error compiling.
                                About the OH rules i made them like this:
                                rule "Light"
                                        when
                                                Item lightBar02 received command
                                        then
                                end
                                what do you think? do i still need to modify something?
                                Thank you a lot!:pray:
                                • T Offline
                                  T Offline
                                  TimO
                                  There is a copy & paste error. Remove the bracket after "oldValue = value;" :)
                                  The OH rule looks good.
                                  • T TimO
                                    E Offline
                                    E Offline
                                    ewgor
                                    @TimO still doesnt want to compile :(
                                    this is the last error:
                                    sketch_sep10b.ino:81:3: error: expected unqualified-id before 'if'
                                    Error compiling.
                                    Thanks!
                                    • T Offline
                                      T Offline
                                      TheoL
                                      wrote on last edited by TheoL
                                      #38
                                      You have a closing bracelet ({) too much that's ending your loop() method. I corrected it and added a comment so you can see what's been causing the problem.
                                      #define RELAY_ON 1
                                      #define RELAY_OFF 0
                                      int oldValue=0;
                                      bool state;
                                       // Setup the button
                                        gw.process();
                                        debouncer.update();
                                        oldValue = value;
                                      // }  <---- remove this bracelet it's closing the loop() method. Then your compiler sees an if statement that's not in a method, which is not allowed
                                        oldValue2 = value;
                                      Good luck with it.
                                      b.t.w. I have no knowledge of openHab.
                                      • T TheoL
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        int oldValue=0;
                                        bool state;
                                         // Setup the button
                                          gw.process();
                                          debouncer.update();
                                          oldValue = value;
                                          oldValue2 = value;
                                        Good luck with it.
                                        E Offline
                                        E Offline
                                        ewgor
                                        @TheoL thanks man, I'll try it right now, thanks again.
                                        • E Offline
                                          E Offline
                                          ewgor
                                          #40
                                          Guys, i tried this sketch above and now it can be uploaded but its not working well.
                                          The system reacts like this: the first button ( old one) turns the led on / off on the breadboard but its not refreshing the OH button on the webpage and i get some i get some WARN on the server like this:
                                          2015-09-11 19:02:29.052 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                          oes not exist.
                                          Light Item: null Light: ON
                                          2015-09-11 19:02:29.073 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                          oes not exist.
                                          2015-09-11 19:02:29.085 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                          oes not exist.
                                          2015-09-11 19:02:30.701 [INFO ] [runtime.busevents             ] - Arduino state
                                           updated to 0;0;3;0;9;read: 22-22-0 s=1,c=1,t=2,pt=2,l=2:0
                                          0;0;3;0;9;send: 0-0-22-22 s=1,c=1,t=2,pt=2,l=2,st=fail:0
                                          22;1;1;0;2;0
                                          0;0;3;0;9;read: 22-22-0 s=2,c=1,t=2,pt=2,l=2:0
                                          0;0;3;0;9;send: 0-0-22-22 s=2,c=1,t=2,pt=2,l=2,st=fail:0
                                          22;2;1;0;2;0
                                          22;2;1;0;2;0
                                          0;0;3;0;9;send: 0-0-22-22 s=2,c=1,t=2,pt=2,l=2,st=ok:0
                                          22;2;1;0;2;0
                                          2015-09-11 19:02:30.719 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                          oes not exist.
                                          Light Item: null Light: OFF
                                          2015-09-11 19:02:30.742 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                          oes not exist.
                                          2015-09-11 19:02:30.755 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                          oes not exist.
                                          2015-09-11 19:02:30.761 [WARN ] [.model.script.actions.BusEvent] - Item 'null' d
                                          oes not exist.
                                          I don't understand why i get so many things on the server pressing once on and once off!
                                          The second button is completely dead, it doesn't do anything on the breadboard or on the web.
                                          I think the Arduino sketch has some bugs somewhere even it can be compiled. Maybe something inside is wrong or maybe this is not the right way to multiply relays and buttons.
                                          Please see bellow my OH settings.
                                          Items:
                                          Switch           lightBar01                          "Lumina dormitor"
                                          Switch           lightBar02                          "Lumina hol"
                                          Sitemap:
                                             Frame label="Lumini" {
                                                      Switch item=lightBar01 label="Lumina dormitor"
                                          			Switch item=lightBar02 label="Lumina hol"
                                          Rules:
                                          import java.util.*
                                          var int V_TEMP = 0
                                          var int V_HUM = 1
                                          var int V_LIGHT = 2
                                          var int V_RAIN = 6
                                          var int V_WIND = 8
                                          var int V_GUST = 9
                                          var int V_UV = 11
                                          var int V_WATT = 17
                                          var int V_KWH = 18
                                          var int V_VAR1 = 24
                                          var int V_VAR2 = 25
                                          var int V_VAR3 = 26
                                          var int V_VAR4 = 27
                                          var int V_VAR5 = 28
                                          var int V_UP = 29
                                          var int V_DOWN = 30
                                          var int V_STOP = 31
                                          var int V_FLOW = 34
                                          var int msgSet = 1
                                          var int msgReq = 2
                                          var int I_TIME = 1
                                          // Mappings
                                          	"101;2;"            -> "lightBar01",    // looks good
                                              "lightBar02"       -> "101;2;"
                                              when
                                              then
                                                      if(msgType == 1 ){
                                                              var String state
        state = "ON"
                                                              else {
        state = "OFF"
                                                      // Internal Command
                                                      if(msgType == 3){
        sketchName=msg
        sketchName=""
                                          end
                                          rule "Light"
                                                  when
                                                  then
                                          end
                                          rule "Light"
                                                  when
                                                  then
                                          end
                                          Any suggestion will be kindly appreciated.
                                          Thanks!
                                          PS: I forgot to say that i added in the Arduino sketch the address of the node point:
                                          #define NODE_ID 101
                                          12.2k
