  2. Announcements
  3. 1.4 Beta
1.4 Beta
1.4betahelp
129 Posts 18 Posters 121.8k Views 4 Watching
  • DammeD Damme
    @hek ok, how many bytes does it use?
    @Damme
    If you want to store you own data in EEPROM you can use the provided saveState(), loadState(). It makes sure you won't overwrite anything important. If 256 bytes isn't enough you can start writing at position EEPROM_LOCAL_CONFIG_ADDRESS defined in MySensors.h.
      The 1.4 version of the MySenors Arduino library is new open for beta testing.
      Arduino library and examples
      https://github.com/mysensors/Arduino/tree/development
      Vera plugin (1.4)
      https://github.com/mysensors/Vera/tree/development
      Here are some of the hi-lights.
      • Improved communication reliability (now uses hardware acks and resend functionality).
      • Simplified sketches (only one include needed).
      • Most common sleep scenarios build in.
      • Helper for permanently storing values in the Arduinos EEPROM.
      • Acknowledgments can now be requested from gateway and other sensors in network.
      • Smaller footprint.
      • The message structure has been adopted to work better on RPi platform.
      • Binary payloads supported and used for integers between sensors.
      • Configuration message (only metric setting in it today).
      • Allow static parent (no dynamic lookups)
      • Callbacks for incoming messages and time. No synchronous waiting methods any more -> no missed messages.
      All examples in the development branch above has been converted to use the new functionality of the library.
      The new API:
      * Constructor
      * Creates a new instance of Sensor class.
      * @param _cepin The pin attached to RF24 Chip Enable on the RF module (defualt 9)
      * @param _cspin The pin attached to RF24 Chip Select (default 10)
      MySensor(uint8_t _cepin=9, uint8_t _cspin=10);
      * Begin operation of the MySensors library
      * Call this in setup(), before calling any other sensor net library methods.
      * @param incomingMessageCallback Callback function for incoming messages from other nodes or controller and request responses. Default is NULL.
      * @param nodeId The unique id (1-254) for this sensor. Default is AUTO(255) which means sensor tries to fetch an id from controller.
      * @param repeaterMode Activate repeater mode. This node will forward messages to other nodes in the radio network. Make sure to call process() regularly. Default in false
      * @param parentNodeId Use this to force node to always communicate with a certain parent node. Default is AUTO which means node automatically tries to find a parent.
      * @param paLevel Radio PA Level for this sensor. Default RF24_PA_MAX
      * @param channel Radio channel. Default is channel 76
      * @param dataRate Radio transmission speed. Default RF24_1MBPS
      void begin(void (* msgCallback)(const MyMessage &)=NULL, uint8_t nodeId=AUTO, boolean repeaterMode=false, uint8_t parentNodeId=AUTO, rf24_pa_dbm_e paLevel=RF24_PA_LEVEL, uint8_t channel=RF24_CHANNEL, rf24_datarate_e dataRate=RF24_DATARATE);
       * Return the nodes nodeId.
      uint8_t getNodeId();
      * Each node must present all attached sensors before any values can be handled correctly by the controller.
      * It is usually good to present all attached sensors after power-up in setup().
      * @param sensorId Select a unique sensor id for this sensor. Choose a number between 0-254.
      * @param sensorType The sensor type. See sensor typedef in MyMessage.h.
      * @param ack Set this to true if you want destination node to send ack back to this node. Default is not to request any ack.
      void present(uint8_t sensorId, uint8_t sensorType, bool ack=false);
       * Sends sketch meta information to the gateway. Not mandatory but a nice thing to do.
       * @param name String containing a short Sketch name or NULL  if not applicable
       * @param version String containing a short Sketch version or NULL if not applicable
      void sendSketchInfo(const char *name, const char *version, bool ack=false);
      * Sends a message to gateway or one of the other nodes in the radio network
      * @param msg Message to send
      * @return true Returns true if message reached the first stop on its way to destination.
      bool send(MyMessage &msg, bool ack=false);
       * Send this nodes battery level to gateway.
       * @param level Level between 0-100(%)
      void sendBatteryLevel(uint8_t level, bool ack=false);
      * Requests a value from gateway or some other sensor in the radio network.
      * Make sure to add callback-method in begin-method to handle request responses.
      * @param childSensorId  The unique child id for the different sensors connected to this Arduino. 0-254.
      * @param variableType The variableType to fetch
      * @param destination The nodeId of other node in radio network. Default is gateway
      void request(uint8_t childSensorId, uint8_t variableType, uint8_t destination=GATEWAY_ADDRESS);
       * Requests time from controller. Answer will be delivered to callback.
       * @param callback for time request. Incoming argument is seconds since 1970.
      void requestTime(void (* timeCallback)(unsigned long));
       * Processes incoming messages to this node. If this is a relaying node it will
      * Returns true if there is a message addressed for this node just was received.
      * Use callback to handle incoming messages.
      boolean process();
       * Returns the most recent node configuration received from controller
      ControllerConfig getConfig();
       * Save a state (in local EEPROM). Good for actuators to "remember" state between
       * power cycles.
       * You have 256 bytes to play with. Note that there is a limitation on the number
       * of writes the EEPROM can handle (~100 000 cycles).
       * @param pos The position to store value in (0-255)
       * @param Value to store in position
      void saveState(uint8_t pos, uint8_t value);
       * Load a state (from local EEPROM).
       * @param pos The position to fetch value from  (0-255)
       * @return Value to store in position
      uint8_t loadState(uint8_t pos);
      * Returns the last received message
      MyMessage& getLastMessage(void);
       * Sleep (PowerDownMode) the Arduino and radio. Wake up on timer.
       * @param ms Number of milliseconds to sleep.
      void sleep(int ms);
       * Sleep (PowerDownMode) the Arduino and radio. Wake up on timer or pin change.
       * See: http://arduino.cc/en/Reference/attachInterrupt for details on modes and which pin
       * is assigned to what interrupt. On Nano/Pro Mini: 0=Pin2, 1=Pin3
       * @param interrupt Interrupt that should trigger the wakeup
       * @param mode RISING, FALLING, CHANGE
       * @param ms Number of milliseconds to sleep or 0 to sleep forever
       * @return true if wake up was triggered by pin change and false means timer woke it up.
      bool sleep(int interrupt, int mode, int ms=0);
       * getInternalTemp
       * Read temp from internal (ATMEGA328 only) temperature sensor. This reading is very
       * inaccurate so we round the result to full degrees celsius.
       * http://playground.arduino.cc/Main/InternalTemperatureSensor
       * @return Temperature in full degrees Celsius.
      int getInternalTemp(void);
      ###To convert an old 1.3 sketch follow this guide:
      Include section
      Remove the following includes
      #include <Sleep_n0m1.h>
      #include <EEPROM.h>
      #include <RF24.h>
      #include <Sensor.h>
      #include <Relay.h>
      Add
      Global variable scope
      Change the following lines
      Sensor gw;
      or
      Relay gw;
      To
      Also message containers for outgoing messages. E.g. Light level message for child sensor id 1.
      MyMessage msg(1, V_LIGHT_LEVEL);
      ####Setup()
      In setup() replace sendPresentation with present.
      Also note that begin() now allows you to add an function-argument to get callbacks for incoming messages (actuators). begin also controls wether this node should act as an repeater node. See above for full argument list.
      ####Loop()
      The sending of values looks a bit different. The old sketches could look like this:
      gw.sendVariable(CHILD_ID_LIGHT, V_LIGHT_LEVEL, lux);
      In new code you send a value by using the MyMessage contaner defined in global scope. Fill it with the value to send like this (where lux is light level in this case).
       gw.send(msg.set(lux));
      Replace any sleeping with the new build in sleep functions. The old code might have a few lines like this:
      delay(500);
      gw.powerDown();
      sleep.pwrDownMode(); //set sleep mode
      sleep.sleepDelay(SLEEP_TIME * 1000);
      Replace those with:
      gw.sleep(<sleep time in milliseconds>);
      DammeD
      DammeD
      Damme
      Code Contributor
      wrote on last edited by Damme
      #62
      @hek I just cant figure this out:
      0;0;3;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
      0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=0,l=2,st=fail:42
      the last one isn't sent.What have I missed?
      I have also tried 42 as int (no "")
      	msg.destination = 255; 		//NodeID
      	msg.sender = GATEWAY_ADDRESS;
      	msg.sensor = 255;	  				//SensorID
      	msg.type = I_ID_RESPONSE;			//MsgType
      	mSetCommand(msg,C_INTERNAL); 		//Subtype
      	mSetRequestAck(msg,true);			//Request ack
      	mSetAck(msg,false);
      	msg.set("42");					//Payload
      	sendRoute(msg);
      hekH 1 Reply Last reply
        Vera plugin (1.4)
        The new API:
        * Constructor
        boolean process();
         * power cycles.
        void sleep(int ms);
         * getInternalTemp
        Include section
        #include <EEPROM.h>
        #include <RF24.h>
        #include <Sensor.h>
        #include <Relay.h>
        Add
        Sensor gw;
        or
        Relay gw;
        To
        ####Setup()
        ####Loop()
        delay(500);
        gw.powerDown();
        Replace those with:
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        @hek Do you know if the ota is something initiated by the controller or do we update the gateway with a new version and will the gateway be responsible?
        Fulltime Servoy Developer
        • marceltrapmanM marceltrapman
          @marceltrapman
          The controller will be responsible for initiating and serving the new sketch version. There is basically no changes in gateway except being able to handle binary data.
          • DammeD Damme
            	mSetAck(msg,false);
            	sendRoute(msg);
            @Damme
            You should probably not request ack back on a id-response. But I doubt that is the cause for transmission error. What is happening in the sensor node?
            DammeD 2 Replies Last reply
              @Damme
              DammeD
              DammeD
              Damme
              Code Contributor
              #66
              @hek Tried with no ack also. And the node doesn't recieve anything. I'm out of components to build myself a sniffer right now.. Might have to kill something.. :boom: I can recieve From the node though.. but the node does not read from gateway..
              • DammeD Damme
                @Damme
                You only live 190 km from me. Come and get some :smile:
                What kind of antenna on your gateway? Have you tried lowering transmit power of gateway?
                  @Damme
                  DammeD
                  DammeD
                  Damme
                  Code Contributor
                  #68
                  @hek I fixed the problem , it was the RF24_PA_LEVEL_GW .. needed to be low.
                  You are correct with the ack on id-response, it gets all fucked up. Stuck in loop requesting ID 10+times/second. And doesnt register the id.. Too bad. would be really good for me to know if the sensor actually got the id_response or not... (and if it's sent as node 255 or node newid doesnt really matter..)
                  edit:
                  I changed my aproach to checking if sendRoute(msg) is true. But I still have a problem that the node actually recieves the packagt but just ignored is. sometimes I need to reset the node for it to get accept the new ID.. example;
                  0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=1,l=1,st=ok:20
                  0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=1,l=1,st=ok:21
                  0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=1,l=1,st=ok:22
                  0;0;3;9;send: 0-0-255-255 s=255,c=3,t=4,pt=1,l=1,st=ok:23
                  I'll try to look at the debug output on the node tomorrow..
                  btw: \n missing line 278 mysensor.cpp debug(PSTR("version mismatch"));
                    @marceltrapman
                    marceltrapmanM
                    marceltrapmanM
                    marceltrapman
                    How do I get this started Henrik?
                      @marceltrapman
                      Until @ToSa is back, I suggest you have a look at how the NodeJSController serves hex-files.
                      https://github.com/mysensors/Arduino/blob/development/NodeJsController/NodeJsController.js
                      • YveauxY
                        YveauxY
                        #71
                        @hek I wanted to update my MQTT gateway to 1.4beta state but run into a problem with the serial message format.
                        If I interpret the code right, the messages sent (in serial message format) to the ethernet gateway (over ethernet, so from my linux system running the MQTT gateway) contain 6 fields, of which the 4th is the ack flag.
                        Messages received from the ethernet gateway contain 5 fields, with no ack indication.
                        Shouldn't the message format be identical in both directions, as it is for the 1.3 version?
                        • YveauxY Yveaux
                          @Yveaux
                          Yes, It might be interesting (for the controller side) to use the 4th field to flag if the received message is an ack or regular message.
                          ...so for outgoing you enable receiver to send ack back. And incoming the flag indicates if this as an ack or regular message.
                          Make sense?
                          YveauxY 1 Reply Last reply
                            @Yveaux
                            Make sense?
                            YveauxY
                            YveauxY
                            @hek said:
                            Make sense?
                            Makes sense ;-)
                            • JohnJ
                              JohnJ
                              John
                              Short question. I'm browsing the 1.4 code and is there a replacement for waitForMessage? I've looked into the code online but can't seem to find it. And if not, is it possible to attach the radio to an interrupt to call an interrupt routine on incoming message?
                              YveauxY hekH 2 Replies Last reply
                              • JohnJ John
                                YveauxY
                                YveauxY
                                #75
                                The last question is a definite yes, see for example https://github.com/Yveaux/NRF24_Sniffer/blob/master/Arduino/NRF24_sniff/NRF24_sniff.ino function handleNrfIrq. Connect the NRF24 IRQ to pin 2 and call attachInterrupt to register the interrup handler.
                                Be very careful what you do in this interrupt handler, though. Don't try to receive any message for example, as the SPI access to the NRF24 is not interrupt-proof, as is the MySensors library!
                                • JohnJ John
                                  @John
                                  Yep, as @Yveaux says, be careful what you do inside interrupt handler.
                                  Not sure what you try to archive here.. but in 1.4 you should usually just call process() in your loop(). The callback you registered a in begin(callback) will be called on incoming messages.
                                  See RelayActuator for an example.
                                  • JohnJ
                                    JohnJ
                                    John
                                    wrote on last edited by John
                                    #77
                                    @Yveaux
                                    Darn, i hoped it could.
                                    @hek
                                    I'm averaging sensor results, so i read sensors every second an send them every minute, also this setup has an 16x2 display attached to show the values. But i would like it to be bi-directional with the server so it can display the server send data. Thus if i would use waitForMessage i can let it wait about a second for a message read sensor values, and let it wait for a second again. (because i understood it blocks?)
                                    • JohnJ John
                                      @Yveaux
                                      @hek
                                      YveauxY
                                      YveauxY
                                      @John You can obtain the same result as the old waitForMessage by registering a callback. Have this callback set a flag and call process() in the loop, as hek suggests.
                                      You could also turn things around and read and average your sensors from a (timer)interrupt handler.
                                      But when you're not completely confident with using interrupts then its better to avoid them and just process everything from your loop(). Interrupts can introduce lots of nasty problems if you don't know exactly what you're doing!
                                      JohnJ 1 Reply Last reply
                                      • YveauxY Yveaux
                                        JohnJ
                                        JohnJ
                                        John
                                        @Yveaux
                                        Well, that was my first try and hoped it was interrupt based because of one wire connected on arduino pin 2 to IRQ on the NRF. The reason i asked it because i saw an example from an other library: http://maniacbug.github.io/RF24/pingpair_irq_8pde-example.html .
                                        I will have to investigate if any of the components is using which timer and what will be influenced by it. I'm using an HD44780 alike as display so i'm not sure because never dived deep into the used library.
                                        about 90%?
                                        @hek
                                        It would be nice if a waitForMessage like functionality would be included in 1.4.
                                        • clippermiamiC
                                          clippermiamiC
                                          clippermiami
                                          @hek Any idea when 1.4 will become the production version?
