  2. Announcements
  3. 1.4 Beta
1.4 Beta
1.4betahelp
129 Posts 18 Posters 121.8k Views 4 Watching
  • YveauxY Yveaux
    @hek said:
    but that might not be possible if we choose some other transportation layer
    Then the transportation layer data is not part of mysensors protocol. It's that simple!
    IMHO This again boils down to nested protocol headers which we talked about before.
    The routing info is part of transportation layer (it could even have its own version info) followed by the mysensors header ( starting with a version number) which tells us what's in the message. Then come the actual data, be it a value, presentation info or whatever. I can make a sketch of this structure if that helps in the discussion.
    @Yveaux
    I think we agree. Only problem is that I haven't split up the structure in mysensors-transportation/mysensors-header/mysensors-payload yet but if you look from the sniffer side this would not matter.
    Please post you suggested structure (but in a new thread).
    DammeD 1 Reply Last reply
      @Yveaux
      DammeD
      DammeD
      Damme
      Code Contributor
      I got this question from a friend and since I dont know the answer either;
      I'm trying to figure out the sleep mode and if the radio module wakes up or not (via INT pin 2) .. but for me it does not seam to do this. Which sleep-modes does 1.4b have and how do I see if the message is for me, and if not continue sleep?
      hekH 1 Reply Last reply
      • DammeD Damme
        @Damme
        The radio interrupts is not used at the moment.
        It uses the following sleep modes
        LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
        or
        LowPower.powerDown(SLEEP_XXXXS, ADC_OFF, BOD_OFF);
        Depending on if you want timer to wake up or not. Radio is always put to sleep.
        For more details, check out MySensor.cpp.
        • warawaraW
          warawaraW
          warawara
          I'm trying to create my own controller in Node-Red.
          My setup is as followed:
          Motion Sensor arduino with standard example sketch <--> SerialGateway arduino with standard example sketch <--> USB <--> Node-Red (installed on Raspberry PI)
          My SerialGateway receives the request for a node ID (255;255;3;0;3;)
          I then return a serial command: 255;255;3;0;4;1
          You can see my Node-Red output below:
          For some reason my SerialGateway is not broadcasting my command. It's only repeating the above commands sevral times;
          Am i using the correct protocol values or is there something else I should do?
          • warawaraW warawara
            @warawara
            Did you remember sending a newline?
            warawaraW 2 Replies Last reply
              @warawara
              warawaraW
              warawaraW
              warawara
              @hek
              Yes I did.
              My Node-Red is configured to send a newline after every command.
              But just to make sure I also tried adding it to the string.
              Same result.
                @warawara
                warawaraW
                warawaraW
                warawara
                @hek
                I assume sending de command in ascii is good or do I need to send a binary buffer?
                  @hek
                  @warawara
                  If it's working from your gateway Serial Monitor in IDE you must be doing something wrong in your program.
                    @warawara
                    warawaraW
                    warawaraW
                    warawara
                    @hek
                    Not working in IDE.
                      @warawara
                      warawaraW
                      warawaraW
                      warawara
                      @hek
                      Got it working, but my solution is not very satisfying.
                      I swapt the sketches on my 2 arduino's.
                      Original arduino setup was:
                      SerialGatway - Arduino pro mini 3.3v (including Decoupling-Capacitor)
                      Motion Sensor - Arduino Uno (including Decoupling-Capacitor)
                      Now the sketches are switched and it works.
                      Eventually I will be working with only Arduino pro mini's but still the original setup should have worked.
                        @hek
                        DammeD
                        DammeD
                        Damme
                        Code Contributor
                        @warawara did you try clearing using clear eeprom? That helped me some times. Dont really know why some nodes just wont want to recieve packages..
                        warawaraW 1 Reply Last reply
                        • DammeD Damme
                          warawaraW
                          warawaraW
                          warawara
                          @Damme
                          Thanks for the tip.
                          I will try that in the future. But I don't think it was a problem of not receiving on the sensor part. I think it was a problem with not sending on the Serial Gateway part.
                          But I got it working now!
                          • RJ_MakeR
                            RJ_MakeR
                            RJ_Make
                            Ok, So I took the plunge and upgraded to 1.4.b1, and everything went "OK" with one glaring exception...... All temperatures display in Celsius. No matter what I do, I can't seem to get it to display in Fahrenheit..
                            Any Idea's?
                            RJ_Make
                            • B
                              B
                              Bandra
                              @hek
                              I'd like to ask for a small change to be made to the sleep function.
                              When we call gw.sleep(x) or gw.sleep(x,y,z) then the arduino disables the interrupt timer (to save power) that triggers the counter that drives millis(). So the value returned from millis() stalls when we sleep.
                              This is ok on our battery powered devices, since it's saving power, but makes it hard to determine how long it's been since we sent values to the gateway.
                              For example, if I use this code:
                              if ((unsigned long)(millis() - timeOfLastSensorSend) >= MIN_SAMPLING_INTERVAL) {
                                  // read sensors and send to gateway
                                  timeOfLastSensorSend = millis();
                              gw.sleep(SLEEP_TIME);
                              Then it doesn't work because millis() does not increment while the the sketch is asleep.
                              I have a thought on how we can solve this but I have a to get to a work meeting.
                              • B
                                B
                                Bandra
                                Ok, back from meeting.
                                So, for sketches that don't need to sleep on interrupt, then things are ok because I can code around it like this:
                                timeOfLastSensorSend -= SLEEP_TIME;
                                My rationale here is that if millis doesn't increment then I should make my variable decrement by the same amount. Same effect.
                                However, the catch is when sleeping with interrupt. My thinking was to modify MySensors.cpp to change the return value of sleep. Something like this:
                                unsigned long MySensor::internalSleep(unsigned long ms) {
                                    unsigned long origMs = ms;
                                    while (continueTimer && ms >= 8000) { LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF); ms -= 8000; }
                                    if (continueTimer && ms >= 4000)    { LowPower.powerDown(SLEEP_4S, ADC_OFF, BOD_OFF); ms -= 4000; }
                                    if (continueTimer && ms >= 16)      { LowPower.powerDown(SLEEP_15Ms, ADC_OFF, BOD_OFF); ms -= 15; }
                                    return (origMs - ms);
                                unsigned long MySensor::sleep(unsigned long ms) {
                                    // Let serial prints finish (debug, log etc)
                                    Serial.flush();
                                    RF24::powerDown();
                                    continueTimer = true;
                                    return internalSleep(ms);
                                unsigned long MySensor::sleep(int interrupt, int mode, unsigned long  ms) {
                                    unsigned long sleptFor = 0;
                                    Serial.flush();
                                    RF24::powerDown();
                                    attachInterrupt(interrupt, wakeUp, mode); //Interrupt on pin 3 for any change in solar power
                                    if (ms>0) {
                                            sleptFor = sleep(ms);
                                    } else {
                                            Serial.flush();
                                    detachInterrupt(interrupt);
                                    return sleptFor;
                                So rather than return a boolean on sleep(x,y,z), return the amount of time it slept for before it was interrupted. The check of the boolean is replaced with a check if return code > 0.
                                Hopefully my ramblings make some kind of sense.
                                • RJ_MakeR RJ_Make
                                  Any Idea's?
                                  @ServiceXp
                                  The sensor fetches the unit setting from Vera at startup. Something probably fails during this data exchange. You'll have to look at the debug logs to see what happens.
                                  This behavior might change in 1.4 with sensors just reporting SI-units and controller makes the necessary conversion/scaling.
                                  RJ_MakeR 1 Reply Last reply
                                    @ServiceXp
                                    RJ_MakeR
                                    RJ_MakeR
                                    RJ_Make
                                    @hek
                                    This is the first time I've ssh into vera, so I have no idea what I'm looking for.. I have 2 Everspring ST-814's that display correctly, and of course 2 MySensor sensor which did in 1.3, but not in 1.4b1.
                                    I found this, but not sure if this is what you need.
                                    02 08/22/14 7:47:04.914 luup_log:87: Arduino: Incoming internal command '0;0;3;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5:22.6' discarded for child: nil <0x2f8b3680>
                                    50 08/22/14 7:47:04.916 luup_log:87: Arduino: Set variable: 2;1;1;0;0;22.6 <0x2f8b3680>
                                    50 08/22/14 7:47:04.916 luup_log:87: Arduino: Setting variable 'CurrentTemperature' to value '22.6' <0x2f8b3680>
                                    50 08/22/14 7:47:04.916 luup_log:87: Arduino: urn:upnp-org:serviceId:TemperatureSensor1,CurrentTemperature, 22.6, 92 <0x2f8b3680>
                                    06 08/22/14 7:47:04.917 Device_Variable::m_szValue_set device: 92 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 22.5 now: 22.6 #hooks: 3 upnp: 0 v:0xda4620/NONE duplicate:0 <0x2f8b3680>
                                    01 08/22/14 7:47:04.918 LuaInterface::CallFunction_Variable func: w_switch Device_Variable 92 urn:upnp-org:serviceId:TemperatureSensor1:CurrentTemperature failed [string "..."]:14: bad argument #1 to 'sub' (string expected, got nil) <0x2f8b3680>
                                    01 08/22/14 7:47:04.919 LuaInterface::CallFunction_Variable func: w_switch Device_Variable 92 urn:upnp-org:serviceId:TemperatureSensor1:CurrentTemperature failed [string "..."]:14: bad argument #1 to 'sub' (string expected, got nil) <0x2f8b3680>
                                    RJ_Make
                                    • RJ_MakeR RJ_Make
                                      @hek
                                      @ServiceXp
                                      The node will be transferring celsius data until it manage to receive settings from controller (this is done in the background) by setup().
                                      Attach your failing sensor to the computer. Upload sketch with debug enabled. And look at the Serial monitor. Restart a sensor a few times .
                                        @ServiceXp
                                        RJ_MakeR
                                        RJ_MakeR
                                        RJ_Make
                                        @hek
                                        Thanks, I'll do that when I get home later. Just so I'm clear..
                                        To enable debugging: I Remove the "//" before the #define DEBUG ** in and ONLY in** the /libraries/MySensors/Config.h file ? Then upload the sketch again to the sensors? (I don't have to upload the gateway sketch also do I?)
                                        RJ_Make
                                        • RJ_MakeR RJ_Make
                                          @hek
                                          @ServiceXp
                                          Yes correct!
