  2. Announcements
  3. 1.4 Beta
1.4 Beta
1.4betahelp
129 Posts 18 Posters 121.8k Views 4 Watching
    wrote on last edited by hek
    #41
    A major code drop coming from @ToSa has now been merged into 1.4. It contains:
    • The new MySensors Bootloader supporting Over-the-air sketch updates ("client"-side).
    • A simple NodeJs Controller to test the OTA stuff ("server"-side).
    • Changes to cope with new sketch meta data stored in EEPROM and conversion between serial protocol/binary data and some new STREAM command types added.
    • A new internal command has also been added to allow resetting a node remotely.
    A more detailed change log can be found here:
    https://github.com/ToSa27/Arduino/commits/development
    I haven't had time to test myself yet but everything has been verified by @ToSa and is reported working. He is on a business trip right now so advanced bootloader questions have to wait until he's back.
      marceltrapmanM
      marceltrapmanM
      marceltrapman
      @hek Sounds like a good step forward!
      Only one boot loader question: does this mean we can use an external boot loader or do we have to use an external boot loader now?
      Fulltime Servoy Developer
      hekH 1 Reply Last reply
      • marceltrapmanM marceltrapman
        @marceltrapman
        The OTA stuff is optional. But if you want to be able to hot deploy sketches over the air, you have to install the MySensors bootloader.
          Pushed a few new changes/bugfixes. Sorry for the slow progress. Had to wait until we got home and had the chance to do some verification.
          • Ack bit in header indicating if message is an ack (see RelayWithButton for an example how to read it out).
          • Sleep functions now takes unsigned long. This allows sensor to sleep for than 30 sec ;)
          • Corrected string termination
          https://github.com/mysensors/Arduino/commits/development
          DammeD
          DammeD
          Damme
          Code Contributor
          wrote on last edited by Damme
          #44
          @hek There are still some problem with string termination,
          repeater started, id 3
          send: 3-3-0-0 s=255,c=0,t=18,pt=0,l=15,st=fail:1.4b1 (18848a2)
          send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
          send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=9,st=fail:Relaytest848a2)
          send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0aytest848a2)
          read: 5-5-0 s=11,c=1,t=1,pt=0,l=4:58.4
          send: 5-3-0-0 s=11,c=1,t=1,pt=0,l=4,st=fail:58.4
          send: 3-3-0-0 s=10,c=1,t=0,pt=0,l=5,st=fail:26.20
          DammeD 1 Reply Last reply
          • DammeD Damme
            DammeD
            DammeD
            Damme
            Code Contributor
            @Damme My bad wrong working directory! sorry
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              Thank you :)
                marceltrapmanM
                marceltrapmanM
                marceltrapman
                And thanks again!!!
                • T
                  timminater
                  wrote on last edited by timminater
                  #48
                  How do I request information from a node from the gateway?
                  I have a relayactuator node with 2 relays that is transmitting its initial state at the startup of the node. This is also received by the gw.
                  But after that I cant seem to request the current relay status from the node by sending a message from the gateway.
                  I tried lots of combinations, nothing worked.
                  I thought this would be correct:
                  1;2;2;1;2;0\n
                  1=node number
                  2=sensor (relay number 2)
                  2=request
                  1=ack message
                  2=light
                  0=string??
                  Can anyone point me in the correct location?
                  maybe a new API page for 1.4 would be handy
                  edit: also I can't find anywhere what the debug letters mean
                  what is s=,c=,t=,pt=,l=,st= ??
                  • T timminater
                    1;2;2;1;2;0\n
                    1=node number
                    2=request
                    1=ack message
                    2=light
                    0=string??
                    @timminater
                    You cannot request state from a node without programming a little . I answered exactly this question a couple of posts back in this thread.
                    http://forum.mysensors.org/topic/168/1-4-beta/34
                      mitekg
                      @hek
                      Could u plz help me
                      getting in eth GW. Vera and Libs updated.
                      **0;0;3;9;Arduino startup complete.
                      0;0;3;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
                      0;0;3;9;version mismatch0;0;3;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
                      • M mitekg
                        @hek
                        Could u plz help me
                        @mitekg
                        All the zeroes indicates that something is wrong in radio communication. Check wires.
                          mitekg
                              Is any instructions, how to use this?
                              thx.
                            The 1.4 version of the MySenors Arduino library is new open for beta testing.
                            Arduino library and examples
                            https://github.com/mysensors/Arduino/tree/development
                            Vera plugin (1.4)
                            https://github.com/mysensors/Vera/tree/development
                            Here are some of the hi-lights.
                            • Improved communication reliability (now uses hardware acks and resend functionality).
                            • Simplified sketches (only one include needed).
                            • Most common sleep scenarios build in.
                            • Helper for permanently storing values in the Arduinos EEPROM.
                            • Acknowledgments can now be requested from gateway and other sensors in network.
                            • Smaller footprint.
                            • The message structure has been adopted to work better on RPi platform.
                            • Binary payloads supported and used for integers between sensors.
                            • Configuration message (only metric setting in it today).
                            • Allow static parent (no dynamic lookups)
                            • Callbacks for incoming messages and time. No synchronous waiting methods any more -> no missed messages.
                            All examples in the development branch above has been converted to use the new functionality of the library.
                            The new API:
                            * Constructor
                            * Creates a new instance of Sensor class.
                            * @param _cepin The pin attached to RF24 Chip Enable on the RF module (defualt 9)
                            * @param _cspin The pin attached to RF24 Chip Select (default 10)
                            MySensor(uint8_t _cepin=9, uint8_t _cspin=10);
                            * Begin operation of the MySensors library
                            * Call this in setup(), before calling any other sensor net library methods.
                            * @param incomingMessageCallback Callback function for incoming messages from other nodes or controller and request responses. Default is NULL.
                            * @param nodeId The unique id (1-254) for this sensor. Default is AUTO(255) which means sensor tries to fetch an id from controller.
                            * @param repeaterMode Activate repeater mode. This node will forward messages to other nodes in the radio network. Make sure to call process() regularly. Default in false
                            * @param parentNodeId Use this to force node to always communicate with a certain parent node. Default is AUTO which means node automatically tries to find a parent.
                            * @param paLevel Radio PA Level for this sensor. Default RF24_PA_MAX
                            * @param channel Radio channel. Default is channel 76
                            * @param dataRate Radio transmission speed. Default RF24_1MBPS
                            void begin(void (* msgCallback)(const MyMessage &)=NULL, uint8_t nodeId=AUTO, boolean repeaterMode=false, uint8_t parentNodeId=AUTO, rf24_pa_dbm_e paLevel=RF24_PA_LEVEL, uint8_t channel=RF24_CHANNEL, rf24_datarate_e dataRate=RF24_DATARATE);
                             * Return the nodes nodeId.
                            uint8_t getNodeId();
                            * Each node must present all attached sensors before any values can be handled correctly by the controller.
                            * It is usually good to present all attached sensors after power-up in setup().
                            * @param sensorId Select a unique sensor id for this sensor. Choose a number between 0-254.
                            * @param sensorType The sensor type. See sensor typedef in MyMessage.h.
                            * @param ack Set this to true if you want destination node to send ack back to this node. Default is not to request any ack.
                            void present(uint8_t sensorId, uint8_t sensorType, bool ack=false);
                             * Sends sketch meta information to the gateway. Not mandatory but a nice thing to do.
                             * @param name String containing a short Sketch name or NULL  if not applicable
                             * @param version String containing a short Sketch version or NULL if not applicable
                            void sendSketchInfo(const char *name, const char *version, bool ack=false);
                            * Sends a message to gateway or one of the other nodes in the radio network
                            * @param msg Message to send
                            * @return true Returns true if message reached the first stop on its way to destination.
                            bool send(MyMessage &msg, bool ack=false);
                             * Send this nodes battery level to gateway.
                             * @param level Level between 0-100(%)
                            void sendBatteryLevel(uint8_t level, bool ack=false);
                            * Requests a value from gateway or some other sensor in the radio network.
                            * Make sure to add callback-method in begin-method to handle request responses.
                            * @param childSensorId  The unique child id for the different sensors connected to this Arduino. 0-254.
                            * @param variableType The variableType to fetch
                            * @param destination The nodeId of other node in radio network. Default is gateway
                            void request(uint8_t childSensorId, uint8_t variableType, uint8_t destination=GATEWAY_ADDRESS);
                             * Requests time from controller. Answer will be delivered to callback.
                             * @param callback for time request. Incoming argument is seconds since 1970.
                            void requestTime(void (* timeCallback)(unsigned long));
                             * Processes incoming messages to this node. If this is a relaying node it will
                            * Returns true if there is a message addressed for this node just was received.
                            * Use callback to handle incoming messages.
                            boolean process();
                             * Returns the most recent node configuration received from controller
                            ControllerConfig getConfig();
                             * Save a state (in local EEPROM). Good for actuators to "remember" state between
                             * power cycles.
                             * You have 256 bytes to play with. Note that there is a limitation on the number
                             * of writes the EEPROM can handle (~100 000 cycles).
                             * @param pos The position to store value in (0-255)
                             * @param Value to store in position
                            void saveState(uint8_t pos, uint8_t value);
                             * Load a state (from local EEPROM).
                             * @param pos The position to fetch value from  (0-255)
                             * @return Value to store in position
                            uint8_t loadState(uint8_t pos);
                            * Returns the last received message
                            MyMessage& getLastMessage(void);
                             * Sleep (PowerDownMode) the Arduino and radio. Wake up on timer.
                             * @param ms Number of milliseconds to sleep.
                            void sleep(int ms);
                             * Sleep (PowerDownMode) the Arduino and radio. Wake up on timer or pin change.
                             * See: http://arduino.cc/en/Reference/attachInterrupt for details on modes and which pin
                             * is assigned to what interrupt. On Nano/Pro Mini: 0=Pin2, 1=Pin3
                             * @param interrupt Interrupt that should trigger the wakeup
                             * @param mode RISING, FALLING, CHANGE
                             * @param ms Number of milliseconds to sleep or 0 to sleep forever
                             * @return true if wake up was triggered by pin change and false means timer woke it up.
                            bool sleep(int interrupt, int mode, int ms=0);
                             * getInternalTemp
                             * Read temp from internal (ATMEGA328 only) temperature sensor. This reading is very
                             * inaccurate so we round the result to full degrees celsius.
                             * http://playground.arduino.cc/Main/InternalTemperatureSensor
                             * @return Temperature in full degrees Celsius.
                            int getInternalTemp(void);
                            ###To convert an old 1.3 sketch follow this guide:
                            Include section
                            Remove the following includes
                            #include <Sleep_n0m1.h>
                            #include <EEPROM.h>
                            #include <RF24.h>
                            #include <Sensor.h>
                            #include <Relay.h>
                            Add
                            Global variable scope
                            Change the following lines
                            Sensor gw;
                            or
                            Relay gw;
                            To
                            Also message containers for outgoing messages. E.g. Light level message for child sensor id 1.
                            MyMessage msg(1, V_LIGHT_LEVEL);
                            ####Setup()
                            In setup() replace sendPresentation with present.
                            Also note that begin() now allows you to add an function-argument to get callbacks for incoming messages (actuators). begin also controls wether this node should act as an repeater node. See above for full argument list.
                            ####Loop()
                            The sending of values looks a bit different. The old sketches could look like this:
                            gw.sendVariable(CHILD_ID_LIGHT, V_LIGHT_LEVEL, lux);
                            In new code you send a value by using the MyMessage contaner defined in global scope. Fill it with the value to send like this (where lux is light level in this case).
                             gw.send(msg.set(lux));
                            Replace any sleeping with the new build in sleep functions. The old code might have a few lines like this:
                            delay(500);
                            gw.powerDown();
                            sleep.pwrDownMode(); //set sleep mode
                            sleep.sleepDelay(SLEEP_TIME * 1000);
                            Replace those with:
                            gw.sleep(<sleep time in milliseconds>);
                            DammeD
                            DammeD
                            Damme
                            Code Contributor
                            @hek
                            I think BASE_RADIO_ID should be declared in MyCofig.h
                              Vera plugin (1.4)
                              The new API:
                              * Constructor
                              boolean process();
                               * power cycles.
                              void sleep(int ms);
                               * getInternalTemp
                              Include section
                              #include <EEPROM.h>
                              #include <RF24.h>
                              #include <Sensor.h>
                              #include <Relay.h>
                              Add
                              Sensor gw;
                              or
                              Relay gw;
                              To
                              ####Setup()
                              ####Loop()
                              delay(500);
                              gw.powerDown();
                              Replace those with:
                              Z
                              Z
                              Zeph
                              wrote on last edited by Zeph
                              #54
                              @hek @ToSa
                              Could we get a description of how the OTA programming works?
                              (Terminology: the program flash is divided into a bootloader section and an application section; compile sketches go in the application section)
                              One approach is to have a separate flash or eeprom chip which one somehow fills (this could even happen at the application level). When booting, check this flash or eeprom and if valid - load into internal program flash, clear the vallidity of the external flash or eeprom (so you won't loop loading it again) and reboot. When you reboot there will be no valid image to copy from external memory, so you jump to the start of internal application flash. This takes external flash as large or larger than application flash (eg: >= 32 KiB for the 328p)
                              I think you are taking a different route, where the bootloader is somehow given control, after which it receives nRF packets to RAM, periodically writing another page from RAM to the application section of internal flash. When done, reboot.
                              If booting and there is no valid image in external memory and the CRC of the internal application flash section is valid, jump to it as usual.
                              I'm not sure if you can also still use serial programming.
                              This could be all wrong. It implies keeping (at least part of) the nRF library in bootload program flash, to receive packets. I'm putting it out as a hypotheis to help elicit the real description.
                              How big is the OTA bootloader?
                              • DammeD Damme
                                @hek
                                Yes, that's a better place for it.
                                • Z Zeph
                                  @hek @ToSa
                                  @Zeph, @mitekg
                                  Right now the OTA works without any need for external flash. @ToSa will have to answer the details when he's back (like size, building, serial programming).
                                  Yes it uses a VERY stripped down rf24 library.
                                  https://github.com/mysensors/Arduino/blob/development/Bootloader/MyOtaBootloaderRF24.h
                                  Not much of the MySensors library is needed.
                                  https://github.com/mysensors/Arduino/blob/development/Bootloader/MyOtaBootloader.c
                                  • joe.kJ
                                    joe.kJ
                                    joe.k
                                    I am in process of upgrading to 1.4b1 - have most things working. I noticed that my status consistently fails during setup() when presenting sensors AND also never receive a return message from controller after a time request. It's always the same two failures.
                                    Everything works after adding a 100ms delay between calls. Not sure if there's a timing problem somewhere.
                                    Hek - as always thanks for ALL your contributions. :-)
                                    Joe K.
                                    SERIAL CONSOLE OUTPUT:
                                    sensor started, id 4
                                    send: 4-4-0-0 s=255,c=0,t=17,pt=0,l=15,st=ok:1.4b1 (18848a2)
                                    send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                    send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=11,st=ok:LCD Display
                                    send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                                    send: 4-4-0-0 s=0,c=0,t=7,pt=0,l=15,st=ok:1.4b1 (18848a2)
                                    send: 4-4-0-0 s=1,c=0,t=6,pt=0,l=15,st=fail:1.4b1 (18848a2)
                                    send: 4-4-0-0 s=2,c=0,t=8,pt=0,l=15,st=ok:1.4b1 (18848a2)
                                    send: 4-4-0-0 s=255,c=3,t=1,pt=0,l=15,st=fail:1.4b1 (18848a2)
                                    CODE in setup():
                                    gw.sendSketchInfo("LCD Display", "1.0");
                                    gw.present(CHILD_ID_DHT_HUM, S_HUM, true);
                                    delay(100); // needed otherwise status may come back as failed
                                    gw.present(CHILD_ID_DHT_TEMP, S_TEMP, true);
                                    gw.present(CHILD_ID_BMP085_BARO, S_BARO, true);
                                    delay(100); // needed otherwise status may come back as failed & time request doesn't work
                                    // request time
                                    gw.requestTime(receiveTime);
                                      Vera plugin (1.4)
                                      The new API:
                                      * Constructor
                                      boolean process();
                                       * power cycles.
                                      void sleep(int ms);
                                       * getInternalTemp
                                      Include section
                                      #include <EEPROM.h>
                                      #include <RF24.h>
                                      #include <Sensor.h>
                                      #include <Relay.h>
                                      Add
                                      Sensor gw;
                                      or
                                      Relay gw;
                                      To
                                      ####Setup()
                                      ####Loop()
                                      delay(500);
                                      gw.powerDown();
                                      Replace those with:
                                      DammeD
                                      DammeD
                                      Damme
                                      Code Contributor
                                      @hek Does the gateway use any eeprom?
                                      • DammeD Damme
                                        @Damme
                                        Yes, it uses eeprom for storing routing information.
                                          @Damme
                                          DammeD
                                          DammeD
                                          Damme
                                          Code Contributor
                                          @hek ok, how many bytes does it use?
