  3. DHT22 lib working on 1Mhz?
15 Posts 6 Posters 8.6k Views 3 Watching
  • T
    tomkxy
    I tested a DHT22 clone with a ProMini (3.3V) using basically the Sensebender sketch which reduces clock frequency to 1Mhz.
    Without clock frequency reduction I get consistent readings from the DHT22 on 3.3V.
    When going down to 1MHz only the first couple of readings are ok then I get NaNs.
    Right now I am using the library from Mark Ruys.
    What library is known to work 1Mhz?
    Cheers,
    Thomas
    • T
      TimO
      I'm working with the library that is provided with the mysensors download.
      Works with an internal clock set to 1 MHz for me.
      • T
        tomkxy
        Actually, I am using the same lib.
        I found a thread in the Arduino forum which explains that it can not work in principle: http://forum.arduino.cc/index.php?topic=291695.0
        Hmmm, quite interesting that it seems to work at least in certain cases.
        • S
          Stric
          how about 2 or 4MHz if 8 is too high?
          • T
            tomkxy
            Will try and report back.
            • T
              tomkxy
              I tried it. Even on 4Mhz only the first 4 transmits show readings. Then it only returns errors.
              So it only work on 8Mhz for me.
              • T
                tomkxy
                So after 2 weeks fiddling around with the different libraries at different clock frequencies, I have some conclusions I would like to share with you.
                I tested with a ProMini and two DHT22 sensors, one from Adafruits and one from China.
                As I already reported, I had problems with clock frequencies below 8MHz with all different libraries. After switching to 8MHz, I realized another problem. Temperature readings did not change. They stayed the same value, only when I reset the ProMini I had a correct reading.
                I had this behaviour with the Adafruit and the library included in the MySensors project.
                Since yesterday evening I am testing the library from Rob Tillaart (http://arduino.cc/playground/Main/DHTLib) which is working correctly giving me correct readings.
                I am presuming that this is related to sleeping the ProMini and may be the low power mode the DHT22 is going into, I don't know...(at least in Rob's lib there is a wakeup delay which seems to address that point)
                Anyway, it seems I have at least now a working solution. I will re-try to lower the clock frequency with that library.
                Apart from that I also realized that the DHT library included in MySensor will perform a sensor read for a call to readTemperature and readHumidity which means that you would need to put a delay of 2s between a readTemperature and readHumidity. Since the sensor delivers the values in a "single" read this is rather unfortunate for battery powered sensor.
                  If it verifies ok you could perhaps create a pull request with the new library and update the DHT example sketch accordingly?
                  • T
                    tomkxy
                    Ok. I'll do that. Might however take a couple of days.
                    • T
                      tomkxy
                      I retried again with Rob Tillaart's DHT22 library whether I can reduce clock frequency.
                      The results:
                      • 1 MHz -> wrong readings, like -100 C
                      • 2 MHz -> "
                      • 4 MHz -> from time to time wrong reading
                      Overall, I would state that you need to run the DHT22 with the libraries I tested on 8 Mhz.
                        Ok, thanks for the update.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @tomkxy
                          Are you compiling for the different clock frequencies in arduino? Or is it compiled for 8/16Mhz target, and then you switch frequency in the sketch?
                          • T
                            tomkxy
                            I used the Sensebender sketch which switches in the sketch.
                            • T
                              tlustoch
                              Sorry for a stupid question, but how do you run at 1 Mhz?
                              See http://www.mysensors.org/hardware/micro#comment-2196823229
                              Are you able to switch to 1 Mhz at runtime?
                              • T
                                tomkxy
                                Have a look at the sensebender sketch http://www.mysensors.org/hardware/micro#example-sketch
                                  if ((measureCount == 5) && highfreq)
                                    clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
                                    highfreq = false;
                                The clock frequency is scaled down by software.
