  3. multiple DS18D20 does not report temperature
27 Posts 4 Posters 13.5k Views 2 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    Are you powering your Dallas sensor using the 'one-wire' method? Is your arduino 5V or 3.3V?
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    • Tomasz PazioT
      Tomasz PazioT
      Tomasz Pazio
      wrote on last edited by Tomasz Pazio
      #22
      exactly like o the example so power from arduino 5V (not parasite)
      • rvendrameR
        rvendrameR
        rvendrame
        Can you post the serial monitor logs, from both gateway and node?
        Alexa / Google Home
        • Tomasz PazioT
          Tomasz PazioT
          Tomasz Pazio
          @rvendrame, why You need log from gateway? When no values are sent from node than nothing on Vera. When use some dummy values which are visible in node log - than those values are in Vera.
            @hek said:
            Guess I have to hook up a Dallas sensor myself to check (tomorrow or so..)
            Ok, tried latest from 1.5 branch and it works fine here with 2 hooked up DS18D20.
            sensor started, id=200, parent=0, distance=1
            send: 200-200-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
            send: 200-200-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
            send: 200-200-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
            send: 200-200-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
            send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:27.9
            send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:28.0
            send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:31.5
            send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:32.0
            • Tomasz PazioT
              Tomasz PazioT
              Tomasz Pazio
              removed all Arduino related stuff from PC
              Installed new IDE and libs from https://github.com/mysensors/Arduino/archive/master.zip
              now I have progress, there are no readings no mater on which sketch hahaha.
              • clio75C
                clio75C
                clio75
                I have the same problem. No temperature is transported to GW.
                This log is from Sensor:
                req id
                send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
                sensor started, id=255, parent=0, distance=1
                req id
                req id
                req id
                I have added some exstra lines in serial printout so I know that ds1820 is found and read.
                req id
                req id
                req id
                **Sensors found
                **req id
                temp :
                23.80
                But This value is not transported to GW.
                Any idee ?
                Thanx
