  3. multiple DS18D20 does not report temperature
27 Posts 4 Posters 13.6k Views 2 Watching
    -127 means something is wrong when reading your dallas sensors. It is a an error code. So you actually only have an issue with your temp sensors.
    • Tomasz PazioT
      Tomasz PazioT
      Tomasz Pazio
      when I use Example for Dallas multiple sensors it works fine.
      when I use example for one-wire temperature sensor ds18.... it works fine as well
      so i can reed but can not use Mysensors sketch :(
        Very strange. Are you using the same OneWire library in both cases?
        • Tomasz PazioT
          Tomasz PazioT
          Tomasz Pazio
          yes the same.
          • Tomasz PazioT
            Tomasz PazioT
            Tomasz Pazio
            any idea?
              No, must be hundreds of users running Dallas sensors here. Trying to figure out if anything has changed in the library/dependencies but I don't see anything except the thing I mentioned earlier here.
              And you can get the sensor running without MySensors library loaded...
              Guess I have to hook up a Dallas sensor myself to check (tomorrow or so..)
              • rvendrameR
                rvendrameR
                rvendrame
                Are you powering your Dallas sensor using the 'one-wire' method? Is your arduino 5V or 3.3V?
                ESP8266 GW + mySensors 2.3.2
                Alexa / Google Home
                • Tomasz PazioT
                  Tomasz PazioT
                  Tomasz Pazio
                  wrote on last edited by Tomasz Pazio
                  #22
                  exactly like o the example so power from arduino 5V (not parasite)
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    Can you post the serial monitor logs, from both gateway and node?
                    Alexa / Google Home
                    • Tomasz PazioT
                      Tomasz PazioT
                      Tomasz Pazio
                      @rvendrame, why You need log from gateway? When no values are sent from node than nothing on Vera. When use some dummy values which are visible in node log - than those values are in Vera.
                        Ok, tried latest from 1.5 branch and it works fine here with 2 hooked up DS18D20.
                        sensor started, id=200, parent=0, distance=1
                        send: 200-200-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
                        send: 200-200-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                        send: 200-200-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                        send: 200-200-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                        send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:27.9
                        send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:28.0
                        send: 200-200-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:31.5
                        send: 200-200-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:32.0
                        • Tomasz PazioT
                          Tomasz PazioT
                          Tomasz Pazio
                          removed all Arduino related stuff from PC
                          Installed new IDE and libs from https://github.com/mysensors/Arduino/archive/master.zip
                          now I have progress, there are no readings no mater on which sketch hahaha.
                          • clio75C
                            clio75C
                            clio75
                            I have the same problem. No temperature is transported to GW.
                            This log is from Sensor:
                            req id
                            sensor started, id=255, parent=0, distance=1
                            req id
                            req id
                            req id
                            I have added some exstra lines in serial printout so I know that ds1820 is found and read.
                            req id
                            req id
                            req id
                            **Sensors found
                            **req id
                            temp :
                            23.80
                            But This value is not transported to GW.
                            Any idee ?
                            Thanx
