  3. Heartbeat signal
Heartbeat signal
11 Posts 6 Posters 8.3k Views 3 Watching
  • SparkmanS
    SparkmanS
    Sparkman
    Hi all,
    I have a few sensors such as my lightning sensor that may not transmit actual sensor data for a long time. In case the sensor were to lock up, or have some other issue, I'd like my HA system to notify me. For the lightning sensor, I've added a heartbeat signal that sends a V_TRIPPED value once an hour and it alternates sending a 1 and a 0 and I've programmed my HA system to alert me if that value has not changed for a few hours. I'm just wondering if there's a more elegant way or what others have done. Ideas?
    Al
    • tbowmoT
      tbowmoT
      tbowmo
      I'm just sending the last state of the port and light, in my garage port opener, once every 60 minutes. In domoticz I can see when a sensor is seen the last time.. And this way I can check that it's alive.
      I admit, I have to look at it manually, no automation in warnings etc.
      SparkmanS 1 Reply Last reply
      • TD22057T
        TD22057T
        TD22057
        I think the heartbeat is a reasonable way to do it. I'm designing my system to use an MQTT broker and I'm going to write a small client that listens to all the sensor messages as they come in. If no message is seen from a sensor in some elapsed time, the client will send out a "sensor down" message which can then be acted on.
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @Sparkman
          How about a Sensor Sensor?
          From the Sensor Sensor send a message to each node that you need to check communication and wait for a bounceback.
          You could use a motion sensor to indicate probem, and show the trouble node in a V_VAR ...
          something to try
          • sundberg84S
            On my batterysensors i send batterlevel every 60min (4th sleep cycle) as a heartbeat.
            Probably a stupid question, but how do I code it in a node without sleep? It doesnt have a clock :)
            @tbowmo You probably knows, but using lua script you can let domoticz send you a notification (i really recommend notifymyandroid).
            Something like: (untested).
            -- script_time_garageport.lua
            -- Sends a warning if the garagedoor has been unseen more than 60 minutes.
            t1 = os.time()
            s = otherdevices_lastupdate['Garageport']
            -- returns a date time like 2013-07-11 17:23:12
            year = string.sub(s, 1, 4)
            month = string.sub(s, 6, 7)
            day = string.sub(s, 9, 10)
            hour = string.sub(s, 12, 13)
            minutes = string.sub(s, 15, 16)
            seconds = string.sub(s, 18, 19)
            commandArray = {}
            t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
            difference = (os.difftime (t1, t2))
            if (difference > 3600 and difference < 3900) then
               commandArray['SendNotification']='Garage door alert#The garage door has been stolen??'
            end
            return commandArray
            • tbowmoT
              tbowmoT
              tbowmo
              @sundberg84
              Currently domoticz sends a private tweet to me, if it has any notifications, I chose twitter, as I don't have to pay for any license keys to use that.
              I just haven't come around to enable notifications, if sensors doesn't check in at a regular interval.
              If you want to ping your controller in a node that never sleeps, you could always use millis():
              unsigned long lastHeartbeat = 0;
              #define HEARTBEAT_INTERVAL 3600000
                if (millis() - lastHeartbeat > HEARTBEAT_INTERVAL) {
                    ... PING ....
                    lastHeartbeat = millis();
              This will send a ping every 3600 seconds (once a hour). The first heartbeat will be 1 hour after startup.
              • tbowmoT tbowmo
                SparkmanS
                SparkmanS
                Sparkman
                wrote on last edited by Sparkman
                @tbowmo @TD22057 @BulldogLowell @sundberg84
                Thanks for the replies everyone. The HS3 MySensors plugin will only update the "last change time/date" if the value sent by the sensor actually changes, so I need to make sure what I send is different than before which is why I alternate 0's and 1's. I would like a common solution for both mains and battery powered devices, and therefore polling sensors won't work for sleeping battery powered sensors. Using the V_TRIPPED sensor type is a bit of a kludge, but seems to be working ok. Maybe a V_HEARTBEAT sensor type should be added to the protocol. @hek, any thoughts?
                Cheers
                Al
                  Hmm. if this is something the community would find useful we could add it as an INTERNAL variable type (which reports it on the node-device). And API something like:
                  gw.sendHeartbeat(<optional destination node (defaults to gateway/controlle)r>)
                  Sends an incremental integer payload.
                    SparkmanS
                    SparkmanS
                    Sparkman
                    @hek That sounds great to me!
                    Al
                      I skipped the destination argument...
                      https://github.com/mysensors/Arduino/commit/2343d8ae8fb72bdcab467b158eb77c09af6fda5d
                        SparkmanS
                        SparkmanS
                        Sparkman
                        @hek Thanks!
