  3. No protocol version during PRESENTATION
3 Posts 2 Posters 1.4k Views 1 Watching
  • T Offline
    T Offline
    Tang
    Hi
    I just upgraded all my sensors/gateway to the new version and I don't see protocol version of my sensors during PRESENTATION message.
    It worked before (1.4.1)
    I compiled my sketches using master.zip file in download section
    Here is full log of my controller (agocontrol) during temperature sensor startup:
     => 22:21:11 2015/08/05 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 110-110-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
     => 22:21:11 2015/08/05 RECEIVING: 110/255;PRESENTATION;0;S_ARDUINO_NODE;1.5
     => 22:21:11 2015/08/05 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 110-110-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
     => 22:21:11 2015/08/05 RECEIVING: 110/255;INTERNAL;0;I_CONFIG;0
     => 22:21:11 2015/08/05 SENDING: 110;255;3;0;6;M
     => 22:21:11 2015/08/05 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;send: 0-0-110-110 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
     => 22:21:13 2015/08/05 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 110-110-0 s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature S
     => 22:21:13 2015/08/05 RECEIVING: 110/255;INTERNAL;0;I_SKETCH_NAME;Temperature Sensor
     => 22:21:13 2015/08/05 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 110-110-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
     => 22:21:13 2015/08/05 RECEIVING: 110/255;INTERNAL;0;I_SKETCH_VERSION;1.0
     => 22:21:13 2015/08/05 RECEIVING: 0/0;INTERNAL;0;I_LOG_MESSAGE;read: 110-110-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
     => 22:21:13 2015/08/05 RECEIVING: 110/0;PRESENTATION;0;S_TEMP;
    As you can see S_ARDUINO_NODE reports (line2) its version 1.5 but the S_TEMP presentation (last line) reports nothing in payload.
    The only sensor that reports correctly its version is the repeater node.
    Here is my sketch:
    #include <OneWire.h>
    #define TIMEOUT 600000 //10 minutes
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    unsigned long SLEEP_TIME = 150000; // Sleep time between reads (in milliseconds)
    OneWire oneWire(ONE_WIRE_BUS);
    MyMessage msg(0,V_TEMP);
      // Startup OneWire
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor", "1.0");
      gw.present(0, S_TEMP);
      gw.process();
      float temperature = static_cast<float>(static_cast<int>(sensors.getTempCByIndex(0)) * 10.) / 10.;
      gw.send(msg.set(temperature,1));
      //sleep
      gw.sleep(SLEEP_TIME);
    Is this an issue or I missed something?
    Thank you for your help.
    Tang
    • hekH Offline
      hekH Offline
      Version is only sent to the S_ARDUINO_NODE now.
      The present() method now supports a 3rd argument, a device title which will show instead of version if controller supports it.
      E.g. gw.present(0, S_TEMP, "Temp Living Room");
      • T Offline
        T Offline
        Tang
        Ok thanks for the precision ;-)
