  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 398.1k Views 39 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    wrote on last edited by Mark Swift
    #281
    @Yveaux I doubt it will, seems I'm destined to build a serial gateway, crap, I've invested so much time in this and tried everything!
    • Mark SwiftM
      Mark SwiftM
      Mark Swift
      #282
      @Yveaux How about this, for a laugh I just tried rolling the ESP8266 gateway back to v1.5 (master).
      Guess what? It works every time with no fails (communicating with my 2.0.0 beta node). So the issue lies with the latest development version somewhere, any ideas?
      Insane, I just took the gateway down the other end of the house and not one fail, wow! So okay, what was changed in version 2.0.0?
      UPDATE: After more investigation, the reason it was working is because v1.5 only has a straight forward gateway version, and until now I've been using the MQTT client. It seems the gateway versions work fine, but the MQTT client version create the fails!
      UPDATE 2: Okay, I can reproduce the fails with the gateway too, let me try and explain. When the gateway is not connected to anything (for example Domoticz) I get OK all of the time, no fails whatsoever. If I connect to Domoticz, I start to get fails against certain child sensors (it's always the same!). I presume it's sketch related, or even the amount of node updates I'm sending? As I believe the fails are the same I'm seeing with the MQTT client.
      UPDATE 3: Nearly 3 weeks in and I've just figured out what has been causing me all this pain. I've always commented out the default 9600 serial baud define on the ESP8266 sketches. It seems this combined with the 200ms TCP delay has been causing me my issues when connecting to my Windows 7 machine. S$%&*!
      YveauxY 1 Reply Last reply
      • Mark SwiftM Mark Swift
        YveauxY
        YveauxY
        @Mark-Swift Well, look on it from the bright side: your marriage is saved now :bowtie:
        There have been more reports from issues with connections to external servers (e.g. MQTT, Domotiocz) that take too long.
        Maybe we should pull @hek in as he wrote the MQTT client for ESP.
          What adjustments do you propose to the MQTT sketch/driver?
            YveauxY
            YveauxY
            #285
            @hek I'm not familiar with the exact implementation at the moment. Just hoped you would have a hunch where these issues might arise from or how we can prevent them...
              Nope, I don't get why baud rate would affect radio/tcp traffic. Maybe @Mark-Swift could shed some light on it.
              • R
                R
                robosensor
                ESP8266 gateway is quite unusable in setups where TCP ACKs can be delayed. This is because thread is blocked until TCP ACK received in ESP wifi code. So all wireless messages will be rejected if NRF24 receives more than 3 messages during this 200ms delay: http://forum.mysensors.org/topic/1870/esp8266-wifi-gateway-port-for-mysensors/235
                  Hmm.. blocking code.. crap.
                  • R
                    R
                    robosensor
                    The problem is slightly wider than it seems. Wireless messages should be fetched from internal NRF24 FIFO and stored into memory as soon as possible (using interrupts?). But lack of RAM makes the problem difficult to be solved.
                    The same thing happens not only with ESP8266 gateway and TCP ACKs, but also with all blocking calls during sensor reading (for example for old blocking call to read DS18B20 data with 750ms delay), with improper use of delay() instead of gw.wait() and so on.
                    • R robosensor
                      YveauxY
                      YveauxY
                      #290
                      @robosensor said:
                      lack of RAM
                      Not really an issue on ESP I would say.
                      @hek IMHO it really is time to investigate the impact on the library to support message queueing (fetched & sent from interrupt).
                      Starting with @tekka rewrite of the nRF driver in 2.0 beta, as it supports SPI transactions.
                      Probably we can add support incrementally to lower the impact on the library.
                        Yes, at least for the gateway and repeaters this would be preferred. How's your play-time-bandwidth?
                          YveauxY
                          YveauxY
                          I already feared you we going to ask this ;-)
                          Quite limited at the moment, but such things should grow in my mind first. Let's start with that hehe..
                            Mo ha haha :smiling_imp:
                            • scalzS
                              scalzS
                              wrote on last edited by scalz
                              #294
                              @hek @Yveaux : I don't know if this could help. but some times ago I found a lib when you were talking about this issue but I have never had enough time to test it. It is a "non blocking" ack with some buffering version for wifiserver. I think that does not solve completely the buffering issue :confused: But maybe a small step..
                              I don't remember where I read this but igr was saying it would be better to have a lib for this than modifiying the wifiserver lib for compatibility with other arduino wifi libs. So maybe this guy did it.
                              http://www.forward.com.au/pfod/pfodParserLibraries/index.html
                              In the middle :)
                              I also read that for esp, bigger tcp packet were processed faster than small :open_mouth:
                              very tricky issue to debug when so much layers..
                              • R
                                R
                                robosensor
                                Also it is possible to partially solve this issue by fetching all available messages from NRF24 FIFO and concatenating them into one TCP packet for ESP. It is possible that this will be useful for other gateways too.
                                But no chances that MYS protocol will be changed? I'm talking about reliable delivery and message ids. That topic is very close to this.
                                • R robosensor
                                  YveauxY
                                  YveauxY
                                  @robosensor I think message buffering could be the first step to (more) reliable delivery.
                                  • scalzS
                                    scalzS
                                    this was the thread I read. pfod lib creator and esplibs team were talking about this.
                                    https://github.com/esp8266/Arduino/issues/1430
                                    And it seems there is another lib too for this:
                                    https://github.com/me-no-dev/ESPAsyncTCP
                                    • scalzS scalz
                                      YveauxY
                                      YveauxY
                                      @scalz Thanks for the links man!
                                      Now we're at it: anyone knows if a blocked socket connection can be interrupted at all by an external pin interrupt on ESP(Arduino) ? Otherwise buffering on interrupts will make no sense...
                                      • Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        #299
                                        Thanks for looking into this guys... I've been doing some tests and basically the ESP gateway is not an option for me right now due to too many radio failures.
                                        Using the normal serial gateway I tested one of my nodes that sends about 15 values during each loop; it was perfect every time!
                                        The same test with the ESP shows failures every few messages or so, introducing a large radio delay between each send fixes it, but the issue can still occur if other nodes call in at the same time.
                                        Another interesting thing, when I don't specify a gateway, or static IP I get no failures, when I do, I get failures, what!?
                                          YveauxY
                                          YveauxY
                                          @Mark-Swift Don't know if you already ditched the ESP gateway completely, but you could give my latest experiment a try: https://github.com/Yveaux/Arduino/tree/development
                                          It adds a reception queue to the gateway which will immediately retrieve a message from the radio when it comes in. This process should even continue when the ESP is blocked on some TCP transfer.
                                          Only thing you have to do is connect the IRQ line from the nRF radio to the ESP (e.g. to pin 1), and define the IRQ pin at the top of your gateway sketch:
                                          #define MY_RF24_IRQ_PIN  (1)
                                          I tested this on a UNO, and can easily sleep the gateway for 1 second or more when messages come in at 0.1sec interval -- none gets lost. The buffer is set to 20 by default, but you can increase it when the amount of RAM allows it:
                                          #define MY_RF24_MESSAGE_BUFFER_SIZE  (50)
                                          I don't have a NodeMCU setup ready so I cannot test it on ESP myself...
