  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 398.0k Views 39 Watching
  • P
    P
    Pseudomizer
    Hello guys,
    I am having issues with this installation. I got everything up and running but it simply doesn't connect to my WiFi Netgear router at home.
    I just enabled my hotspot on my cell phone and the gateway did connect successfully and started the gateway master with IP, etc assigned.
    When I try to connect to my home WiFi it just keeps on printing dot dot dot in the serial console.
    My Netgear has two networks with 2.4Ghz and 5Ghz. I tried both and none of them worked. They are configured with WPA2-PSK [AES] encryption for the passphrase and the passphrase has one special character included. The SSID is 5 characters long and the passphrase is 22 characters long which shouldn't be an issue.
    I don't get any error messages in the serial console and my router doesn't show anything in the logs either like the ESP gateway doesn't even try to connect. I don't know how to troubleshoot this from here.
    Any help would be appreciated.
      I also have both 5/2.4Ghz on my router.
      When ESP connects is seems to prefer 2,4 GHz / n / WPA2 if that helps.
      • P
        P
        Pseudomizer
        This is what I have. 2,4 GHz / n / WPA2 (no TKIP but AES instead so I can go beyond 54Mbit) and it doesn't connect. Just dots coming up.
        YveauxY 1 Reply Last reply
        • P Pseudomizer
          YveauxY
          YveauxY
          @Pseudomizer Esp8266 is 2.4ghz only.
          You could try adding the following line just after hw_init() in the sketch:
          Serial.setDebugOutput(true);
          It will dump a lot of ESP WiFi related data, please post the output here. Maybe some will give a hint of what goes wrong.
          • P
            P
            Pseudomizer
            Thanks a lot for this. This helped me troubleshoot the problem and I am surprised why it didn't connect. It couldn't find my SSID name because in the router it is all UPPER case but when I write it on any other machine Windows, Linux, etc to connect to, I always write it lower case with the exception of the first character.
            In this case I modified the sketch to have the SSID name all in UPPER case and voila it connected.
            Thanks again for the help here. Much appreciated.
            • P
              P
              Pseudomizer
              I was very happy when it connected but now it is resetting itself constantly with this error message:
              wdt reset
              load 0x4010f000, len 1264, room 16
              tail 0
              chksum 0x42
              csum 0x42
              ~ld
              Any ideas why?
              • P
                P
                Pseudomizer
                I missed one line of error code above:
                ets Jan 8 2013,rst cause:4, boot mode:(3,6)
                • P
                  P
                  Pseudomizer
                  I tried my Home Wifi and my Cell Hotspot. The crashes occur on both wifi networks. :-(
                  • R
                    R
                    ridge
                    wrote on last edited by ridge
                    #109
                    @Pseudomizer , Is the esp8266 on a breadboard or is it part of a commercial product like HUZZAH or nodemcu ? I ask because the esp devices can reset themselves from a brownout condition during the WiFi transmit if the power supply circuit is not up to handling the momentary 'high current draw' requirements of the radio. From reading www.esp8266.com, breadboard circuits have caused many hours of troubleshooting enjoyment with the esp8266 parts.
                    I replace the battery packs on these with 2 Amp cell phone charger power supplies. I have 8 under power 24/7 for months with no problems. They are available from multiple vendors.
                    http://www.aliexpress.com/item/Free-shipping-ESP8266-ESP-12-serial-WIFI-Industrial-stable-version-A-full-test-board-Full-IO/32260095422.html?spm=2114.01020208.3.49.0YGvDs&ws_ab_test=201556_7,201527_4_3_2_1_4_71_72_73_74_75,0_0
                    • P
                      P
                      Pseudomizer
                      I followed the instructions exactly as shown here and I purchased that exact equipment.
                      http://www.mysensors.org/build/esp8266_gateway
                      I even powered the NRF24L01+ from a different power source just to make sure that power fluctuation is not the issue but it didn't make any difference.
                      I even tried transfer rates 115k, 57k and 9600 Baud but none of that made any difference either.
                      I also downloaded the flash eeprom ino program to clear all the data but again, no difference.
                      • P
                        P
                        Pseudomizer
                        I even reflashed the ESP8266 with those instructions and then loaded the mysensors ino but still the same outcome. :-(
                        http://benlo.com/esp8266/esp8266QuickStart.html
                        • P Pseudomizer
                          YveauxY
                          YveauxY
                          @Pseudomizer did you make any changes to the gateway sketch out the MySensors library/config?
                          Could you post the output of the gateway just before the crash occurs (it might give an indication of where this crash occurs)
                          • P
                            P
                            Pseudomizer
                            The only changes to the sketch are the SSID, the pass and the debug line
                            as instructed. No other changes were made.
                            Here the the debug output....you will see multiple resets in a row based on the internal watchdog timer.
                            ESP8266 MySensors Gateway
                            Connecting to MYWIFI
                            scandone
                            f 0, scandone
                            .add 0
                            aid 1
                            pm open phy_2,type:2 0 0
                            cnt
                            connected with MYWIFI, channel 6
                            dhcp client start...
                            ......ip:192.168.1.222,mask:255.255.255.0,gw:192.168.1.1
                            .Connected!
                            IP: 192.168.1.222
                            wdt reset
                            tail 0
                            chksum 0x42
                            csum 0x42
                            ~ld
                            scandone
                            f 0, scandone
                            .add 0
                            aid 1
                            cnt
                            .......ip:192.168.1.222,mask:255.255.255.0,gw:192.168.1.1
                            .Connected!
                            IP: 192.168.1.222
                            wdt reset
                            tail 0
                            chksum 0x42
                            csum 0x42
                            ~ld
                            scandone
                            f 0, scandone
                            .add 0
                            aid 1
                            cnt
                            .Connected!
                            IP: 192.168.1.222
                              Triple-check your radio wiring.
                                YveauxY
                                YveauxY
                                Or try with a different radio. The crash seems to happen in the radio init part.
                                • P
                                  P
                                  Pseudomizer
                                  I just replaced the NRF with a new NRF and then again as I have 4 total. With every single one the same error.
                                  The wiring matches exactly the picture from mysensors.
                                  This is driving me crazy...
                                    miguelingles
                                    Hi, I tried the bridge with a rfm69hw module. It starts all well but does not receive any information. Neither shows startup information module .
                                    Where to put the DIO0 . I tried on several pins ( changing IRQ number) but no thoughts about doing anything.
                                    • M miguelingles
                                      YveauxY
                                      YveauxY
                                      @miguelingles I didn't test with a rfm69hw module and I'm not aware of anybody else testing with this setup.
                                      Probably you have to test step by step what work and what not.
                                      Start with the radio initialization to see if the communication is ok, and go on from there.
                                      • P Pseudomizer
                                        YveauxY
                                        YveauxY
                                        @Pseudomizer past few days @hek and I have been working on better diagnosis for the ESP8266 regarding radio communication failures.
                                        Please try if the version of MySensors development helps in diagnosing your problems.
                                        Make sure to uncomment the line
                                        //#define MY_DEBUG_VERBOSE
                                        in MyConfig.h and make the same changes to ssid & password as you did before.
                                        This version will dump diagnostics of NRF communications and a full register dump when starting up.
                                        Good luck!
                                        • P
                                          P
                                          Pseudomizer
                                          Thanks a lot. This version provides much more details but at this stage of my learning progress I am not able to understand all those registers where I have to rely on your help guys. I assume that my password is not being exposed here.
                                          Connecting to ZEUS
                                          scandone
                                          f 0, scandone
                                          .add 0
                                          aid 1
                                          cnt
                                          connected with ZEUS, channel 6
                                          .Connected!
                                          IP: 192.168.1.222
                                          write_register(0x04,0x5F)
                                          write_register(0x06,0x23)
                                          write_register(0x06,0x03)
                                          write_register(0x00,0x0E)
                                          write_register(0x07,0x70)
                                          write_register(0x05,0x4C)
                                          STATUS 0x0E RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                                          RX_ADDR_P0-1 0x0E0E0E0E0E 0707070707
                                          RX_ADDR_P2-5 0xFF C4 C5 C6
                                          TX_ADDR 0x0E0E0E0E0E
                                          RX_PW_P0-6 0x00 00 20 00 00 00
                                          EN_AA 0x3B
                                          EN_RXADDR 0x07
                                          RF_CH 0x4C
                                          RF_SETUP 0x03
                                          CONFIG 0x0E
                                          DYNPD/FEATURE 0x3F 06
                                          Data Rate 1MBPS
                                          Model nRF24L01+
                                          CRC Length 16 bits
                                          PA Power PA_LOW
                                          write_register(0x01,0x3F)
                                          write_register(0x01,0x3B)
                                          write_register(0x1D,0x06)
                                          FEATURE=0x06
                                          write_register(0x1C,0x3F)
                                          ets Jan 8 2013,rst cause:4, boot mode:(3,7)
                                          wdt reset
                                          tail 0
                                          chksum 0x42
                                          csum 0x42
                                          ~ld
                                          Connecting to ZEUS
                                          scandone
                                          f 0, scandone
                                          .add 0
                                          aid 1
                                          cnt
                                          .Connected!
                                          IP: 192.168.1.222
                                          EN_AA 0x3B
                                          EN_RXADDR 0x07
                                          RF_CH 0x4C
                                          RF_SETUP 0x03
                                          CONFIG 0x0E
                                          Data Rate 1MBPS
                                          Model nRF24L01+
                                          CRC Length 16 bits
                                          PA Power PA_LOW
                                          FEATURE=0x06
                                          wdt reset
                                          tail 0
                                          chksum 0x42
                                          csum 0x42
                                          ~ld
                                          YveauxY 2 Replies Last reply
