  3. My own board (50mm x 30mm)
133 Posts 22 Posters 119.5k Views 21 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    @ahmedadelhosni It probably depends on the other boards put on the same panel. A boardhouse makes PCB's in large panels. They fit as much designs as they can on these boards. If you need exactly 10, they will give priority to your design (and it costs more); if not needed, they can add your design to a board and if that means 9 PCB's only, that would be acceptable. For my blue board design I received 11 PCB's, for the red board I received 12, but I would have been OK with 9 or 10 also (given the low price and good quality).
    For prototyping I think this is a very good deal. The only minor point: transport time is VERY long, in my case it is 4 weeks between notification that the PCB's are shipped to me and actual delivery to my mailbox. Production is about 1 week. So if you have time (count 5-6 weeks) to get your boards, then DirtyPCB is very good value. If you need prototypes faster (at a little higher expense) I suggest you use OSHPark. You will only get 3 PCB's, but they will be delivered faster (about 3 weeks in my case).
    • G
      G
      gloob
      @GertSanders
      I did now receive the PCBs and ordered the other components via Reichelt.de
      I hope to start soldering next week.
      Do you have any tips to flash the Atmega?
      Did you use the normal Arduino IDE?
      Do I have to check something special?
      • BartEB
        BartEB
        BartE
        wrote on last edited by BartE
        #63
        @GertSanders just to let you known i did plat around a little bit with your PCB design and i found a way to use is with-out the crystal by using the ATmega's internal 8 MHz clock
        See the results here: http://forum.mysensors.org/topic/2484/running-atmega328p-on-internal-8mhz-clock
        The free PCB space (where the clock Cap's and crystal was designed) i now use for the big transmitter capacitor to lay down.
        • GertSandersG
          GertSandersG
          GertSanders
          @BartE Excellent, of course you can use this without the crystal, depends on your fuse settings :-)
          • GertSandersG
            GertSandersG
            GertSanders
            @gloob I made my own version of the Optiboot bootloader to flash led on pin 8. I will add the hex file to the site later. To flash the atmega328 I made an extension to the bootloader programmer sketch by Gammon, I will post that as well. It is a translation of my version into his sketch format.
            • G
              G
              gloob
              I have now soldered everything on the board and want to burn the bootloader now.
              I have included the bootloader HEX file in the bootloaders folder and modified the boards.txt file.
              How do I now burn the bootloader with the Arduino IDE?
              I have a FDTI programmer but I'm not sure if this is the correct device to burn the bootloader or if I need something different.
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Is it possible to order the AC boards from your last picture?
                • Carl HC
                  Carl HC
                  Carl H
                  I order from OSHpark the v2 of your own board and I have a question, if I run it with 2AA battery for example, I put jumpers (marked red on the picture) and it is working.
                  upload-b99a206b-5adb-421c-8865-2e3271212d9e
                  But if I want to try with 5v input, like from usb charger, do I need to have a 3.3v regulator for the NRF24+ ? And if yes, do I need other pcb to complete this?
                  Other question, what is the use of the jumper J1? I'm not sure...
                  Thanks again !!
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    wrote on last edited by GertSanders
                    #69
                    hi @Carl-H By adding the two jumpers as you do, indeed it wil work with a set of batteries.
                    J1 connects the VCC circuit with the 3V3 circuit.
                    3V3 circuit connects to the NRF24. Vcc circuit connects to the power (Vcc and AVcc) of the atmega328.
                    The jumper you put on the left arrow, is to connect the VRaw input with 3V3 (above).
                    So by adding the two jumpers you get battery voltage on VCC and on 3V3 circuit, through the JST connector (which is connected to VRaw).
                    If you want to use 5V, you will need to add a 3V3 regulator. This can be through a companion board like I published on OSHPark (https://oshpark.com/shared_projects/IOHUNYT2), or you could make your own board. You could take the VRaw input and bring to down to 3V3 and connect to the 3V3 circuit. If you put a jumper between Vraw pin and VCC pin instead of between VRaw and 3V3, then VCC will have the 5V.
                    If you use the companion board, you should not bridge the Vcc and 3V3 circuits or the Vcc and 3V3 circuits.
                    As you guessed, to get 3V3 from a 5V input you need more then just this board.
                    There are also two pins for a battery holder. One is visible above C9, this is the + side and connected to VBat. The other is right of the LED and R2 and is negative side and connected to GND circuit.
                    More info on this board I will keep adding here: http://forum.mysensors.org/topic/595/pcb-boards-for-mysensors/30
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @Cliff-Karlsson The blue board (AC capable) can be ordered from Dirtypcb's:
                      http://dirtypcbs.com/view.php?share=12146&accesskey=c3a217d7f31434a5565ecf9bdf3f7dc6
                      There is no BOM for the moment. I built several variants, and they all work. But I do not consider this my final version of this type of board. The above link points to my first spin of the PCB (first version). There is no v2 right now, but I have some ideas to improve it, and I'm open to suggestions.
                      I will add the EAGLE files also to the message thread where we collect all the hardware.
                      Fo the moment most info (images) is only here:
                      http://forum.mysensors.org/topic/2374/50mm-x-50mm-board-with-different-powering-options/10
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        @GertSanders
                        Just got the board v2 from OSHpark and I would to ask a few questions:
                        1. Can I replace R2 with 220Ohm one?
                        2. I have 16Mhz crystal - hopefully this is not a problem?
                          I fired the board, but cannot connect it to the Arduino IDE 1.6.5 via the FTDI USB-TTL. I checked the voltage and it is 3V from the battery pack with two jumpers J1 and VBAT to VCC in place. I have used a standard ATMEGA328P_PDIP with an Arduino Uno bootloader I got from the Ebay. Do you think this may be an issue?
                        Regards
                        Alex
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          @alexsh1 I think running at 16Mhz in 3V is asking too much from the processor. The boot loader for Arduino Uno assumes 16Mhz, and communication with the processor at a much higher speed then I use on my board. That is why I compiled my own boot loader (for 8MHz and serial communications at 36K baud instead of 115K baud).
                          Also, the boot loader for Arduino Uno assumes there is a LED on pin 13. In my board I moved this to pin 8. This should not block the processor. Having it at 16Mhz while powering it with 3V is more the issue here I think.
                          If you have an Arduino Uno available, you can burn your own boatloader. The HEX file is added in the topic:
                          http://forum.mysensors.org/topic/595/pcb-boards-for-mysensors/31
                          The how to here is:
                          http://www.gammon.com.au/bootloader
                          Using 220 Ohm for R2 should be OK, the led will get a bit more current, but should handle it fine. The port can give 20mA. With 220 Ohm you pull 13mA, so within limits.
                          alexsh1A 1 Reply Last reply
                          • GertSandersG
                            GertSandersG
                            GertSanders
                            #73
                            @alexsh1
                            From another board:
                            The most common non-5v voltage is of course 3v3 and as you can see at 3v3 the chip is only spec'd at just over 13MHz, people do often run them at 16MHz but that is well out of spec. That's ok if you are playing around, making a widget for yourself etc, but it's not ok for a commercial product, especially if it will be subject to large temperature variations.
                            Source: http://forum.arduino.cc/index.php?topic=213105.0
                            At 3V (or thereabouts when using g a set of batteries) you are well under specification. 12MHz would be OK, 16MHz is a bit much.
                            • GertSandersG GertSanders
                              The how to here is:
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #74
                              The how to here is:
                              @GertSanders - thanks very much for your comprehensive and quick reply.
                              OK, this is what I thought. Will have to change crystal to 8Mhz and burn a new bootloader.
                              Interesting info I found on Nick's web-site regarding my issue:
                              For running at 16 MHz you need at least 3.78V and at 8 MHz you need at least 2.40V. (Caveat: under testing I found that it did not seem to work reliably much under 2.8V at 8 MHz).
                              [EDIT] That unreliability would have been because of the brown-out reset kicking in at 2.7V. If you are using lower voltages you need to adjust or disable the brown-out detection.
                              I am planning to run at 8 MHz using the internal oscillator, to save parts and space. Thus you could conceivably run the whole thing off 2 x 1.5V batteries, giving around 3V nominally. However 3 x 1.5V batteries would be OK, and let you run it at 16 MHz.
                              Taken from here: http://www.gammon.com.au/forum/?id=11637 (Power Supply)
                              • GertSandersG
                                GertSandersG
                                GertSanders
                                #75
                                @alexsh1 I completely switched off the BoD in my fuse settings, this saves the battery even more. I found that the processor kept working down to around 1,64V. Even my NRF24 worked to that low level, because the last message I received in my Domoticz from that node gave a battery voltage of 1.64V
                                Anyway, since I monitor all battery levels via a script in Domoticz, there is no need for BoD.
                                rmtuckerR 1 Reply Last reply
                                • GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @gloob To burn a boatloader with Arduino IDE, you will need a second Arduino or working atmega328 onto which you can load a sketch.
                                  I have an older Arduino board (the one I bought when I first started exploring this new hobby), and I use the setup as described in this article: http://www.gammon.com.au/bootloader
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    Yes, I noticed that you have atmega328pO4M8i.bootloader.extended_fuses=0x07 which is as you said switches off all BoD levels.
                                    Thanks for an interesting info regarding the voltage. This is a very good news. I guess you are getting a notification in Domoticz if a battery level goes down to 1.64V?
                                    I'am going to setup a programmer on mega 2560 tonight, but meantime ordered one of the programming shields to streamline the process - http://www.boardstuff.co.uk/
                                    • GertSandersG
                                      GertSandersG
                                      GertSanders
                                      #78
                                      @alexsh1 I actually set up a notification on each Voltage sensor within Domoticz, so that I get a prowl message when the voltage drops below 2V. This then gives me some time to replace the batteries. The 1.64V was when I intentionally let a sensornode die out, just to see what would happen. I never let the voltage drop that low now. All my nodes now have batteries that should last at least 9-12 months (depends on the sensor and it's activities).
                                      • G
                                        G
                                        gloob
                                        @GertSanders
                                        Thanks for your help. I was now able to burn the bootloader and will start testing the board tomorrow when I have a valid 3,3V source to power the radio.
                                        Can I power the radio from an FTDI programmer if the programmer is set to 3,3V power? If yes, how to set the two jumpers?
                                        • GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @gloob if you power via a 3V3 FTDI interface, then you only need to close jumper 1 to connect the Vcc corcuit with the 3V3 circuit.
