  3. My own board (50mm x 30mm)
133 Posts 22 Posters 119.5k Views 21 Watching
  • rmtuckerR
    rmtuckerR
    rmtucker
    Sorry Guys seems the aerial was not tight enough on the Gateway,All working great now.
    • rmtuckerR
      rmtuckerR
      rmtucker
      Hmm thats a little worrying,Both sensors are not enclosed sitting in fresh air next to each other.
      10% away from each other seems a lot.
      I am awaiting a delivery of more SI7021 sensors let's see where that takes us??
      0_1454372709451_Screenshot from 2016-02-02 00:21:23.jpg
      • G
        G
        gloob
        Are these identical sensors?
        I have 10 sensebender micros with a SI7021 sensor and they show completely the same values.
        • rmtuckerR
          rmtuckerR
          rmtucker
          No
          One is an si7021 running on the board in this thread.
          The other is a HTU21D running on a pro micro that i already had set up and running.
          • alexsh1A
            alexsh1A
            alexsh1
            @GertSanders
            I have been struggling to upload photos in the openhardware section of your node and I think it is better if we move our discussion here. Take a look at these:
            This is my answer to the problem, but I think we can have a neater solution by having jumpers deciding on SDA/SDL pin out ?
            • alexsh1A alexsh1
              @GertSanders
              GertSandersG
              GertSandersG
              GertSanders
              @alexsh1 There is indeed a better solution, the next version of this board will allow swapping the I2C data and clock pins :-)
              alexsh1A rmtuckerR 2 Replies Last reply
              • GertSandersG GertSanders
                alexsh1A
                alexsh1A
                alexsh1
                @GertSanders
                Other than that I have not been using the JST connector - this may save some space unless you want to leave it as a power backup. I never used the second row pins (behind the FTDI connection) and some of them are not accessible if using a sensor connected via I2C.
                  @gloob There are two connections on the board to allow soldering the battery holder. Both the AA and AAA versions I use have the same pin spacing (seems standard), so you can use an AA battery holder as @alexsh1 does, or an AAA as I have.
                  http://forum.mysensors.org/uploads/files/1446751714416-image.jpeg
                  The red arrows show where the batteryholder pins should go. If you have individual AAA battery holders, then the pins surrounded by yellow circle are also used to connect the batteries in series. If the battery holder holds 2 batteries, then only the pins pointed to by red arrows are used.
                  The PLUS sign next the the pin on the lower right of the above image is for the LED, the polarity of the pins from the battery is marked on the silkscreen of the bottom side. Looking at it from the top side, the pin above right is for Positive, the pin on below right is for Negative (or GND).
                  Jumper J2 is to connect the IRQ pin from the NRF24 to pin 2 (INT0) of the atmega328. You could also use that to connect a switch between the top jumper pad (connected to pin 2) and the extra ground pin of C5, to use with a doorswitch. I have used this with the internal pull up, but that would not be very good for the battery-use. It is better to use a 1MOhm pull up resistor wich can also be connected using the extra hole connected to pin 2 and Vcc
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  wrote on last edited by rmtucker
                  #128
                  This post is deleted!
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    @GertSanders
                    I have been running these boards for some time now and overall very easy and compact.
                    And battery life on 2 AA batteries is years.
                    But i still have problems with deadspots in the house etc.
                    So i thought i would try changing the radio's to rfm69w and make another serial gateway with an rfm69hw.
                    I have received some of the hallard nrf to rfm adapter boards which i believe can be plugged straight in
                    What i would like to know is,Would it be ok to use one of these boards as a serial gateway with an ftdi adapter?
                    I am using the board barebones with no external crystal etc at 8mhz.(would this be a problem for a gateway?).
                    This would save on a lot of wiring (Level shifters etc).
                    alexsh1A 1 Reply Last reply
                    • rmtuckerR rmtucker
                      @GertSanders
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @rmtucker I'm using rfm69w with @GertSanders board (I think it is v1-1) via the same adapter you ordered. You need to solder IRQ pad in order for the board to work with rfm69. I tried to compile both a gateway and a sensor code and it worked. No need to have a crystal if you have the right bootloader on atmega328p. With or without crystal does not matter for radio. Radio has got its own crystal
                      rmtuckerR 1 Reply Last reply
                      • alexsh1A alexsh1
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        Wonderful just what I wanted too hear.
                        But could you elaborate on the irq soldering?
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @rmtucker just check out how to connect rfm69 to atmega328. @GertSanders luckily designed the board to be universal- there is a solder pad to connect D2 to IRQ, which you need to solder to use rfm69
                          • alexsh1A alexsh1
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @alexsh1
                            Indeed, there is a solderpad near to the D2 pin which needs to be closed (connected) to allow the IRQ signal to go to D2, so one can use the radio
